Is this the way it should be??
- falcon
- Town: Alberton
- Vehicle: HILUX S/C 4X4
- Real Name: Riaan
I have a 2009 S/C 3.0 D4D 4X4 and had 2 Pajero's before this one also 4X4 but the Hilux do something the others did not.When I drive in 4X4 High Range and turn into a corner at low speed like when I want to park it is jumping as if the Diff Lock is on and it is not it also feels like the hand brake is on because if I leave the petrol pedal it just stops this is strange.
Is this correct or is something else wrong?
Re: Is this the way it should be??
Check that your rear drum brakes are not binding...
B
B
- Town: Durbanville
- Vehicle: Prado 120 VX
- Real Name: Jaco
- Club VHF Licence: B35
This will happen on tar or any surface where traction is good as the center diff is locked when 4H or 4L is selected on the Hilux - Not good for the vehicle.
- falcon
- Town: Alberton
- Real Name: Riaan
I use it in the rain because the back is so light and it tend to spin out should I rather not?
You put a while lot of strain on the drive train because of the fact that the front and rear axles get "locked" together when you engage 4wd. Unlike a permanent 4wd vehicle the Hilux does not have a center diff.falcon wrote:I use it in the rain because the back is so light and it tend to spin out should I rather not?
- Optimus Prime
- Town: Krp
- Vehicle: Fortuner 4.0 v6
- Real Name: Robert
Id say rather not ,this can become an expensive excersise.
"As long as power flows through any of my circuits ill 4x4."
Agreed, rather load something heavy (a sandbag) in the loadbin to weigh it down or drive with a lighter right foot.DieBul wrote:Id say rather not ,this can become an expensive excersise.
- falcon
- Town: Alberton
- Real Name: Riaan
Thanks for the response I will just have to take the tar corners more carefully in future :)
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Riaan, jy moet nooit daai bakkie op teer, nat of droog, in 4x4 ry nie. Jy gaan hom breek! Die drivetrain gaan opwen, want die teer is nie glibberig/los genoeg sodat die bande kan gly nie. Gaan ry bietjie op grond in 4x4, draai skerp, dan hoor jy hoe gly daai bande.
Ek ry n 3.0TDCi Ford, en as dit reen, is ek maar rustig op die throttle.
Riaan, listen to the guys here ... in a turn the front wheels travel on a wider arc than the back which means that the distance travelled differs. If you engage 4x4 you're locking front and back wheels to drive at the same speed. In a straight line, no prob but in a turn ... axle windup! A loose surface is forgiving and the wheels slip easily enough, but on tar somethings going to have to give and if it's not the tyres, it'll be a diff that strips or a half-shaft that snaps. Either way it'll be an expensive repair.
Some vehicle manufacturers used to employ a LSD (limited slip diff) on the drive wheels to overcome wheel spin on pull off, and improve drive traction in the wet. It seems that this is not so popular anymore because of the extra cost, but I think the bigger engined BMW's still have it. LSD's are still available as aftermarket upgrades on most vehicles, unless you already have difflock ... don't think you can have a combination of both.
- Vehicle: '96 D/C Raider
- Real Name: Bennie
Riaan
If you selected 4HLC on the Pajero you would experience the same. Remember the Pajero is about the only 4wd vehicle that can be driben in 4wd and 2wd on tar. Normally vehicles with a centre diff does not have a 2wd option and vehicles with 2wd dont have a centre diff
