Where can i get good Recon Diff or Second Hand Diff
If you would like to discuss the functionality of this web site or have any suggestions, please out it here.
DANIELK
Town: Randburg
Vehicle: Toyota Hilux 1990 DC V8
Real Name: Karl
Needing to replace my rear diff after this weekend after turning at the robot felt like the diff fell off the truck.. rear wheels seized up after, got a the flatbed truck to bring it home the following morning locked in the front hubs and drove in slowly into the driveway..
seems to be no drive at on to the rear wheels at all, rear wheels off the ground truck in gear and running running prop spinning but wheels are standing still.. :(
I'm needing to try and find a rear diff for 1990 SFA Double cab 4x4.
Regards
Karl
Trucks
1990 Toyota Hilux DC 4x4 4.0 V8 1UZ-FE (Current)
1998 Ford Courier SC 4x4 3.4 V6
2001 Ford Ranger DC 4x4 2.5 TD
1996 Ford Courier DC 4x4 3.4 V6
Tim86
Real Name: Tim
Located close to you in Magaliesburg are Jaco & Henk Groenveld of Living SFA (look it up on faceboet) - Jaco: 060 451 5714.
Further afield is Arrie in Steelpoort who just yesterday was advertising brand new diffs for that axle - Arrie: 082 357 6023
The V8 may be the cause of your diff failure, possibly consider something stronger for the back.
DANIELK
Town: Randburg
Real Name: Karl
Tim86 wrote:
Mon Jul 08, 2019 11:27 am
Thanks Tim was also thinking the same, most of the damage was done by prev owner, Replace full prop and clutch after buying the truck just under 2 years ago.. Will ask the guys what would they recommend for a stronger solution for the back.
Regards
Karl
Trucks
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Karl I might be wrong. Your bakkie load sensor valve need adjustment. Do you have 33/35 tyres fitted?
DANIELK
Town: Randburg
Real Name: Karl
The Legend wrote:
Mon Jul 08, 2019 6:18 pm
33 12.5 x 15 Tyres, I don’t get locking up on the rear breaks when breaking in wet or dry conditions ?
Regards
Karl
Trucks
Scott
Vehicle: Hilux SFA
Real Name: Rodney
That looks like a import diff which is a very strong diff so you can normally have it re-conned or you can have a look at putting the d4d center portions in for better ratio.
DANIELK
Town: Randburg
Real Name: Karl
Scott wrote:
Thu Jul 11, 2019 2:57 pm
Taking the diff out tomorrow and sending if off for recon... I'm not sure what abuse the prev owner gave the truck, I know these import diff's are strong.
Regards
Karl
Trucks
They are indeed tough, much stronger that the local GearMax one. Refurbishing is the better option, changing the ratios means changing the front diff as well - the front and rear diff portions (3rd members) are interchangeable, a nice option to have if you have diff trouble out in the styx.
DANIELK
Town: Randburg
Real Name: Karl
Mud Dog wrote:
Sat Jul 13, 2019 12:13 am
Diff is out and i will go for recon next week... I must be honest i don't even what to try gearmax diff with the V8... i have not heard good reports
Regards
Karl
Trucks
Here's the thing to be careful for .... that drive train was never designed for the torque of a V8 and with a standard motor the drive train already takes more strain than designed for when you fit 33" tyres. Now take those 33's and drive them with a V8 - you're gonna break something in time .... just the wrong amount of torque at the right moment.
Just also make sure the guys doing the recon know that they're dealing with V8 power so that they don't cut corners or fit sub-standard parts. :winkx:
Then learn to drive like a blouse. :D:
Scott
Vehicle: Hilux SFA
Real Name: Rodney
yes agree with Andy that is same as taxi diff as far as I know so there will be very good replacement parts and very bad parts out there i remember when I done the bearings the spares shop pulled a no name brand out and I said try again and they had name brands in stock at a price difference but worth it.
Return to “Web Related Discussions and Suggestions”
