heating system in the CAB
- Musselcracker
- Vehicle: 1989 SFA D/C
Hi guys
I tried searching the forum and can't find a thread to help fix my heater in the car! Man oh man it was cold this morning, but feet felt like the were gonna freeze off on the way to work this morning! I know i only live in Durban, but you must remember that we are not use to anything under 10 degrees!!
Anyways the long and short of it... the heater dial on the dash (89 SFA) does not move across into the red... the furtherst i can push it is in between hot and cold! I have open the bonnet and can see the little "switch" thing is obviously stuck.... tried carb cleaner and WD 40 not helping!
Can you get new ones... can you rehab this one! What are guys thoughts and experiences on this??
CHRIS "Cold toes"!
CHRIS "Cold toes"!
- Musselcracker
Re: heating system in the CAB
Here is the culprit!!
- IMG_0361.jpg (20.87 KiB) Viewed 5103 times
- IMG_0360.jpg (22.63 KiB) Viewed 5103 times
- Borntofish
- Vehicle: Hilux 86
- Real Name: Werner
I have bought a Taxi one (HIACE) from Gemini a couple of years back and it is working like a charm.
- Musselcracker
Great... did you have to do any mods or did it bolt right on??
Part number would be great?
- dustbuster
- Town: Richards Bay
- Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
- Real Name: Dean
when I stripped my hilux saw mine was buggerd as well, also the cable for the heater dial had snaped
- Musselcracker
OKay.... so what are your plans with yours?
I took off that protective end white cap and was very very generous with the WD 40 ... sommer outside in the work parking lot!!
According to FD's thread (which I eventually) tracked down his came right!!
I am struggling to find a par number
- dustbuster
- Real Name: Dean
Have not thought that far, think mine is totally trashed all rusted inside and blocked will try get a pic for you tonight.
Think it is the valve assembly for the heater water check here
http://www.toyodiy.com/parts/p_E_199009 ... _8716.html" onclick="window.open(this.href);return false;
- Musselcracker
thats him 87240
am i right??
am i right??
- Musselcracker
Hang on mine is a 89 what is yours?
- dustbuster
- Real Name: Dean
91 but should be the same, part numer is 87240-8115 phoned toyota here R886,80 exc vat. :evil: :evil: think I will put on an extra pair of socks
- Musselcracker
sweet heavens!!! thanks for the part number
Mine has since jammed up again. I have bought a new one but have not yet fitted it. Keep meaning to...
(But if it's too cold then I just take another Hilux with one that is actually still working...)
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
IIRC a citi golf heater valve can be made to fit...
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
I have the golf one in mine at the moment but it works "backwards" compared to the toy one.Toybox wrote:IIRC a citi golf heater valve can be made to fit...
so I have to get out and open the bonnett and manually work the lever - I have sourced a good 2nd hand one and plan to fit that soon.
They jam up when there is not enough antifreeze in the system and the heater is not used regularly like at the coast
- Club VHF Licence: X93-
Hi Musselcracker
I have exactly the same one like yours.I bought mine from Gemini in J.H.B for R550.00 part nr T8724089115 which was an genuine Toyota part. My bakkie is also a 1989 model.
I work 4 bloks from Gemini,if you want me to get one for you i will do it with a pleasure for you.Dont know if they have got stock now.Last time they have to order it for me.You can phone them on 011 334 1417
- Town: Port alfred
- Vehicle: 2008 Fortuner V6 4x4
- Real Name: Daryl
I cleaned mine up soaking it in brake fluid for 30 minutes, and then getting a good pair of pliers and un-jammed it, got all the junk and corrosion out. been working fine since then, around 2 years now. Just remember to wash it well and dry it before installing it again.
- Borntofish
- Vehicle: Hilux 86
- Real Name: Werner
Here is the Hiace one. I cannot remember the price as I bought it longer than a year ago. It was definitely not over R300.00, but I can be wrong......
- Musselcracker
Thanks guys
Lollie I think I may take you up on that offer.... I will PM you!
Another freezing morning in traffic at a frosty 12 degrees! This coupled with the puddle at the drivers side foot well due to all the rain last week, means the toes are getting frost bite as it is like a slush puppy down there!
Funny my mate commented on the way to work... "You have got to love the tropics... when you have to open the window to let the warm air in!!"
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
sheesh - I left this morning for work at a "fresh" 1 deg!!Musselcracker wrote:Thanks guys
- Musselcracker
hahaha ya its tough here in the tropics!
Here is a question... Is there a seperate pump that pumps the water into the heater sytem? currently the there is no water running into that pipe up to the valve? well not that i can feel? I have heard that you have to bleed it to get the air out that system... so will see what happens when i take the valve out tonight i will try bleed all the air out!
Anyone got a simple explanation on the system works, for me to understand better
- Toybox
- Vehicle: Hilex
The system uses exactly the same pump that circulates the water around the engine and through the radiator. The heater valve only allows hot water to circulate through the in cab heater, so although there is water in the pipe to the valve there won't be any circulation until the valve is opened.
Bleeding the system is as simple as setting the in dash control to hot, removing the radiator cap and allowing all the bubbles to surface through the cap.
- Musselcracker
Perfect thanks
although I can't feel any water in that pipe running into the valve... which i am hoping the bleeding will help
- Toybox
- Vehicle: Hilex
Well unless the valve is open there wont be any circulation through the heater. It the hoses will be full of water but not going anywhere if that makes any sense.
- Musselcracker
Okay i had the heater valve out last night!! Here are the chain of events:
1: Spray with Q20
2: Spray with Carb cleaner
3: Soak in Brake Fluid for 2 hours over supper
4. More Q20 and Carb Cleaner
5: Hammer
6: Long nose pliers
7: Bigger Hammer
8: DRAIN CLEANER
9: More hamme
Eventually gave up that little thing is not moving for nothing! PROPER PROPER stuck!!!!
Pics to follow
1: Spray with Q20
5: Hammer
6: Long nose pliers
7: Bigger Hammer
8: DRAIN CLEANER
9: More hamme
Pics to follow
- Musselcracker
Here is the rusty culprit of a frustrating tuesday night
- IMG_0373.jpg (15.1 KiB) Viewed 4990 times
- IMG_0371.jpg (13.17 KiB) Viewed 4990 times
- IMG_0370.jpg (18.26 KiB) Viewed 4990 times
- Musselcracker
Okay So i found a couple of Toyota Strippers!! Durban guys can pm me for the place... or i will post it somewhere!!
I managed to find a venture heater valve which had the potential to work or be modified!!!
pics to follow!!
Please give me your thoughts and advice!
pics to follow!!
- Musselcracker
1st price will to be to get the pipes and valve out and place inside my current braket! I can see hammer and chisel work in my future!
2nd would be to mount as is and repipe it!
- IMG_0381.jpg (17.66 KiB) Viewed 4972 times
- IMG_0380.jpg (20.15 KiB) Viewed 4972 times
- SideKick
- Vehicle: Toyota Hilux '89 2.2 (4Y) EFI D/C 4x4, Mikem Suspension, PowerFlow Exhaust, BroSpeed Branch, 31" M/T, Long Range Fuel Tank, Front Diff-Lock
- Real Name: Stephan
- Club VHF Licence: X108
Hi Guys
That same valve of mine gave problems. Changing on the dash from hot to cold and back didn't move the valve. I pulled the valve out halfway with my hand so that I can at least get halfway warm air when I turn the heater on. Very weird. Even though the valve stays on halfway open, putting it back to cold on the dash turns off the warm air . . .
But I think that the cable is snapped. How difficult is it to replace that cable?
Stress: The confusion created when one's mind overrides the body's desire to choke the living $H!t out of some asshole that desperately deserves it!
- Musselcracker
That little blue cable is often the culprit as well ..... had the same hassle on my work bakkie ... cable snapped. Just manually opened the valve fully and leave it there. This means that there is always hot water circulating through the heater radiator ... (probably better for it), the heater control operated two cables ... that blue one and another that opens and shuts a flap in the air duct. Mine shuts off completely so no hot air comes through when in the 'cold' position. Works just fine for me. So all you need to do is bypass the valve and you'll have an operational heater.
- Musselcracker
Thanks guys for the help!
I managed to modifiy the venture heater valve from the scrap yard to fit into my old bracket! I just had to tap the brass fold over bits that keep the valve secured to the bracket! Put the new one in and cut the brass things to fit the bracket and bent them back into place!
Just a longer heater pipe to ensure there were no kinks and hey it works! Saved me from frostbite on Saturday after fishing on the beach down in Park Rynie in the wind and rain all day! (caught nothing)
Only thing is now the heat adjuster slides great all the way over to the red but only half way into the blue side! Any thoughts?
If it doesn't go all the way over then the air duct vent won't close off. The Lux valve had a spring mechanism at the valve to allow for further travel once the valve was closed ... does the Venture one have this also? Otherwise you could extend the control 'arm' of the valve which would give the cable more travel.
- Musselcracker
Yeah the actual Valve looks identical andy!
I am just not sure it has the same amount of movement as the Hilux has! If I can remember the venture had a smaller dash board unit that did not allow for as a big a movement as the lux!
I am tempted to take off the white end protector cap and (you can see it clearly in the photo of my lux original vavle) and see if that helps! The ventures did not come with a cap at all!
If you're sure that it's the valve that's restricting the movement, then it's quite possible that the Venture unit has less travel. Should''t really be too much of an issue as long as the vent flap in the air duct is opening to allow air in from the heater radiator.
- Musselcracker
Just one of those annoying things!
I know we gonna go fishing and someone will climb in and try force that slide all the way across and probably break it!!
Just read this thread now, my original valve also siezed. After trying the VW valve route, I found a Corolla valve that worked perfectly(with minor tweaks). I'll post a pic for reference...
