Compressor question
george
Town: Velddrif
Vehicle: Triton 3.5l V6
Club VHF Licence: HC107
Compressor question
Post by george »
Hi Guys.
if i join 2 compressors with a Y piece will this double the air capacity?
Even if they are of diffrent sizes.
The one problem is that they will draw a large current.i would gues around +-20 amp?
I will have to run it from the battery while the motor is running.
Will there be anything else i need to look out for?
Cheers
Hiluxdave_nz
Town: Christchurch New Zealand
Vehicle: 95 2.8 turbo d/cab hilux with a soild axle conversion ,diff locks,high steer falcon spring rear end
Real Name: Dave
Re: Compressor question
Post by Hiluxdave_nz »
i don't see and problem with having a y piece but why do you need more pressure .as for running off the same battery i would have the too compressors fused separately.
george
Town: Velddrif
Post by george »
The reason is to speed up the time it takes to pump the wheel
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
I have seen it done before George. Friend of mine with a Colt did it and he said it worked for him. :D :lol:
Post by Family_Dog »
Hi George,
When we took Bulldog to Berakah recently, we pumped the tyres up with two independent compressors. Bennie used the custom-fitted ARB one while I used a loose compressor connected to the battery with croc clips and we each pumped up two 31" tyres from 1.1 bar to 2.1 bar. It only took us a few minutes (about five minutes I think... can't remember, but less than 10 minutes) in total. I never had the engine running although that is a good idea.
But keep each Compressor separately fused.
Post by CasKru »
Family_BullDog wrote:Hi George,
And I inflated 4 31" tyres from 1.3 bar to 2.1 bar and was finished before you :twisted: :twisted:
That sounds like a lot of "Hot Air"...!!! :P
Post by CasKru »
I must say I've got respect for that T-Max compressor. :mrgreen: :mrgreen:
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Post by BenHur »
I agree the duel piston TMAX rules, even with the 33's it pumps very well. I have seen some guys saying that you have to buy the expensive stuff if you have bigger wheels but I have pumped 2 vehicles tyres (31s) back to back and it did not overheat, or loose power at all. :wink: Compare tat to the ARB at more than double the price, and even Eric's smaller single piston TMAX still out pumped the ARB.
Niel
Real Name: Niel
Post by Niel »
BenHurBul wrote: duel piston TMAX rules
Inflate 4, 31' Coopers from 0.6 to 2.2 in succession and no problems :D :D :D sometimes help other thereafter. :D
Post by CasKru »
I also repaired punctures on my Corolla and then re-inflated the tyres from totally flat to 2.5 bar in just over a minute :) (205/55 R16)
