Galvinised rock sliders of swart spray?
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Het iemand al galvanised rock sliders gemaak of gesien weet nie hoe dit by my lux gaan pas nie maar dink dit kan mooi werk
Help asb
Help asb
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Re: Galvinised rock sliders of swart spray?
slegte idee! Galvanizing is maar net soos 'n verf laag en as jy dit krap dan sal dit ook roes en dit kan nie mooi gedoen word nie, dit sal lyk of die sliders 'n slegte laag spray paint op het. met verf kan jy dit self reg maak vanheer dit krap jy hoef dit nie te stuur vir ' re-dipping' nie. Powdercoat eerder of gaan stainless steel.
Hoop dit help.
o ja, en om op galvanizing te verf is 'n pyn in die g@t daar is spesiaale prep werk wat gedoen moet word.
Hoop dit help.
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
Hot dip galvanising and then powder coating over it. Most hollow steel work starts to rust from the inside - paint doesn't get there to protect it but hot dip will. the powder coat will help to protect the galvanising from being scratched, and even then, it takes an awful lot to scratch through hot dip.
Galvinising will stop it from rusting but it will look crap. Paint/powdercoating wil make it look great, but over time and after travelling on dirt roads a lot stones will chip the coating off. In that case paint is the best because you can patch it up yourself, whereas with powdercoating you'll need them sand blasted and recoated...
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Dankie het geweet die slim manne sal help
Wat sit hulle dan op die bush plates?
- Town: ROODEPOORT
Los hom stainless steelMasekind wrote:Dankie het geweet die slim manne sal help
God made man before
God made man before
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Het dit klaar van mild steel gemaak, stailess is bo my budget sou baie nice gewees as ek konObelix and Dogmatix wrote:Los hom stainless steelMasekind wrote:Dankie het geweet die slim manne sal help
- Town: ROODEPOORT
Verf maar jy sal die selfde krap proebleme he met powder coatingMasekind wrote:Het dit klaar van mild steel gemaak, stailess is bo my budget sou baie nice gewees as ek konObelix and Dogmatix wrote:Los hom stainless steelMasekind wrote:Dankie het geweet die slim manne sal help
God made man before
God made man before
Hammerite die goed.. lekker dik hammered finish.. dis nogals baie sterk.. amper soos liquid powdercoating...
- Oupa Stig
- Town: Johannesbug
- Real Name: Mickey
Stem saam, Hammerite, biekie duur, maar jy kan hom in 1lite en selfs halfliter kry.
So vir interessantheid, wonder hoe sal dit werk as jy hom mooi mask en die onderste helfte laat rubberise? Sal klippers hom chip?
- Town: ROODEPOORT
DIS JUIS WAT EK GEBRUIK HET WERK GOEDThysdJ wrote:Hammerite die goed.. lekker dik hammered finish.. dis nogals baie sterk.. amper soos liquid powdercoating...
God made man before
God made man before
- Town: ROODEPOORT
Jy wil eerder bo rubberize sodat jy die afgly in die nat as jy daarop staan nie.Oupa Stig wrote:Stem saam, Hammerite, biekie duur, maar jy kan hom in 1lite en selfs halfliter kry.
God made man before
God made man before
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
quote="ThysdJ"]Hammerite die goed.. lekker dik hammered finish.. dis nogals baie sterk.. amper soos liquid powdercoating... [/quote]
Dankie dit klink na n plan waar sal ek dit tekoop kry en wat kos dit?[
- Town: ROODEPOORT
enige builderwarehouse maar ek dink nie dat daar een in Slurry is nie
God made man before
God made man before
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Hier is niks in Slurry nieObelix and Dogmatix wrote:enige builderwarehouse maar ek dink nie dat daar een in Slurry is nie
dankie sal gaan kry moet dit met lae of hoe druk gespry word?
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Daar sit mos 1 langs Jim Fouche naby Hendrik Potgieter sal ouma vra om te gaan kyk
- Town: ROODEPOORT
hulle het beslis dis waar ek myne gekoop het jy sal so drie blikke nodig he.
God made man before
God made man before
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Dit sal dan 3L wees?Obelix and Dogmatix wrote:hulle het beslis dis waar ek myne gekoop het jy sal so drie blikke nodig he.
There is no substitute for hot dip galvanising, period. The problem with galvanising however is that painting it requires proper preparation and an effective etch primer, otherwise it will just flake off. But yes, painting is an option besides powder coating, and Hammerite can be sprayed .... just get the Hammerite thinners (Acetone does work as well but you have to use or discard all that you have thinned with it, otherwise it curdles ... you can't put it back to the tin).
Painting alone will result in rust inside the pipe where you cannot get a paint coating.
