Hawkins DC/AC 1000w Inverter
JohanM
Town: Meyerton
Vehicle: Prado 120 4.0 V6
Club VHF Licence: HC126
Post by JohanM »
Guys does anybody know if the Hawkins DC/AC Inverter is a robust and reliable unit to mount in my SFA for overlanding to keep the Camera, laptop & cellphone charged as and when needed....
I have some of the specs from their website, and in my (limited) knowledge it does seem like a good unit to get.
DPI 12100
Output:
Power: 1000 watt
Start-up: 2000 watt
Voltage: 230VAC
Regulation: 8% (rms)
Frequency: 50% (1%)
Waveform: Square
Input:
Nominal Voltage: 12V
Low BatteryAlarm: 10.7V
High Voltage Alarm: 16V
Efficiency: 90%
Protection:
Over Teperature >65 deg. centigrade
Short crcuit
Overload
Dimensions: 152 x 70 x 275
Weight: 2.1 kg
Re: Hawkins DC/AC 1000w Inverter
Post by OOOOMS »
Hawkins, is one of the best :thumbup: Yes will be sufficient for your application.
JohanM
Town: Meyerton
Post by JohanM »
OOOOMS wrote:Hawkins, is one of the best :thumbup: Yes will be sufficient for your application.
Then I will make the effort of getting one and fitting it to my truck as one of the last modifications before I head off on a 4 week Solo Vehicle Safari.... :thumbup: :thumbup:
Niel
Real Name: Niel
Post by Niel »
Johan, sien in die SA4X4 dat hulle die 1000w inverter verkoop vir R 1596 (DPI 12100) en die prys sluit ook dan die Auto 7, 5 stage automatiese 12v, 7 amp laaier in. Die prys sluit versending na poskantoor naaste aan jou in. Hoop dit help. BL 109 Feb uitgawe.
Mark is dit n goeie prys/deal?
Post by OOOOMS »
Niel wrote:Johan, sien in die SA4X4 dat hulle die 1000w inverter verkoop vir R 1596 (DPI 12100) en die prys sluit ook dan die Auto 7, 5 stage automatiese 12v, 7 amp laaier in. Die prys sluit versending na poskantoor naaste aan jou in. Hoop dit help. BL 109 Feb uitgawe.
Ja beslis, Hawkins is een van die beste
Goeie deal :thumbup:
Niel
Real Name: Niel
Post by Niel »
Ek weet hulle chargers is vrek duur maar hulle se ook dat jy betaal vir gehalte.
Thanks Mark
Post by OOOOMS »
Dit is 'n goeie prys :thumbup:
JohanM
Town: Meyerton
Post by JohanM »
Ek het my inverter gekry asook die charger saam. Moet se ek is baie impressed met Hawkins se diens asook die courier mpy wat die delivery gedoen het....
Ek gaan die week my Deep cycle battery charge met die nuwe charger en kyk hoe hy werk!!! :thumbup: :thumbup:
Hier is die charger se specs:
ABC1206
Input Voltage: 200 - 240VAC
Input Frequency: 47 - 53 Hz
Power Consumption: 59 watt
Efficiency: 87%
Equalising Voltage: 14.6VDC
Float Voltage: 13.7 VDC
Charge Current: 6 Amp
Dimensions: 155 x 47 x 70
Weight: 0.5 kg
En hy kom met 'n 2 jaar waarborg... :thumbup: :thumbup:
Dis hoe hy lyk...
EK kan defnitief daai special wat hulle het aanbeveel...
Post by OOOOMS »
Weight: 0.5 kg
Is dit reg? Electronics.....?
JohanM
Town: Meyerton
Post by JohanM »
OOOOMS wrote:
Weight: 0.5 kg
Mark ja hy is lekker kompak.
Hier is die info van hulle website af...
The ABC are three stage fully automatic microprocessor controlled battery chargers that can be left connected to your batteries indefinitely. These chargers are especially useful in stand-by applications and compliment our range of 12VDC to 220VAC inverters.
Post by OOOOMS »
En die ABC se prys?
JohanM
Town: Meyerton
Post by JohanM »
OOOOMS wrote:En die ABC se prys?
Mark ek dink hulle is nou so vanaf R 780-00
