Very useful item to use with your High Lift Jack
Yes some of you may say, what do I do if a want to remove the wheel if I lift it up using this item
Well this lift mate can be used on vehicles that do not have special high lift jack points, what we do is just carry a few small blocks of wood, we lift the wheel and then place the blocks under the axle, then remove the wheel.
This item is very useful if your vehicle has a lot of flex with the suspension, you end up lifting the vehicle and not just the axle, sometimes with some vehicles, you lift up the body and the axle sags down or drops and the wheel is still on the ground.
When we bought our Lift Mates, we ordered four of them, from America and if I remember correctly they cost us about R400. each.
For this photo above turn your monitor on its side to see it correctly :roll: :)
The Lift Mate
- SYRON CONVERSIONS
- Town: Tamboekieland
- Vehicle: SFA HILUX
- Real Name: SIMON
The Lift Mate
simoan
simoan
Re: The Lift Mate
Bought myself one so that I can use the high lift (actually a farm jack that I am quite happy with) on the Pajero since it does not have all the nice steel bars and stuff like the Hilux to use the jack
