Good Day all,
On my Hilux 2,5D4D 4X4 I had an oil leak on the right hand side of the side shaft on the diff side.
Is there an oil seal in there?
And can one replace it from outside if you take the side shaft out?
Is there any problems to bear in mind when I do the job?
Thanks for any response.
Side shaft Oil Leak on 4X4 Figo
- Town: Springs
- Vehicle: '2013 2,5 D4D D/C 4X4 Hilux
- Real Name: Jan
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: Side shaft Oil Leak on 4X4 Figo
HI Jan,
The drive shaft oil seal possibly gave up the ghost. To replace it you will have to remove the shaft first. Do yourself a favour and get the oil seal from the Agents. They are really not expensive and if you are going to do all that work, best is to ensure it will not leak again there.
- Town: Springs
- Real Name: Jan
Dankie Johan,Janee dis maar die beste om egte parte te gebruik.
- Town: Henley on klip
- Vehicle: Toyota hilux 3.0d4d
- Real Name: Paul
- Club VHF Licence: HC346
Het onlangs myne ook gedoen en na ons uitstappie basslake toe, het Lionel sin ook begin lek.
Die agente is net so oor die R200 gewees vir die seel.
Sterkte....
Sterkte....
- Town: Mooi River KZN
- Vehicle: 96 SFA D/C 4x4 2.4
- Real Name: Malcolm
Hi all. Similar problem on my kz-te bakkie.
Sideshaft is leaking badly right front.
There is also a LOT of play on sideshaft entering diff.?
Not just the sideshaft but the first part of diff is very loose
Sent from my S60 using Tapatalk
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
