sfa brake conversion/upgrade?
- Town: wellington
- Vehicle: 81 hilux 350,80 vx landcruiser,650 bombardier.
- Real Name: martin
hi,
i am new here and tried to search for this,but no success!
i am sure there must be quite a few wright ups on this?
i have currently a 99 prado front and rear brake system as well as 96 80 series cruiser system.
which is going to fit the easiest?
thanks
thanks
hilux sfa -the only real 4x4!
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: sfa brake conversion/upgrade?
The 80 series, if it's the smaller discs.
The Fj75 front system bolts straight on
- Quintin
- Town: Umhlanga
- Vehicle: Toyota Hilux D/C 2 x Diff lock, 33" MT Tyre, Lexus V8, Winch, Bull Bar and Tow bar.
- Real Name: Quintin
Really? why is the FJ better than the Hilux disks
Because hulle grooter is :wink2:Quintin wrote:Really? why is the FJ better than the Hilux disks
- Quintin
- Town: Umhlanga
maar gaan groter pas want as ek ny my setup kyk is daar nie plek vir groter nie
Ek dink jou 33' maries is dalk te klen, gaan na 38' toeQuintin wrote:maar gaan groter pas want as ek ny my setup kyk is daar nie plek vir groter nie
- Quintin
- Town: Umhlanga
ek het nog nooit so daaraan gedink nie eish maar daardie tyer sal hy pas by die lorry en die briek sal hy gaan by die rim eish
- Quintin
- Town: Umhlanga
weettie die baas hy jock mos nou lekker maar daai big tyre sal mooi werk denk ekke
Eish, ekke weetie....?Quintin wrote:weettie die baas hy jock mos nou lekker maar daai big tyre sal mooi werk denk ekke
- Town: wellington
- Real Name: martin
die land cruiser en die prado se discs is beide groter asook "ventelated" en die calipers is ook groter.
ek het dit nog nie probeer pas nie,want hoop iemand het dit al gedoen en spaar my dalk enige "kopkrap"?
ek dink die groot vraag is:gaan die calipers binne die 15" rims pas?
dit behoort eintlik,want ek het 15"x33 op my 80 series?
Glo dit is vented discs.Quintin wrote:Really? why is the FJ better than the Hilux disks
Die legend 35 shape IFS se calipers en disc is ook bolt on maar jy gaan 'n spacer of ander mags nodig hê
- Hoppy
The FJ 75 discs are the same diameter, but they are vented, we make spacers that fits inside your std caliper to accomodate the discs.
The KZTE calipers bolts straight on, use the FJ 75 discs, they have larger pistons and they use bigger pads.
You can use your old front discs, move them to the back and fit a set of Audi A4 calipers, there is two brackets to be made, but it has a built in handbrake.
The KZTE rear drums and backing plates also fits the SFA, they are much bigger and stops much better.
Don't forget to adjust your load sensing valve at the back, this sorts most SFA brake problems.
The KZTE booster and master cylinder also fits the SFA.
There is other upgrades, but the above is all "bolt on"
- Town: wellington
- Real Name: martin
hoppy,
it looks like the most straight forward conversion will be kzte calipers,fj 75 discs,kzte booster and master cyl and audi a4 calipers rear.
thanks so far,but do know about the fitting of the 80 series stuff or the prado?
the reason i am asking is-i think(have not made a comparison yet)that the these calipers and dics are bigger than kzte.(and i have it in stock)
- Hoppy
That is the best way and straight forward.
I'm sure you'll be able to make them fit, but they won't bolt straight on.
I'm going to have a few sets of brackets made up for the Audi calipers.
- Town: wellington
- Real Name: martin
hoppy,
let me know about caliper brackets-i will take a set.
no hurry-the hilux is waiting for a vortec which is lying in pieces at the moment.
thankyou, i think you saved me some schoolfees/time!
martin
martin
- Town: keetmanshoop
- Vehicle: toyota , land rover
- Real Name: willem
- Club VHF Licence: no
Yes Martin, lekker om jou hier te sien, welkom. Ek het verlede jaar by jou die Audi se calipers gekoop, het al die fittings uitgesort. Ek ry Maandag af, sen jou so iewers in die week, sal vooraf reel.
- Town: wellington
- Real Name: martin
hi willie,
ek het gewonder waar jy aan daai tip gekom het! (die a4 calipers)
...so nou soek ek weer-het gelukkig nog tyd.
iemand met a4 agter calipers te koop???
Sal Goldwagen dit nie dalk verkoop nie of doen hulle net VW parte?iemand met a4 agter calipers te koop???
- Town: wellington
- Real Name: martin
piet,
ek het reg gekom dankie-met die audi calipers.
- 96-Luxi 4x4
- Vehicle: 1996 Toyota Hilux 4x4 DC Almost Lexus V8
- Real Name: Naas
Hi Guys
Iits been a while since someone posted here, hope you are still active on this. Im busy with a lexus conversion, a 6 week project now 5 months going :wth:
Anyways, the next step is to upgrade the brakes. I would like to look at this KZTE conversion in front with FJ75 Rotors, and KZTE master cylinder. Has anyone done this, and have some estimated costs? Where can I buy this?
Im thinking N1 4x4, but they are not the cheapest.
Then rear what is easier, adding the bigger KZTE drum brakes, or converting to the disc and uadi calipers? What about the braking distribution between front and rear? The USA kit (to expensive) includes a valve to manage the braking between front and rear, is this not needed? or do you play around with the Load sensing valves?
As my Hilux is now, the rear wheels lock up quickly, if I adjust it to brake more in the front, in feels like its not braking at all??
I have allot of extras on, and 33" BF Muds, and now when the V8 is done Im gonna need propper brakes.
Please comment and give me some insight and info please.
Thanks guys
Thanks guys
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Hoppy, I would also be interested in a set of Audi A4 brackets
BTW which model A4 do you plunder for the parts?
- Town: wellington
- Real Name: martin
ok,
firstly i did not read so lekka what hoppy said about which calipers and discs!
so i bought two new kzte discs and machined them like the powerbrake ones!(drilled and slotted)
any body interrested-you don't have to pay for the machining-just the discs!
2x alpha discs for kzte front-new and machined-R400.00
