Canvas RTT kort n was
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Weet iemand wat is n veilige manier om n RTT te was dat hy nie aan die lek gan as dit reen nie?
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
Mountain Man
Town: South Africa
Vehicle: Land Cruiser 79 Series 4.5 EFi
Real Name: Craig
Re: Canvas RTT kort n was
Post by Mountain Man »
Hangover wrote:Weet iemand wat is n veilige manier om n RTT te was dat hy nie aan die lek gan as dit reen nie?
I don't know about a RTT but I have a Tentco canvas dome tent and we packed it away wet from the dew. When we opened it again it was mouldy so I simply washed it with the pressure washer. It came out very clean, took the mould and bird pooh off it too. It also never leaked when it rained because I never used detergent, only water from the pressure washer. I'm not saying it is the best way to clean it, we just did it that way because of the mould. But I would do it again as it worked very well.
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Ok cool is there anybody else that have tried this? Mine was also packed away wet... I suppose you used a wide spray beam on your washer?
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
Mountain Man
Town: South Africa
Real Name: Craig
No, I used that rotating sprayer that comes with the K'Archer pressure washer. Probably about 200-300mm from the tent fabric.
Return to “Open Discussion”
