Alternators and elektrickery
- mushroom
- Town: krugersdorp
- Vehicle: '16 Legend 45 DC 4x4M
- Real Name: James
Hi Peoples,
Excuse my ignorance - I dont know elektrickery :wth: :wth: :wth: but I had a thought. I have an aftermarket air con installed on the 'bongi, and it doesnt work, I wouldnt ever use it anyway. So heres my question to the wise men. Can I strip it out and then put a second alternator in to charge the DCB in the back ??
Obviously it would suck more power (and more juice), but would something like this be possible ???
Comments/suggestions ???
Q20 if its stuck, duct tape if it moves
- mushroom
- Town: krugersdorp
- Real Name: James
Re: Alternators and elektrickery
Eish Cassie - cryptic.....
= work, eat more juice, charge the battery or all of the above !!!CasKru wrote:Yes it would
All of the above!
Why not just fit a higher amp alt, then you can modify the aircon pump and use it to inflate your tyres quick after play time!
lol... all of the above.
It will chow more kW's but not noticeable according to me. It will be able to charge a second battery or run some other 12v circuit. Just make sure it is properly fused.
Wanted to do something like this on my van but don't have the space
- mushroom
- Town: krugersdorp
- Real Name: James
Hey Mr B,
Had that discussion with an auto elektrickeren (at Motolek, Kdorp), and he said that having a higher Amp rated alternator didnt make any noticeable difference to the charge rate of the DCB, as the fridge was pulling less than the alternator was supplying.
Now, my alt is 45A, and this bloke reckons beefing it up is not good for the alternator, it reduces its life span and makes it unreliable. I then asked why the guys beef them up to which he responded that if one has a ORRA type radio and other gadgetry sucking charge while driving, then it becomes necessary.
Me stoopid wif elektrickery - need help.....
The more bells and whistles... the bigger the alternator you need.
If you have a second alti which you dedicate to the DCB, it will charge quicker in the sense that your original alti charges the cranking battery and the car electrics while driving while your second alti will give all it's attention to the DCB
I wouldn't worry about it either unless you have a lot of extras that run simultaneously. Standard, the alt size in the vehicle should be able to rum all the electrical gadgets simultaneously and still have enough output to charge the battery with some amps to spare. If the only extra you have is the DCB, it should still cope 95° of the time.
James... are you still running carburettor or have you also done Efi?
The reason for asking is if you did your Alternator needs to be upgraded as you are running very close to the max if you are driving at night when raining
- Bugzy
- Town: Rustenburg
- Vehicle: 2015 Hilux S/C 4X4 Dakar1996 2.8D s/c 4x4 Hilux with 3CT Toyota motor
- Real Name: Buks
- Club VHF Licence: X56
What amp Altentor do I need if I got a winch,duel battery system with 60l fridge, Orra radio, thermo cooler and GPS?
I would say about 70Amp at leastBugzy wrote:What amp Altentor do I need if I got a winch,duel battery system with 60l fridge, Orra radio, thermo cooler and GPS?
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
What wrong with the standard one.I almost got the same setup and no probsBugzy wrote:What amp Altentor do I need if I got a winch,duel battery system with 60l fridge, Orra radio, thermo cooler and GPS?
George ek dink jou bakkie het standaard met 'n 65A alti uit gekom (ek praat onder korreksie)george wrote:What wrong with the standard one.I almost got the same setup and no probsBugzy wrote:What amp Altentor do I need if I got a winch,duel battery system with 60l fridge, Orra radio, thermo cooler and GPS?
- Bugzy
- Town: Rustenburg
- Real Name: Buks
Thanks, ek het eers gister die winch by Mark gekoop en moet nog die radio koop - het gewonder of ek sal moet upgrade
- mushroom
- Town: krugersdorp
- Real Name: James
Cassie, I have a carb (weber 38D) setup. Currently have the fong kong alt that came with the new 4Y Korean engine (buggered the old alt up when stripping the old engine off.....dont ask )
The Bosch that came off was a 45A, but I find at 0 deg C the fridge turns off if the cab is parked for more than 1.5 days...seems a bit quick to me
- george
- Town: Velddrif
Dit maak dan sinCasKru wrote:George ek dink jou bakkie het standaard met 'n 65A alti uit gekom (ek praat onder korreksie)
Cas moet ons nie dalk 'n paar somme maak nie.
Hoeveel amps gemiddeld gebruik die motor as hy hardloop?
Ekstra toerusting ens.
Ek het ook in daai lyn gedink.george wrote:Dit maak dan sinCasKru wrote:George ek dink jou bakkie het standaard met 'n 65A alti uit gekom (ek praat onder korreksie)
Headlights (55W) 4.6A per light (dims)
Headlights (60W) 5A per light (bright)
Spot lights (100w) 8.4A per light
ECU guessing about 2 to 3 amps
Ignitor guessing 5 to 10A
Fridge/freezer between 4 and 8A
Interior lamps and lights and sigarette lighter 12A
Wipers guessing 7A
Battery charging current 4 to 8A
Winch guessing about 25A
- george
- Town: Velddrif
Los maar die winch.Hy kan tot 400amps trekCasKru wrote:Ek het ook in daai lyn gedink.george wrote:Dit maak dan sinCasKru wrote:George ek dink jou bakkie het standaard met 'n 65A alti uit gekom (ek praat onder korreksie)
Wipers guessing 7A
- mushroom
- Town: krugersdorp
- Real Name: James
Jeez Cassie - that means with my little 45A alt- if I'm driving at night, listening to the radio, charging my torch, and I decide to light up a Styvie, my beers might start getting warm cos theres no charge going to the fridge...
ouch.....
ouch.....
Jipmushroom wrote:Jeez Cassie - that means with my little 45A alt- if I'm driving at night, listening to the radio, charging my torch, and I decide to light up a Styvie, my beers might start getting warm cos theres no charge going to the fridge...
ouch.....
Then there is:
ORRA Radio - between 2A and 8A depending on receiving or transmitting
indicator lights +- 1.5A per side
brake lights and parking lights - +- 2A
Then the following stuff also uses power:
Airconditioner
ABS
- Cleaner
- Real Name: Ernst
- Club VHF Licence: X31
Sounds like adding a generator in to supply power would solve the problem
- mushroom
- Town: krugersdorp
- Real Name: James
Okay, so I have settled on getting my old alt beefed up to around 90A - done by Bosch service dude. Brushes, bearings and the beefup all for R 650 !!!
I will post his details for the Gautengelengers, once I receive the finished goods and ensure they are working and I dont get ripped off...
Now the next project is solar on the vehicle - to power a small house alarm battery, from which I will run a couple of LED strips and a LED spot - so, if theres any solar boffs out there - please dont be shy to share some gaff with me ...pleeeeez
- kfxnando
- Town: Germiston
- Real Name: Fernando
yes the two alternates has been done before
self been there done that
however I had 7 yes seven batteries in the boot to power the sound system
maybe have a read here
http://www.kfxnando.com/viewtopic.php?f=29&t=93" onclick="window.open(this.href);return false;
have posted it here before just not sure where, and me not very good at finding old posts
hope this helps
hope this helps
- mushroom
- Town: krugersdorp
- Real Name: James
Heres a lekka link for us dof okes - its out of a Toyota electrical training manual by the looks of it:...use or dont...
http://www.autoshop101.com/forms/elec11.pdf" onclick="window.open(this.href);return false;
and then :
http://www.scribd.com/doc/18736611/Basi ... cal-Course" onclick="window.open(this.href);return false;
and then :
- Stubs
- Town: Onrusrivier Hermanus
- Real Name: Stuart
I have just put in one big Bosch alternator able to push out 1550 W's....runs all my six x 100 w spots, fridge, fogs, 2 x radios, dual batteries, invertor and run all my headlighhts/high beam at the same tim.....been working perfect for over 2 years now...
