Lexus 4speed Auto gearbox problems
- Ali3n
- Town: Roodepoort
- Club VHF Licence: B338
So about 4 weeks ago my surf decided not to change gear into 4th gear. It shifts perfectly from 1st to 3rd but not into 4th nor lock-up. Now after phoning around and getting many different possible causes I decided to start from the simplest and work my way down.
Drained the oil and put in new oil. Still no luck, Checked all the wiring and no luck, removed and tested and cleaned the speed sensors with no luck, checked and tested the crank position sensor and nope not that either.
So one evening I pulled the gbox sump and tested the solenoids and they seem to work. I then checked the sump and I found a lot of metal shavings.
The box runs perfectly, no scratching and or funny noises so I suspect that some of this metal has got into places where it should not have gone into and thus does not let it change to 4th. The box filter is clean and no metal.
Now my question is should I try and flush the gbox clean somehow and install the sump again and try or should I rather just replace the box?
What damage can there be?
To replace the box will not cost so much so I am not too concerned about that but don't want to unless I have to.
PRESENTLY DISADVANTAGED
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Re: Lexus 4speed Auto gearbox problems
I have a spare valve body if you want to try that? It's just quite heavy for couriering...
- Ali3n
- Town: Roodepoort
Thanks. Let's see if there is someone willing to bring it back for me. What are you looking for it?Toybox wrote:I have a spare valve body if you want to try that? It's just quite heavy for couriering...
I've got family leaving for Bloem and then Joburg on 22nd... if Jonathan can get it to me, I can send it with them... Alien, you'll have to collect it in Kempton Park then...
- Ali3n
- Town: Roodepoort
That will be awese if possible for Jonathan to get it to you. I don't mind collecting it in Kempton.Mr_B wrote:I've got family leaving for Bloem and then Joburg on 22nd... if Jonathan can get it to me, I can send it with them... Alien, you'll have to collect it in Kempton Park then...
- Toybox
- Vehicle: Hilex
It's yours. It's been sitting in a box for ages. That said I hope it's still there!
I'll scratch tomorrow.
- Ali3n
- Town: Roodepoort
Ag thanks a mil. Wil stick you for a drink or 2 when I come down to play in the dunes. Whether you still have it or not.Toybox wrote:It's yours. It's been sitting in a box for ages. That said I hope it's still there!
[quote= "Francina"]I then checked the sump and I found a lot of metal shavings.[/quote]
Don't like the sound of that at all! I think you're going to find something other than just the valve body .... hope I'm wrong!
- Ali3n
- Town: Roodepoort
Jip, thats my worry but these sumps have magnets at the bottom (Never seen that before)to remove these shavings so I am guessing that it does happen that there is shavings in there. But where do they come from is the big question.Mud Dog wrote:Don't like the sound of that at all! I think you're going to find something other than just the valve body .... hope I'm wrong!Francina wrote:I then checked the sump and I found a lot of metal shavings.
Top gear is normally a "straight through" 1:1 ratio ..... in reality it's not really 'straight through' in the sense that there is no gearing involved. Usually there is a separate cluster at the back of the box that connects input and output shafts at the same speed (5th gear) and it's not unheard of (like we had a case just a week or two ago), where one of the retaining snap-rings gives in and 5th is lost. I hope it's just something simple like that in your case as well and that the metal bits are just from the chewed snap-ring.
- Ali3n
- Town: Roodepoort
Thanks. Hope so 2...Mud Dog wrote:Top gear is normally a "straight through" 1:1 ratio ..... in reality it's not really 'straight through' in the sense that there is no gearing involved. Usually there is a separate cluster at the back of the box that connects input and output shafts at the same speed (5th gear) and it's not unheard of (like we had a case just a week or two ago), where one of the retaining snap-rings gives in and 5th is lost. I hope it's just something simple like that in your case as well and that the metal bits are just from the chewed snap-ring.
Must say that it has changed into 4th gear twice in the 4 or so weeks but as soon as you stop and pull away it doesn't which leads me to think that it might be something else wrong as it has changed.
- blom
- Town: Landrovia
- Real Name: Blom
i have a spare box the normal rules apply
case o beer and bring back what you take for testing
Grensvegter van LANDROVIA
- Ali3n
- Town: Roodepoort
Blom... wee jy wat. Jy is eintlik n yster... ek sal jou bel more en reelings maak.blom wrote:i have a spare box the normal rules apply
Jonathan, I am still interested if you still have it.
- Town: Muscat and Midrand
- Vehicle: 2.7 Hilux 4x4
- Real Name: Roelof
Good excuse to fit the 3uz and 5 speed now!
- Ali3n
- Town: Roodepoort
Unfortunately I was fighting a loosing battle with the minister of finance after my plans became public knowledge as well as my plans on buying a complete shell with full interior and exterior.Hiluxfan_111 wrote:Good excuse to fit the 3uz and 5 speed now!
- Real Name: Roelof
That is very unfortunate!
A SMALL amount of shavings is acceptable and normal in a manual gearbox with many kilos.
However in an auto box this is a clear indication that something has gone wrong!
- Toybox
- Vehicle: Hilex
Right found it. I'll make a plan to get it to Mr B in the next day or two.
- Ali3n
- Town: Roodepoort
Great, thanks a mil.Toybox wrote:Right found it. I'll make a plan to get it to Mr B in the next day or two.
- Town: Cristur - Romania
- Vehicle: LC 120
- Real Name: KORNIS
Hy Ali3n!
Give me the VIN of your car.I had same problem with Rav 4 .
- Ali3n
- Town: Roodepoort
Hi Kornis,kornis_istvan wrote:Hy Ali3n!
I doub't that my vehicles VIN will help much as i replaced the original 2L-te motor, Auto box as well as ECU to that of a 1UZ-fe from a lexus thus do not have the donor vehicles VIN.
