Hey Gents.
I am about to install a NL battery box in my Legend 50.
Problem is, I have no idea where to take the wire into the bin of the bukkie.
Any top tips that don’t drill the body or compromise the canopy seals ?
Thanks in advance
Just bear in mind that wherever you might need to make a hole for wiring, That you fit a rubber grommet so that there won't be chaffing of the insulation over time. The battery cables are quite thick so I would make two separate holes, one for each cable ... you will also get a good seal that way, whereas two cables through the same hole won't seal at all.
Life is like a jar of Jalapeño peppers ... what you do today, might burn your ass tomorrow. Don't take life too seriously ..... no-one gets out alive. It's not about waiting for storms to pass. It's about learning to dance in the rain. And be yourself ..... everyone else is taken!
Lekka, thanks for the advice. Thinking of using one of those electrical penetrators, the kind with a small “o” ring. Yes I also thought 1 per wire. Thanks for the reply
