Hi Guys!
I run an automatic ‘91 Hilux Surf. I’m continually blowing the top forward most 20A fuse in the panel at the drivers foot. It blows just by turning the key. I imagine it’s a grounding wire. I found some diagrams for the 22R E, wondering if they coincide?
Once it does blow, I lose my dash lights except seatbelt and glow plug, I become stuck in 3rd gear and my batteries don’t get a charge. 9Vs runs to both.
Also any helpful tips would be really great! I’m decently mechanically inclined, but this wiring will be the death of me.
Thanks in advance!
Help! - Blowing a Fuse 2L TE
Re: Help! - Blowing a Fuse 2L TE
Hi and welcome Hannah.
Is this still a RHS drive vehicle? Just curious.
Does the fuse box cover plate not tell you what the fuse is for? I doubt it's a ground wire, they aren't fused. You might however have a short circuit to ground which would blow the fuse immediately when supplying power. Does it blow every time or just sometime? Does it blow when turning the key to "Accessories" or only when turning further to "Ignition"? If it's accessories first thing I would check is the cigarette lighter ... remove it from the socket and see if it still blows. Then also check the socket wiring itself (you have to remove that console cover).
If that's all OK I would remove that fuse, turn the key on and then using a multi-tester set to DC Volts and determine which leg of the socket is live (connect the black wire pin to a good ground like a screw that goes into the metal of the body, and then try each leg of the socket. The leg that gives you a voltage reading is the live one). Then set the multi-meter to Ohms (resistance) and connect either pin to the other socket leg and the other pin to ground. If you're getting a low resistance reading or zero resistance, you have a wiring short. The resistance should be upwards of 0.8 ohms.
If you have a short, the challenge is to find it
I see you have some creative wiring on the 7.5A fuse next to the 20A that's blowing. That could be an indicator that someone has done some sub-standard electrical work. Try determine which wire leads off the leg that you tested for resistance .You might have to remove the fuse box to see behind and it's a good practice to disconnect the red wire from the battery before doing so. Then trace that wire paying attention to any splicing that may have been done. If there is splicing, trace the splice. Better still disconnect it and test it for resistance to ground ... chances are that you might find the culprit.
Hope you find the fault easily and that it's just a faulty cigarette lighter or something equally simple.
- Town: Campbell River
- Vehicle: 1991 Hilux Surf
- Real Name: Hannah
Hi Andy!
Yes - It's a right hand drive!
The cover plate is missing, but a buddy of mine found one online. The fuse that is blowing was labelled engine. Not much use without the wiring diagrams though. It blows when the key turns to on, before turning it over. It went 3 times in a row and then I followed some wires and wiggled them around, probably coincidence or the wire shorting was adjusted so that it wasn't hitting the firewall? I'll run out and confirm if its a short using a multimeter. I'll also check the wiring for the cig lighter. It's never worked.
This is all really great info!! Thanks for the help!
Pleasure!
Yup, looks like the creative wiring extends somewhere behind the dash and what you say sounds very likely .... moving the wires about has very possibly cleared the short (temporarily - it will resurface again).
Happy trails!![WinkExtra :winkx:](./images/smilies/winkextra.gif)
Happy trails!
- Real Name: Hannah
Completely stuck.
I've thrown a slow blow automatic reset fuse into it. It is constantly resetting, so its turned into a huge fault now. I'm searching for wiring diagrams, but coming up blank. Found a connector that goes into the fuse block, when it’s pulled the short stops. A white wire that goes into the back of that rings out to a white wire in a connector straight to the ignition. This white wire when measured, reads a dead short to ground. We bypassed the white wire by just cutting it at each connector and threw a wire in. It stopped the short, but the truck wouldn’t start.
Sorry if half of it doesn’t make sense. Doing my best to explain what I saw!
ISO wiring diagram or someone very familiar with the electrical system in this truck![😩](//twemoji.maxcdn.com/2/svg/1f629.svg)
We never got the Surf here in RSA, and although similar to the Hilux / Tacoma, the wiring harnesses might differ. If so, then so would the diagrams but maybe you can look at Hilux / Tacoma wiring schematics for diesel models of a similar era, they should differ too much.
There is another possibility of where the short can lie other than in the wires themselves, and that's in one of the components that are fed by that white wire, possibly something like the glow plug solenoid /controller or the starter motor solenoid.
Have you tried tracing the wire with the direct short to earth?
![Thinking :think:](./images/smilies/icon_think.gif)
What is this insulation tape on the blue wire (circled in green) which you say goes to the Ignition? Is it a splicing of another wire into it?
- Real Name: Hannah
I'll go look for the diesel hilux pick up diagram. That's definitely a possibility and why I'm hoping to find diagram. It might not be that wire, it could be something that wire runs to for sure. Maybe a be a relay too?
We traced it using a ground from the truck?
That blue wire (circled in green) was a solder made by the previous owner, would've been over 8 years ago. They had installed another cig lighter and plugged in an XM radio connection and taped it up under the dash. I've removed that. They also rewired the antenna with solder/ heat shrink butt connectors.
Could also be a relay with a dead short, yes.
Hope you find the fault, otherwise it may mean calling in an auto-electrician.
