Electrical gremlin
Posted: Fri Feb 13, 2015 11:33 am
by richard
hi guys
can anyone steer me in the direction of a reputable auto electrician for my Prado 90?
Whenever i wanted to start the vehicle after standing in the garage for 2-3 days the battery would be flat and not crank over. I have had the system checked and nothing was picked up also the normal drain on the battery when standing is in the acceptable range.
So i replaced the battery and all seemed fine...until after standing for about 6 days while i was away the battery is dead again!
PLEASE HELP! i cannot stand to see my Prado suffer like this...and me.
Re: Electrical gremlin
Posted: Fri Feb 13, 2015 12:39 pm
by Haboob
Connect to an intelligent charger when not in use...
Until you can find a good auto electrician...
My lux is basically a holiday vehicle and I keep the batteries charged with a Hawkins intelligent charger which keeps them in tip top shape...
Posted: Fri Feb 13, 2015 1:21 pm
by Mr_B
I've heard of guys having problems like this caused by faulty sat tracking units. If you got one installed, have it checked.
Posted: Fri Feb 13, 2015 1:27 pm
Mr_B wrote:I've heard of guys having problems like this caused by faulty sat tracking units. If you got one installed, have it checked.
+1
Posted: Fri Feb 13, 2015 1:37 pm
by CasKru
IF you want to try and isolate the problem yourself.... here is an excellent method to find the culprit
phpBB [video]
View Original
In the video it says finding a short but you can use the same method to determine which circuit draws too much power even though it might not be a short
Posted: Fri Feb 13, 2015 10:14 pm
by Family_Dog
Bound to be a tracking unit, follow Cassie's advice. The Prado 90 battery stays good for weeks when not used and starts instantly.*
*Except once when I did not close the driver's door properly and the dome light made the battery flatter than a pancake - and this was one time I didn't bother using the Benton 'cos I figured it lasts long enough without the charger connected. Wrong! :oops:
Posted: Sat Feb 14, 2015 6:34 am
by JamesC
+ 1....tracking unit
Posted: Mon Feb 16, 2015 2:14 pm
by richard
thanks all for the valuable info :thumbup:
I'm first going to try isolate the parasitic draw myself as explained in the video (thanks CasKru), otherwise the sparkie will have to get things right for me.
Posted: Thu Apr 16, 2015 10:41 am
by richard
Words of wisdom never fail this forum...thanks guys for the advice :thumbup:
So the tracker was successfully removed and im pleased to say that the Prado can now go 8 days sleeping in the garage and start without any issues :yahoo:
The date on the sticker over the battery of the tracker is 30/01/03!!! They dont make them like they used to!
