Heating problems again!
NardusJVR
Town: Louis Trichardt
Vehicle: hilux 2.8TD
Real Name: Nardus
Post by NardusJVR »
Jip.... Me again
After several repairs / replacements on the enjin and my 2.8 td hilux stil have heating problems!
Right here is what i've done!
Serviced the injectors
Serviced disel pump
Repaced head (new)
Presure test head and block
Repaired radiator (only on second atempt found the blockage)
Thermostat checked all okay
Visco check and all is fine
It doesn't use water, but !when it gets a slight incline the heat gage goes up! above halfway mark!
Plein afrikaars eks al gatvol n n diesel!
Wat kan dit nog wees!
HELP!
sugestions on enjin replacements also welcome! can spend about R20 000
Lane
Town: Port Shepstone - KZN
Vehicle: 97 Hilux 2.4 D/C Raider
Real Name: Lane
Re: Heating problems again!
Post by Lane »
i used to have a 96 model 2.8d (not turbo) s/c a couple of years ago and we started getting overheating problems, after many hours of frustration we eventually changed the thermostat housing (aluminium housing had corroded) and cap. we also drilled about a 4mm hole in the thermostat as a precaution for air locks etc. the van was perfect after that. :D: hope this helps. :crazy:
JohanM
Town: Meyerton
Vehicle: Prado 120 4.0 V6
Club VHF Licence: HC126
Post by JohanM »
NJVR wrote:After several repairs / replacements on the enjin and my 2.8 tdhilux = problems
Nardus jy antwoord jouself eintlik klaar....
as ek jy is sal ek die Turbo afhaal en die enjin standaard maak dan behoort die warm kry probleme op n einde te wees......
Dit is algemeen bekend dat die 2.8TD Hilux sowel as die 3.0 TD enjins was nie betroubaar met betrekking tot oorverhitting nie.
Die turbo is heelmoontlik jou probleem omdat die turbo maklik tot oor 'n 1000°C kan word wanneer jy opdraende ry..
Selfs die nuwe D4D's & KZTE's het n baie hoë EGT op die turbo. Dus is dit hoekom die D4D's met intercoolers uitkom op die 3.0's...... Dit keer dat die Charge air temperature wat terug in die enjin ingaan te warm is, want dit is wat dan begin aangee dat die enjin warm word...
Dink so daaraan, die gewone enjin se intake temperature is enige iets van ambient temperatuur tot en met so +/- 65°C afhangende van hoe warm dit onder die bonnet is.,.....
Jou TD enjin se intake is heelmoontlik nader aan 80°C + en daai 20 grade maak die verskil dat jou enjin nie normaal kan loop as hy werk teen n bult nie.
Ook jou cooling system was nooit gebou om daai tipe hitte te hanteer nie, so as jy miskien n intercooler opsit sal dit die probleem kan "mask" of heeltemal oplos, maar ek is nie bereid om te se dit sal defnitief so doen nie...
Ook sal ek die heat sender unit in die blok vervang en ook die Heatgauge in die cluster net om seker te maak dat alles wel reg is....
Ek het al n geval gehad waar 'n 2.7TD Nissan dieselfde gedoen het... Groot geld gespandeer om die voertuig vir die klient te fix.......Op die ou einde was die gauge op die cluster al die tyd verkeerd..... R 700 later en die "overheating" is solved, nadat hy meer as 20K gespend het om dit te cure...
So toets die water temperatuur by die inlet & oulet hoses op die radiator en kyk of hy actually warmer is of nie.
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
I know in the 80's the guys with the Kombi's with 3l Ford V6's in them also drilled a hole in the thermostat to alleviate this problem :thumbup: :thumbup:
RooiLux
Town: Pretoria-Mayville
Vehicle: 1992 2.2-EFI Hilux 4x4 with Maus conversion,freeflow,Rear Electric Locker'2005 BMW 320i, 2015 Hilux 3d4d dc 4x4
Real Name: Marius
Post by RooiLux »
NJVR wrote:Jip.... Me again
Serviced disel pump
Repaced head (new)
HELP!
Kan moontlik die termostaat wees of die termostaat seeltjie wees,as dit onlags vervang was of vandat die probleme begin het kyk net of hy reg asook die seel reg ingesit is.
Andres kyk by die flange agter by die head of hy nie dalk water lek daar nie,dit is watr my probleem was en dis nou uitgesorteer.
Hoop dit help
NardusJVR
Real Name: Nardus
Post by NardusJVR »
so lyk my vanaand is dit ek en die boormatjien ! begin ma by die klein dingetjies!
Thanx vi die raad sal lat weet!
Wat ek nie genoem het nie is dat die pomp baie oopgestel was en hy hopeloos teveel diesel gekry het! so 4.5 km op die laaste tenk is nie n grap nie! kan dit wees dat hy te veel diesel kry en dit nie gou genoeg kan ontbrand nie! het die pomp lat toeër stel, sal dit werk?
dustbuster
Town: Richards Bay
Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
Real Name: Dean
Post by dustbuster »
Have you checked the water pump maybe corroded and not getting enough water through the system
Gunta
Real Name: Mark
Post by Gunta »
Why dont you buy a D4D motor from Japan Auto for 18k complete with turbo, intercooler, starter and everything.
Thabogrobler
Club VHF Licence: x223
Post by Thabogrobler »
NJVR wrote:so lyk my vanaand is dit ek en die boormatjien ! begin ma by die klein dingetjies!
Hier kom ons nou by die goedjies wat kan pla!
Ek hoop die 'oop' en 'toe' stel van die pomp is nie sommer maar net so-so gedoen nie! Dit moet op 'n Dyno gedoen word met 'n ordentlike EGT gauge op. Te veel diesel sal hoer temperature tot gevolg he.
Is dit nie bietjie tyd vir 'n intercooler nie? EK het al 'n klompie 2.8td's gesien met intercoolers op en hul eienaars was baie tevrede met die resultate.
Of 'n ander opsie is ook om dalk meer lug in die enjin ruim te kry, dalk dmv 'n scoop(kies tog net een wat goed lyk!).
Wat van 'n beter radiator? Dalk 'n KZ-te ene? Ek het erens gehoor van die fabriek wat dit maak waar jy net so oor R1000 vir 'n Kz radiator betaal(AS dit waar is)
Geelslak
Vehicle: 2.8 SC SFA 4x4
Real Name: Jan
Post by Geelslak »
Nardus, ek het n 2.8Td ,wil dit vir niks verruil nie ,het sy warm word gewen. Skakel my by 0798922353. Jan
mafufunyana
Town: Vaal Traingle
Vehicle: '95 SFA Hilux DC, 7MGE, 33" bf muds, rear locker, longrange tanks, outback roofracks, arb bullbar, ipf lights, warn winch, old man emu suspension, dual battery, just solar's solar panels
Real Name: Dawie
Post by mafufunyana »
Nardus, ek het `n '97 2.8 diesel d/c ekt ook probleme gekry met di kar wat warm word. na baie frustrasie en geld het ons agter gekom die timing cover casing(die casing waarop die water pomp vasgeboud word uitgewear was. die gap tussen die impellers en die casing was om en by 6mm waar omtrent 2 mm moet wees. dit beteken die water het nie gesirkileer nie. ek sal se wat jou bakkie na n radiator plek toe dat hulle jo sisteem toets en kyk of die temp van die boonste en onderste pype dieselfde is. hulle sal jou ook kan se as dit jou thermostat is.
Sterkte!
NardusJVR
Real Name: Nardus
Post by NardusJVR »
Dink julle die bumper wat ek gebou het laat genoeg lug deur na die "Radiator"
Borntofish
Vehicle: Hilux 86
Real Name: Werner
Post by Borntofish »
Ek het vir my bakkie 'n 4-core radiator laat insit vir presies dieselfde problem. Na dit het ek nooit weer overheating issues gehad nie.
NardusJVR
Real Name: Nardus
Post by NardusJVR »
thanx werner1 het ook gedink om die radiator the vervang!!
wat het dit gekos
Borntofish
Vehicle: Hilux 86
Real Name: Werner
sjoe, dit was so drie jaar terug toe het ek R1100 betaal vir 'n nuwe core. Hulle het die bestaande tanks behou. Ek het dit by Silverton gedoen.
JohanM
Town: Meyerton
Post by JohanM »
NardusJVR wrote:Dink julle die bumper wat ek gebou het laat genoeg lug deur na die "Radiator"
As ek na daai foto kyk van jou Hilux met die Bullbar op sien ek nie juis baie plek waar die wind van voor jou radiator kan koud waai nie!!!! So dit is ook deel van jou probleem.
As die enigste plek waar jou radiator lug kry tussen die spots is, kan ek nou vir jou se dit is n groot faktor van jou overheating.
Toets die water temp so in die ry voor jy die bumper afhaal op die inlet en outlet pyp van die radiator en doen dit dan weer sodra jy die bumper afgehaal het. Jy mag dalk verbaas wees oor die verskil in lesings wat jy gaan kry.
NardusJVR
Real Name: Nardus
Post by NardusJVR »
gan die naweek die toets doen ek hoop dit maak n verskil!
JohanM
Town: Meyerton
Post by JohanM »
NardusJVR wrote:gan die naweek die toets doen ek hoop dit maak n verskil!
Dit is reg so Nardus!!! Kry vir jou 2x water gauges en sit hulle in die pype as jy kan, anders kry vir jou 2x ordentlike digital multimeters wat die temperatuur vir jou kan lees, dan sit jy sy probe in die water pyp bo en onder en ry en kyk wat is die lesings wat jy kry.
Moet nie die heatgauge alleen glo nie.
If you take it to Silverton, they should be able to do this test in less than a minute with a laser thermometer. More than likely they won't even charge you either. ;-)
NardusJVR
Real Name: Nardus
Post by NardusJVR »
thanx andy! Only one problem, We are is LOUIS TREURIG ! hier betaal jy vi alles en die kaans dat hul die toets kan doen is seke 20%. Maar gan defnetief try!
GeorgeJvR
Post by GeorgeJvR »
Turbo Het blyk baar 2.0 gestoot inplaas van 0.4
NJVR se van is oppad terug van Polokwane af
Hoop hy's nou reg boeta!
As my klein ding gekom het moet ons daai kort stokkies loop oli!
Kom wat wil ek bly 'n Bul!
NardusJVR
Real Name: Nardus
Post by NardusJVR »
Klink vi my reg! het lank laas bietjie 4x4 gery! jip dit wil voorkom of my wa nou reg is!
