Page 2 of 2
Re: Hilux Rebuild
Posted: Thu Jun 12, 2014 2:34 pm
by LouisZ
Yes it will reduce performance. But every bend reduce air intake, ie it makes the actual piping longer as it is, this where you loose more power.
Why do you turn the cover with throttle body 180 degrees, then you reduce the length of the piping.
Re: Hilux Rebuild
Posted: Thu Jun 12, 2014 2:55 pm
by LouisZ
Like so.
Re: Hilux Rebuild
Posted: Thu Jun 12, 2014 3:35 pm
by Striker
Louis, I do loose a little bit of power, but I'm willing to compromise that instead of getting dirt/water into the engine.
Also the engine is so much quieter without the cone filter!
Re: Hilux Rebuild
Posted: Thu Jun 12, 2014 3:39 pm
by Striker
Look at this setup
Re: Hilux Rebuild
Posted: Thu Jun 12, 2014 4:34 pm
by LouisZ
Dis mooi so.
Wat ek bedoel is om die boonste gedeelte van die intake wat ook die Throttle body op het los te maak en dan 180 grade te draai. :wink2:
Sodoende is die intake pyp korter en het bykants nie enige 90 grade draaie in nie. Al wat dan gedoen moet word is om die throttle kabel bietjie langer te maak en hier daar klein goed soos die fuel pype wyer uit te bring.
Re: Hilux Rebuild
Posted: Fri Jun 13, 2014 9:50 am
by robvan87
Does anyone have a lexus autobox to Hilux 4Y 2.2 transfercase adapter lying around gathering dust
? or know of a place that sells them for a reasonable price (Not R4500-00
) That is a bit steep for me at the moment.
Re: Hilux Rebuild
Posted: Fri Jun 13, 2014 9:57 am
by robvan87
I understand what mean by turning the whole intake around Louis, but will there be space for the Idle Controll valve to be facing to the rear, it is somewhat of a touch and go situation with the intake facing the right way round. What would one do about the breather pipe that is situated at the bottom of the throttle body. Has any one checked the performance impact of different intake systems.
I thought of taking my donaldson filter to a master welder here in town to convert all the pipes to 76mm. Would that have less of an impact on performance with the long piping than having long piping plus smaller diameter donaldson setup?
Re: Hilux Rebuild
Posted: Fri Jun 13, 2014 11:03 am
by vanthev8man
striker,
that is a very neat set up,but iiwy - change the top rad hose!
i has got to have a longer pipe in a "S" form to allow for movement of the motor.
otherwise it is going to crack the radiator side over time!
Re: Hilux Rebuild
Posted: Sun Jun 15, 2014 10:44 am
by Willied
robvan87 wrote:Does anyone have a lexus autobox to Hilux 4Y 2.2 transfercase adapter lying around gathering dust
Rob, have a word with Mark Watson.. He might be able to put you in contact with the right people.. oh ate two 762 six five four seven..
Re: Hilux Rebuild
Posted: Mon Jun 16, 2014 12:06 pm
by LouisZ
Rob you talking about the adapter plate between the gearbox and bellhousing?
Re: Hilux Rebuild
Posted: Mon Jun 16, 2014 12:10 pm
by robvan87
Hi, no I already have the cast bellhousing for the manual gearbox. I need the adapter between the automatic transmission and the original 4y Transfer case. Converting from manual to auto.
Sent from my GT-N7100 using Tapatalk
Re: Hilux Rebuild
Posted: Mon Jun 16, 2014 12:27 pm
by LouisZ
Mark Watson can help.
Re: Hilux Rebuild
Posted: Wed Jun 18, 2014 11:21 am
by robvan87
Thanks guys. Spoke to Mark this morning. Gave the go ahead for all the goodies. He says it will take about 2 weeks for the adapter to be completed. So hopefully the Lux will be roaming the roads again in 3 weeks!
Re: Hilux Rebuild
Posted: Wed Jun 18, 2014 8:31 pm
by Willied
Good to know he could help,if I may ask.. what was the price on the adapter?
Re: Hilux Rebuild
Posted: Wed Jun 18, 2014 10:06 pm
by Muz
hi Robert
Pity you going the auto route, I did get my bellhousing from Fana. His are dead straight and no problems with my setup. Made my own up for the 2.5TDI once upon a time and it used to slip out of 4th due to it not being exactly in line.
Alternatively you could have used a lexus bellhousing with the adaptor plate to the hilux box, with a concentric release bearing setup. clutch is very light on the foot.
What ECU are you using now that you going auto?
regrds
Murray
Re: Hilux Rebuild
Posted: Sun Jun 22, 2014 7:45 pm
by robvan87
Getting the whole setup from Mark. Spitronic shifter tcu. One of his oil coolers and the adapter. I have to go the auto route cant afford the manuals no more!
Sent from my GT-N8020 using Tapatalk
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 9:01 am
by robvan87
Hi Muz. Don't know what Marks policies are so I don't know if I am allowed disclosing any prices. I would suggest you contact Mark directly.
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 9:02 am
by robvan87
Sorry Not Muz... Willied!
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 12:10 pm
by Willied
robvan87 wrote:Don't know what Marks policies are so I don't know if I am allowed disclosing any prices. I would suggest you contact Mark directly.
No need for me to contact him for the pricing.. If you go there ask him to see my truck..
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 12:43 pm
by robvan87
O OK great! Going there on Friday hopefully I will be able to have a look at it!
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 8:30 pm
by Willied
robvan87 wrote:O OK great! Going there on Friday hopefully I will be able to have a look at it!
I will only get to see it monday, please let me know what you think of the color choice of the motor.. :D
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 8:32 pm
by robvan87
Great will do! Is Mark almost done with it?
Re: Hilux Rebuild
Posted: Mon Jun 23, 2014 9:22 pm
by Willied
robvan87 wrote:Great will do! Is Mark almost done with it?
2-3 weeks..
Re: Hilux Rebuild
Posted: Fri Jun 27, 2014 4:53 pm
by Willied
Did you get to pick up your parts Rob?
Re: Hilux Rebuild
Posted: Sun Jun 29, 2014 6:40 pm
by robvan87
Hey, yes got the gearbox and adapter on Saturday morning. Still waiting for the shifter, tcu and cooler which Mark Wil be sending on Monday hopefully!
Got the box fitted today, my gosh that box and the adapter is a lot heavier than the manual. Almost gave up!
Made up a bracket for the transfer case to fit on the cross member. Will get the propshafts sorted tomorrow. Need about 30mm shortened at the back and lengthened in the front.
Think by Wednesday I will be able to take it for a test drive.
Re: Hilux Rebuild
Posted: Sun Jun 29, 2014 6:42 pm
by robvan87
Got the van back from the panel beaters back on Friday as well. They repainted the engine bay and bonnet for me after the fire incident! [LOUDLY CRYING FACE]
Re: Hilux Rebuild
Posted: Sun Jun 29, 2014 6:44 pm
by robvan87
Re: Hilux Rebuild
Posted: Sun Jun 29, 2014 6:45 pm
by robvan87
1gz-fe twin turbo! That's damn neat!
Re: Hilux Rebuild
Posted: Wed Jul 09, 2014 6:32 am
by robvan87
[attachment=-1]uploadfromtaptalk1404880349553.jpg[/attachment]
Re: Hilux Rebuild
Posted: Wed Jul 09, 2014 6:35 am
by robvan87
After a extreme amount of time, tears, cursing, suicidal thoughts and effort the rebuild is slowly creeping to an end. A few more little issues to sort out but the biggest hurdles have been overcome.
Re: Hilux Rebuild
Posted: Wed Jul 09, 2014 9:10 am
by Haboob
Looking very nice Robert, will be really interested to know what kind of consumption figures you will be getting. AM Racing(Dylan) here has a similar conversion and that V8 sounds GREAT... it also has loads of Power.
Re: Hilux Rebuild
Posted: Wed Jul 09, 2014 2:07 pm
by robvan87
I drove from nelspruit to Lydenburg this morning and some some town driving 140km total. Only put in 36 liters this morning and the tank is still half, was empty before I filled it. Quick calculation will put the consumption between 6 and 8. Will fill on Friday as I need to have it dynod in Witbank. Will have an accurate measurement then.
Re: Hilux Rebuild
Posted: Mon Jul 14, 2014 2:13 pm
by robvan87
Fuel Consumption update: From nelspruit to Jhb I got 4 km to the litre, this was due to the gearbox that was stuffing around, had no second gear at all so you can imagine it was a bit of a nightmare! Thanks to Mark Watson, the problem was solved early Saturday morning at his Workshop in Springs. Thanks Mark!
On the way back I stopped over at CC Dyno for a tune up, Men did some adjustments for me, and what a difference it has made, avg 120 on the highway and she gave 7.5km/l. Wasn't bargaining on much more so I am happy with that figure.
Just to put out there guys, Mark is a hell of a guy. Always willing to sort your problems out without any hassles! Thanks Matk
Re: Hilux Rebuild
Posted: Mon Jul 14, 2014 6:55 pm
Good to hear!
So is your rebuild project complete now? Some more pics, especially of the engine bay would be great!
Re: Hilux Rebuild
Posted: Mon Jul 14, 2014 8:47 pm
by robvan87
The project is almost complete, need to put some remaining wires into sleeving, sort out some rattles, and fit that stofpad bumper. Oh yes and refit the roof rack canopy and rooftop tent!
Will post pics soon!
Re: Hilux Rebuild
Posted: Mon Jul 14, 2014 9:22 pm
Re: Hilux Rebuild
Posted: Tue Jul 15, 2014 11:10 am
by Haboob
Sounds great Rob...
Re: Hilux Rebuild
Posted: Tue Jul 15, 2014 9:36 pm
by Willied
Hey Rob, remember to show us the bumper..
Re: Hilux Rebuild
Posted: Wed Jul 16, 2014 2:18 pm
by robvan87
Sure will do guys! Hopefully I will be able to complete this week.
Re: Hilux Rebuild
Posted: Sun Jul 27, 2014 2:34 pm
by robvan87
Okay, the bumper will have to wait a bit for now. Leaving for Botswana in the morning. Got the canopy on at least and sorted some rattles.
The image below touches the close but faaaaaaaar... Category
[attachment=-1]uploadfromtaptalk1406464471418.jpg[/attachment]
Re: Hilux Rebuild
Posted: Fri Aug 22, 2014 9:36 pm
by Sven
Robert, i have seen you driving around Nelspruit, dude, your Hilux is stunning!! super envious!!
Re: Hilux Rebuild
Posted: Fri Aug 22, 2014 11:03 pm
by cyborg
'Ell that looks nice...
Re: Hilux Rebuild
Posted: Mon Aug 25, 2014 3:56 pm
by robvan87
Thanks guys, much appreciated!
