Suspension Lift
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Suspension Lift
Ek weet n stupid vraag kry n stupid antwoord maar "as" hierdie n stupid vraag is soek ek asb nie n stupid antwoord nie
Almal sukkel met body lifts en suspension lifts, het nou gesit en wonder, kan mens nie tussen jou blad vere en jou as n spacer in sit nie? Dis tog baie makliker of nie?:crazy:
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Suspension Lift
Jy kan, jy kry ook sulke 4" kits te koop.
Dit vermeerder nie jou "travel" of "articulation" nie
Dit veroorsaak ook "axle tramp" veral in sand, ek het twee stelle hier wat ek moes uithaal.
Re: Suspension Lift
Jo Allan, wat de jorry is dit?axle tramp
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Verduidelik bietjie meer en wat is axle tramp?
Re: Suspension Lift
Dis Jorrie se meisie wat onder die bakkie le, Mark...
Another explanation:
Thanks to : http://www.motorera.com/dictionary/AX.HTMAxle tramp
A form of wheel hop which is usually found in live rear axle cars. It occurs when sudden torque loads on the suspension cause the driven wheels to shake violently by slightly rotating the wheels and then springing back.
Thanks to: http://www.mkivsupra.net/vbb/archive/in ... t-563.htmlAxle tramp used to be caused when leaf springs got wound up by the torque developed by a fast take off. This cause the springs to distort into an 'S' shape which is unatural so the springs tried to straighten out again thus causing a tramping effect of the wheels bouncing.
With the setup on a Supra this I believe shouldn't happen (but I'm prepared to accept differently) and what I believe is happening is similar but not the same.
As you try taking off quickly the wheels will lose their grip as noted by the spinning, the grip starts to come back as the road speed increases but not in a uniform manner so what you're getting is 'spin, grip, spin, grip' again causing a possible bouncing effect in the suspension. You should feel this. If you're not getting any bouncing at the rear then I would check all your bushes because theres some other movement in the drivetrain causing this thudding.
Re: Suspension Lift
Dankie
Gelukkig ken ek haar nie!
Re: Suspension Lift
That's what Bretton's van does on tar when you drop the clutch at 4500, afraid you can't see much though for the smoke pouring off those 33 mudsunknown wrote:Axle tramp
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Okay kaspaas se 7mge was nou weer vinneger as my 4y..sorry
- Danman
- Real Name: Danie
Re: Suspension Lift
wat noem 'n mens dit dan in afrikaans........'n "As Trass"?
Re: Suspension Lift
Ek sien julle manne ken ook vir Google.... Geluk..
Re: Suspension Lift
I've learned something too .... never knew there was a name for it ... always just referred to it as wheel hop caused by leaf spring twist. Incidentally this occurs under heavy braking as well ... one of the other reasons why we have torque rods on our SFA's since the front wheels do most of the braking.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Allen is die goed dalk tekoop? Kan jy fotos plaas van hoe dit lyk? Moet mens dan jou shocks verander? Het Rancho rs9000xl in op die oomblik
- Hoppy
Re: Suspension Lift
As jy so ver is, sal dit goedkoper wees om dit self te maak, sal vir Kaspaas of die engelsman kry om foto's te plaas.
Jou shocks sal werk.
Ek beveel dit nog steeds nie aan nie.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Dankie, waf in spanning
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
As mens van die load hog helpers by die vere sit sal dit nie dalk die axle tramp verminder of weg vat nie??
Re: Suspension Lift
Nee, al wat die load-hog helpers doen is om jou veer-artikulasie heeltemal op te bogger.hi-hilux wrote:As mens van die load hog helpers by die vere sit sal dit nie dalk die axle tramp verminder of weg vat nie??
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
En as mens op die agterste as ook n tipe torque rod kan opsit of maak?
Re: Suspension Lift
Ja jy sal so iets kan maak. Ek het algesien dat ouens dit doen.hi-hilux wrote:En as mens op die agterste as ook n tipe torque rod kan opsit of maak?
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
Re: Suspension Lift
Maak liewer langer shackles
Re: Suspension Lift
Rather do a proper body lift, it's not that expensive... or if finance is really an issue consider a set of extended shackles...
I did the extended shackles, works great and I got decent lift, same as 50mm body lift!
Mikem Suspensions sells good quality greasable ones at an affordable cost!
Mr B
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Het nie agter n probleem om langer shackles te maak nie, maar as jy voor ook langer shacles maak dan raak die propshaft se angle te veel...of so dink ek.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
any pics Bretton? Its not the finance....its the amount of work
Re: Suspension Lift
Will take a foti or 2 this evening, my lux is home in the garage... with the power steering box in pieces!
Mr B
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Sorry to hear. Thanx so far
Re: Suspension Lift
If you have as much as 100mm suspension lift (springs) as well as extended shackles, the propshaft angle should still be OK for the uni's to handle but the length of the shaft may be a problem. If the overall lift is too much you might need the have the prop lengthened & balanced. To check if it's OK, jack up the front till the wheels hang free, then try move the prop from side to side / up & down in the centre. If the slip joint allows more than 10mm overall sideway movement (5mm each side), it's either worn or too close to the end of it's travel.hi-hilux wrote:Het nie agter n probleem om langer shackles te maak nie, maar as jy voor ook langer shacles maak dan raak die propshaft se angle te veel...of so dink ek.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
No pics bretton
Re: Suspension Lift
Trevor sorry man, I had an important visitor last night, and then totally forgot about it... will post the pic this evening if this is ok?
Mr B
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
No problem Bretton...will it be posible to give me the front and rear shackle lenthgs as well? Please..
Re: Suspension Lift
Will measure this evening, but if memory serves me well it 100mm...hi-hilux wrote:No problem Bretton...will it be posible to give me the front and rear shackle lenthgs as well? Please..
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Because the front is shorter than the rear on my lux...therefore i want/need the measurements pleaze
- ismail
- Real Name: Ismail
Re: Suspension Lift
Hi Trevor, I got extended Mikem shackles (greasable), although I bought it from Alucab tho, give darryl a call they cost around R600 per pair ex delivery, if I am not mistaken they 50mm longer than standard hence giving 25mm lift
I surf more than I work
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Will it be posible to get 45-50mm lift out of shacles or will it become a danger hazard? coz 25mm isnt much
- ismail
- Real Name: Ismail
Re: Suspension Lift
i think it will be a hazard, think of it, your bakkie loaded and "floating" on stilts.
- COREFLY
- Town: BLOEMFONTEIN
- Vehicle: 2200 4X4 DC
- Real Name: MITCH HENDRY
- Club VHF Licence: X 59
Re: Suspension Lift
Howzit,if you want to lift to 50mm then you must lift your shackle with 50mm and extend your fixed point with 50mm aswell,if you just lift your shackle at the back you gonna have to lift your shackle 100mm longer than what it already is to get a 50mm lift,dont think it to safe cause yore shackle can flip in the wrong direction without knowing and it wil chow into your chassishi-hilux wrote:Will it be posible to get 45-50mm lift out of shacles or will it become a danger hazard? coz 25mm isnt much
I THINK !!!!
- GeorgeJvR
- Town: Louis Trichardt
Re: Suspension Lift
On my 1952 Willys CJ3B Jeep The previous owner did a Axel under leave spring conversion from the standard axel over leave spring, and neadless to say I broke the pinion gear on the rear axel (Dana 44) then i fitted a torque rod that helped a lot. but not enough.
On my SFA I've got a 3" Procomp Lift it comes with lift blocks at the back that u use with your standard SFA rear leave springs, altough the Procomp lift is werry impressive and capable i'll cange the rear leaves with the lift blocks for a Mikem as soon as the funds is availible.
With my 31" there is already some axlewrap.
My opinion stay away from the lift blocks !!!!!!!!!!!!!!!!!
Kom wat wil ek bly 'n Bul!
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
""if you want to lift to 50mm then you must lift your shackle with 50mm and extend your fixed point with 50mm aswell""
I never thought about this, make sence and alot saver i think than very long shackles alone
- Town: 11
- Vehicle: 111
- Real Name: Hannes
Re: Suspension Lift
How do you extend the fix point? Never seen this done before.....hi-hilux wrote:""if you want to lift to 50mm then you must lift your shackle with 50mm and extend your fixed point with 50mm aswell""
Only way I can think of is by cutting of the current U shape mount on the chassis, replacing it with a longer and stronger one?
But don't think I wil trust my own or for this sake any ones welding on this part... Can get very risky.
- Town: Port Elizabeth
- Vehicle: 1990 SFA Hilux
Re: Suspension Lift
Mitch,
Please see if you can get some pics of the fixing point change. I totally support the theory, I just need to picture the fixing point mod.
Cheers!
Cheers!
- COREFLY
Re: Suspension Lift
I think it would be best to take it to a engineering shop
Much safer,should get some form off guarantee
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Pics Bret??
Re: Suspension Lift
Sorry dude... I've been a bad bee!
Here we go...
Rear extended shackle: Front extended shackle: Rear Height(I've got 33's on...) Front Height:(again 33's...) I hope all is forgiven now!
Here we go...
Re: Suspension Lift
In my opinion there is no need nor real benefit from changing the fixing position of the shackles. If this were a beneficial mod, there would already be guys that have done it with a whole bunch of threads on the topic. This is something that's critical to safety ... I would'nt consider it.
Re: Suspension Lift
I agree with Andy, cutting and drilling on a chassis is not recommended.
Re: Suspension Lift
Rember guys them's "Import Spec SFA Hilux" ones hey, different to "Local Spec" SFA Hilux hey :Geek:
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Dankie vir jou tyd...
- (35.03 KiB) Downloaded 280 times
- rear_ext_shackles.jpg (37.21 KiB) Viewed 4796 times
Re: Suspension Lift
Trevor... from grease nipple to grease nipple... front and rear... 142mm...
Mr B
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Myne meet 80mm agter en 90mm voor, dis 63mm verskil van joune. Glo nie ek sal 50mm lift uit dit kry nie, maar sal dit probeer die naweek en sien wat die lift in mm is. nogmaals dankie vir jou tydMr_B wrote:Rather do a proper body lift, it's not that expensive... or if finance is really an issue consider a set of extended shackles...
Mr B
Re: Suspension Lift
Don't forget that Bretton has bigger tyres fitted .... 33's that's already about 75mm more than the standard 30's and 50mm more than the more commonly used 31's.hi-hilux wrote:Myne meet 80mm agter en 90mm voor, dis 63mm verskil van joune. Glo nie ek sal 50mm lift uit dit kry nie, maar sal dit probeer die naweek en sien wat die lift in mm is. nogmaals dankie vir jou tydMr_B wrote:Rather do a proper body lift, it's not that expensive... or if finance is really an issue consider a set of extended shackles...
Mr B
When I originally fitted OME, I achieved a lift of about 110mm which has since settled a little, but not much.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Ek verstaan dat hy 33's op het maar ek bedoel die lift uit die shackles sal nie 50mm gee nie, nie as daar n 63mm verskil tussen ons shackles is nie of is ek verkeerd?
- ismail
- Real Name: Ismail
Re: Suspension Lift
Mud dog, 110mm with the OME, thats quite abit.
Re: Suspension Lift
That's correct, but in my case the bushes were shot and binding, so the shackle couldn't return to it's default position... the new shackles and bushes fixed that! When Allan did the install for me, he parked my hilux next to one with a 50mm body lift and 33's, Bolt was standing a little taller!hi-hilux wrote:Ek verstaan dat hy 33's op het maar ek bedoel die lift uit die shackles sal nie 50mm gee nie, nie as daar n 63mm verskil tussen ons shackles is nie of is ek verkeerd?
Wait here is a pic of Bolt(right... OME susp, 33's and ext shackles) and Kwaga(left... OME sus, 35's and 50mm body lift)..
Hessequas - April 2009...
Mr B
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Het nou bietjie rond gelees, mens kan werk op 10mm lift vir elke 25mm wat jy die shackle langer maak. So op mates met n 63mm verskil gaan ek so 20 tot 30mm lift kry. Dit sal ek dan vir voor gebruik en agter sal ek die shackles 190mm maak wat my so 40mm lift gaan gee. Klink vir my goed.
Jou trokkie lyk heel windgat!
Re: Suspension Lift
Don't make the shackles too long, else your lux will handle like a boat!
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
No i will not go longer than 190mm in the rear and 140mm for the front
Re: Suspension Lift
I think the old ones were very tired.ismail wrote:Mud dog, 110mm with the OME, thats quite abit.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Ek het gou staal pryse gaan kry. Sal 40x8mm flat bar mild steel reg wees vir die shackles? N$261 vir 6mete lengte.
Re: Suspension Lift
Is mild steel strong enough?? Won't it flex too much?
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Re: Suspension Lift
Will support it in the middle with a "rib".....dont know thats why im asking you clever people. I think it will work that 8mm is lekker fris yster
Re: Suspension Lift
I would rather buy a quality manufacturer product... then at least u know its up to the job!
