How do i remove wheel arch trim on KZTE ?
KZTE Nut
Town: Johannesburg
Vehicle: Hilux KZTE DC 4x2
Real Name: Mervyn
Post by KZTE Nut »
Hi
Anyone know how to remove the wheel arch trims on KZTE ? I removed the bolts inside the wheel arch but it is still 'vas'
There must be a way to maneuver/unclip the trim. I am trying not to break it... :shock2:
Re: How do i remove wheel arch trim on KZTE ?
With the nuts off it must come free. It's probably just bound fast over time or maybe someone has stuck some glue in there. Try prying it gently along it's length (use a rag behind the tool against the paintwork).
P.S. If you don't have a pry tool you can use an old fork or spoon handle that has a curvature in the end, just sharpen the tip a little. :winkx:
Also just check that there are no screws that have been put in on the inside lip. :think:
KZTE Nut
Town: Johannesburg
Real Name: Mervyn
Post by KZTE Nut »
Thanks Mud Dog ! I will try your method :thumbup:
