KZTE Brake problems
pietdevs
Town: Mosselbay
Vehicle: Toyota Land Cruiser Troopy
KZTE Brake problems
Post by pietdevs »
I have a 4x4 KZTE with ABS brakes. When I do approx 70km/h and brake there is no brakes. This happens every now and again. Any suggestions on what is wrong pls?
Re: KZTE Brake problems
Post by CasKru »
Sounds like the master cylinder seals need to be replaced
SKRIK NIKS
Town: krugersdorp
Vehicle: hilux 3.0kzte
Real Name: jan venter
Post by SKRIK NIKS »
Hello Pieter
Dit het al met my gebeur ,kyk na jou voorste wheel bearings ,hulle kom los ,en dan druk die brake discks the psitons op die calipers terug ,en as jy trap dan is darr niks ,maar as jy weer trap dan is die brieke reg vir n rukkie
Ek hoop die info help
SKRIK NIKS
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
Explain "no brakes"
Does the pedal go to the floor with no resistance?
Does it go halfway?
Does it stay hard, but doesn't stop?
MCHILUX
Town: Centurion Gauteng
Vehicle: Mazda Rustler 16v
Real Name: Jan
Post by MCHILUX »
If the pedal stays hard but no effect on braking the ABS actuator is faulty just remove the ABS relay and the braking system will be like normal brakes without ABS
pietdevs
Town: Mosselbay
Post by pietdevs »
Thanks for all the info. Some days I realise how valuable the forum is! I will do all the checks. Where is the ABS relay situated?
The brakes are hard when I step on it with no brakes.... I went through the exercise of bleeding the brakes to check for air but it is ok.
pietdevs
Town: Mosselbay
Post by pietdevs »
The brakes stay hard but does not stop - and then it works again.
Dingo
Real Name: Scott
Post by Dingo »
pietdevs wrote:Thanks for all the info. Some days I realise how valuable the forum is! I will do all the checks. Where is the ABS relay situated?
pietdevs
Town: Mosselbay
Post by pietdevs »
Where is the ABS electrical plug situated? I want to disconnect and start here...
Post by pietpetoors »
Look in engine bay, on the 2.7 it is on the steering wheel side close to the firewall. It is clearly marked ABS. Just pull the relay out.
Not sure if it is located at the same place on KZ
MCHILUX
Real Name: Jan
Post by MCHILUX »
Small black box with two relays in on driver side in engine compartment near the brakebooster
