Hi everyone
I seem to have this little gremlin in my dizi and can't pin point the dam thing ,it's a 4y from Gemini She usaly starts and runs without a problem sometimes for a few minutes sometimes the whole day all depends how she feels has anyone had the same problem or know of what it could be ?
No spark on 4y electronic ignition sometimes
Re: No spark on 4y electronic ignition sometimes
Check the air gap between the magnetic pickup and trigger wheel tooth... if the gap is just a little too big no pulse will be picked up!
The gap should be 0.2mm! The ching chong elec-dizi shafts have a horrible habit of bending, so spin the shaft by hand, checking that there is no play, and that the gap between the trigger wheel teeth and pickup remain constant. It is also possible that the coil is on it's way out!
Honestly I'd replace it with an original Toyota electronic dizi asap, cause the ching chong ones do give hassles!
Ditto.....Mr_B wrote:Check the air gap between the magnetic pickup and trigger wheel tooth... if the gap is just a little too big no pulse will be picked up!
- Town: Pretoria-Mayville
- Vehicle: 1992 2.2-EFI Hilux 4x4 with Maus conversion,freeflow,Rear Electric Locker'2005 BMW 320i, 2015 Hilux 3d4d dc 4x4
- Real Name: Marius
Ditto x2CasKru wrote:Ditto.....Mr_B wrote:Check the air gap between the magnetic pickup and trigger wheel tooth... if the gap is just a little too big no pulse will be picked up!
If you still dont come right give Louis a call as he builds/modifies the dizzy's and has a wealth of knowledge
