Electric fan setup on Spitronics
- Vehicle: Ry die vyand
- Real Name: Reynard
- Club VHF Licence: B01
Hi guys, my truck is running but I've got this one problem I'm not getting sorted out.
I've setup the fan to startup on the Spitonics at 86c and to shutdown at 79c. This is for the water temp. But for the life of me, it is not working. :wth:
I've tried it on both Outputs but nothing. The fan works if I bridge the relay, the relay is working that was tested and we even used another emu. No go.
Can someone please advice me on what to do.
Elands4x4
Elands4x4
Re: Electric fan setup on Spitronics
Hoeveel temp probes het jy aan die water kant en hoeveel aan die lug kant?
Niks aan die lug kant nie. Daar is 2 op die water, een vir die cluster en een vir die EMU. Die Emu lees die temp 100% maar die relay skop nie in nie.
Elands4x4
Elands4x4
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Reynard watter Spitronics system gebruik jy wil gou sy diagram aflaai dalk kan ek help.
Advance vir die Lexus.
Elands4x4
Elands4x4
- Gertc
vraag. Jou rely se coil. het jy eenkant ge aard en die anderkant gaan na jou emu toe?
Ja, geaard. Geel (Output 1) of groen (Output 2) draad na emu en ander draad na fan. As ek die replay bridge, werk die fan 100%
Elands4x4
Elands4x4
- Gertc
Ek sou hom soos volg koppel.
Gebruik `n 30 Amp 12V rely. 12V vanaf Positief van battery deur `n 25Amp fuse na been 87 van rely. been 30 na fan.
Been 85 van rele na emu(geel of groen draad). Been 86 na Positief van battery of ignition.
Thanks Gert gaan dit so probeer en jou laat weet.
Elands4x4
Elands4x4
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Reynard,
Give Peet a call. AFAIK he configures the general purpose outputs for the main 2 relays. So sadly you'll have to find another spot for a temperature sensor....
- Gertc
Reynard kon jy jou fan reg kry?
Gert gistrand was ons af aand. sal vanmiddag kyk of ons regkom.
Elands4x4
Elands4x4
