Packing system from recycled material
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Started this afternoon building the frame for what will eventually be a packing system for my Hilux.
I am using zincalume angles to build the outside frame. We received them inside packaging to make the structure strong and protect the parts inside from possible crush damage.
I'll be getting the medium duty 1.0m sliders, and you will notice a third brace, which will be the place for lidded bins. Sometimes you need a place for stuff you do not want all the time, and having it packed way deep is not much of a problem because you might only need it when in the camp. I've managed to complete the top and bottom part of the frame in approx 3 hours with help from my wife Nadine and my son Elgar. As you can see Elgar was busy with quality control.
Laying it all out:
During the process of riveting:
Fitting finally to see it in relation with the bak itself:
I'll be cladding the whole frame in 6mm laminated ply. Pictures will follow:
Laying it all out:
Know what you don't know.
- Town: Springs
Re: Packing system from recycled material
Baie dankie Chris.ChrisF wrote:Mooi.
Lekker Heinrich
Gaan jy 'n raamwerk bo-op bou vir jou yskas?
- Town: Springs
Dankie Mark.
Yskas is tans in die sleepwa. Wat ek oorweeg is nog 'n ekstra yskas wat ek dan op drop slides sal sit op die kas.
OK
Ek vra net want die yskas is 'n redelike belangrike deel van jou avontuur! Dis baie keer beter om jou dige te beplan 'om' jou yskas
- Town: Springs
Oh yes!!OOOOMS wrote:OK
Ek het my sleepwa aangeskaf met die vrieskas binne die wa, en hy werk baie mooi daar binne, hou alles mooi en koud vir lekker lank, en hy is lekker groot.
Maybe 'n 45liter vir agter in die Hilux.
Yskaste vat baie plek!!!
- Town: Springs
Hulle doen, en hulle is baie nodig ook.OOOOMS wrote:Yskaste vat baie plek!!!
- Town: Springs
My broer kuier hier van Bethlehem, toe span ek hom sommer in om vanaand te help om die raam finaal aanmekaar te sit.
Nou kort ons nog net die ply aan die buitekant en die binneste segment. Dan is dit tyd om laaie te bou.
Elgar was weer byderhand om toesig te hou dat ons nie fokus verloor nie.
En nou is die raam in plek agter op die bak.
Die raam is reeds besonders stewig, en sal beslis nog stewiger wees sodra die ply aan die raam vasgeheg word. Dinge begin nogal besonders goed vorm aanneem.
Lyk netjies Heinrich
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
En dit kos next to nothing!OOOOMS wrote:Lyk netjies Heinrich
Heinrich wat weeg my raam nou? Is hy nou al klaar?
- Town: Springs
Nee jong Mark, ongelukkig het ek gaan kyk hoe lyk Maputo. Is vanaand eers terug.
Ek sal hom bietjie weeg, maar dis sekerlik minder as 10kg op die punt. Ek kan hom maklik optel en insit.
Uys, jy is reg. Koste tot nou was die elektrisiteit vir die boor, en R32 vir die rivets en wassers.
- Town: Springs
Ek het netnou die sliders gaan aanskaf vir die laaie.
- Paul Grobler
- Town: KOEDOESKOP
- Vehicle: '12 79 Land Cruiser Pick up 4.2 D
- Real Name: Paul
Heinrich Dit lyk Great so ver waar kan ons bestellings plaas?
5de Rat brights
- Town: Springs
Paul, weet nou nie of jy gaan dink dit lyk heeltemal so great wanneer ek klaar is nie.
Maar ek sal altyd handjie bysit om van die materiaal te voorsien wanneer ek weer kan kry.
Soos julle seker al gesien het, het ek 'n canopy wat kan oopmaak aan die linkerkant. Ek gaan 'n boonste deel by op die hoofkas bou wat teen hierdie kant deurtjie is, en dan kan ek daardie as so kan toegang kassie gebruik. Weet nog nie wat ek daar sal inpak nie. My plan is om hierdie boonste kas op skaniere te bou sodat hy platvou wanneer ek die laaie wil verwyder en dan kom die hele kontrepsie in 1 uit die bakkie. maak dit sin?
- Town: Springs
Het so bietjie gewerk. Hier is so paar foto's terwyl ons gewerk het.
Dis waar ons nou is?
- Town: Springs
Some more progress.
Ek het die laai wat links ingesit word voltooi, maar sal wag tot volgende naweek vir die volgende laai. Die hout wat opgesit word om die ding toe te maak en te voltooi is reeds gesny, en die gate is geboor.
- Town: Springs
Dit is basies voltooi.
Sal vir julle nou die foto's wys sodra dit alles netjies agter in die plek is..
- Town: Springs
Baie naby aan klaar.
Nog net 'n protective strip, handvatsels & slotte aan die laaie.
Alles net vir so paar sente minder as R800-00.
Die items wat die meeste bygedra het tot die koste was natuurlik die sliders, en die mat. Ons het besluit om matte in te sit wat langer sal hou wanneer hulle blootgestel word aan harde gebruik.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Ek dink jy het n fantastiese job gedoen, well done
- Town: Springs
Baie dankie Trevor. Dit is nou die laaste stappe om afronding te voltooi. En dan is ek klaar.
..... wel klaar totdat ek begin om die ekstra pakplek by te sit.
- Town: Springs
Ek het vandag die handvatsels aangesit, en twee 6mm turnbuckles ingesit om hom mooi in plek te hou.
Is baie verras deur hoe stewig die turnbuckles hom in plek hou. Ek wonder of ek 'n derde en vierde turnbuckle moet insit.
Trevor, hulle is baie sterk, ek hou my yskas in plek met een aan elke kant, geen probleemIs baie verras deur hoe stewig die turnbuckles hom in plek hou. Ek wonder of ek 'n derde en vierde turnbuckle moet insit
- Town: Durbanville
- Vehicle: 2009 Toyota Hilux DC 3.0 D -4D 4X4
- Real Name: Ben
- Club VHF Licence: HC 136
Ek wil weet hoe heg julle jul pak stelsels aan die bak vas. Is dit met bout en moer deur die bakvloer, met turnbuckels aan die bestaande hegstukke in die hoeke van die bak of watter metode ookal? Ek weet die Prado's en Cruisers sal die bestaande sitplek moere gebruik, maar die bakkies wat doen julle.
Sal julle insette waardeer,
Groete,
Groete,
- Town: Springs
Ek het eye bolts vasgebout op die wheel arch, so naby as moontlik aan die kant van die bak, en aan die buitekant van die bak in die wheel arch het ek die grootste wassers gebruik wat ek kon met lock nuts.
Dan is die turnbuckle aan hierdie eye bolt vas, en 'n eye bolt aan die sterkste punt van die laaie se raam.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
:wth: Ek het niks gese nie :roll: :roll:OOOOMS wrote:Trevor, hulle is baie sterk, ek hou my yskas in plek met een aan elke kant, geen probleemIs baie verras deur hoe stewig die turnbuckles hom in plek hou. Ek wonder of ek 'n derde en vierde turnbuckle moet insit
- Town: Springs
Gisteraand het ek begin om die beskermingstrook op te sit, maar ongelukkig is my rivets 2.5mm te kort gewees. SO, vandag is dit terug na die hardewarewinkel.
Ek het wel nog so paar matte geplak. En al die gate vir die strook is geboor, so dit is letterlik net 'n geval van die insit van die twaalf rivets vanaand.
Natuurlik het ek nou gedink dit is ook goeie idee om 'n strook bo aan elke laai te sit om hom ook te beskerm. Nooit klaar nie.
.....Trevor......bedoel Traveler....Ek het niks gese nie
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Is bly om te sien ek is darem in jou gedagtes Mark
- Town: Springs
Ek het aflewering geneem van 'n nuwe yskas/vrieskas combo van Snomaster. En omdat ek die sleepwa verkoop het moes ek toe nou ander plan maak.
En het so hele paar ure die naweek spandeer om hom te maak pas. Ek weet dat die elastic straps is slegte idee, maar dit is net om hom vas te hou. Ek gaan hom met deeglike straps vasmaak (nie oor die deksel nie).
..... ek het eers die opsie oorweeg om die bokant van die Snomaster af te sny.
Netjies Mr H, een van die dae as jou alu canopy klaar is gaan dit wiel lyk
Wat se Mrs N and die ?
- Town: Springs
Thanks Mark.
Die resultate is nogal heel indrukwekkend. Ek is NOU eers baie opgewonde om die alu projek aan die gang te kry. Ek is gelukkig genoeg 'n welder van alu te gekry het so 15min van die huis af.
Heinrich dit lyk mooi.
Wees net waaksaam in warm weer - jy het goeie ventilasie nodig vir daai yskas, en die boonste blad lyk of dit "te goed" pas ...
- Town: Springs
Thanks Chris, dit is waarom ek die laai so "laag" afgesny het. Dit gee hom lekker baie ventilasie. Ek het ok die kas oopgemaak aan die kante sodat hy kan "asemhaal". Ek het seker so 2 ure saam my pa gesit en redeneer Saterdagaand oor hoe om te sny, en watter kant om hom om in te sit. Wat nogal nice is van die spesifieke snomaster, hy gee vir jou die temp lesing op elkeen van die twee binneste houers.
Baie dankie vir die kompliment.
- kfxnando
- Town: Germiston
- Real Name: Fernando
very neat!!
sorry for the offtopic, slight!!
is that a Materia in the back round???
That's 10 demerits then...Traveler wrote:Fernando, yes it is.
It's one of the strangest looking vehicles on the road... a half loaf of bread!
- Town: Springs
It is the coolest set of wheels on the road. I wish the Hilux had 75% of the space inside its cab.
And it is a Toyota..... So how can you demerit me?? I am entering an official complaint....
It is the most practical car you can even think of, space in excess and extremely fuel efficient.
You also get this as the Toyota bB in Japan or die Subaru Dex.
- kfxnando
- Town: Germiston
Yep huge amounts of space
The reason why it cought my eye is that we also have one at home
Actualy the wifes car!!
All very true comfortable light on fuel
Pleasure to drive
And not to mention the handling, try pushing it hard into corners
Handles like a go-cart
What an amazing car!!
Self always wanted one, so we got the wife one!!
Hehehehe
Have been told that some where in the east one even gets them in AWD
Pleasure to drive
Hehehehe
- Town: Springs
Hehehehe
Yip, you do get an AWD version.
Demerits retracked... but remember... I'm watching you...
- kfxnando
- Town: Germiston
wish we had a AWD one!!
from what I hear there are none of those available in SA!!
however there is a turbo version is SA!!
think there were 200 or so turbo models available!!!! :gamer:
have you seen some of the accessories available for those even a bull bar!!!
- kfxnando
- Town: Germiston
me again!!
link to 4WD Materia
http://www.auto-x-catalogue.com/english ... 5-eco-4wd/" onclick="window.open(this.href);return false;
looks the same though!!
link to 4WD Materia
Slightly off-topic here.....
Watch closely....what is your daily ride, Mr H?Mr_B wrote:Demerits retracked... but remember... I'm watching you...
Who's Mr H? Heinrich?
He's the fella sitting between Mr. G & Mr. J... savvy?
You on the biscuit FD :!: Yip B, it's 'H' for HeinrichMr_B wrote:Who's Mr H? Heinrich?
