Sludge buildup in engine, what now?
- Town: Rawsonville
- Vehicle: 96 SFA Hilux
Hi Guys,
I serviced my Toy this weekend and got the fright of my life when I took the tappit cover off to adjust valve clearances.
Bakkie is a 1996 SFA DC Raider with 22R 2.4 petrol engine, 205 000Km on the clock.
See what you think of this and where do I go from here?
If you wanted to say "do not add engine flush", too late! did that last weekend before I changed the oil and filter. That might be the reason for the cleaner spots seen in places. I bought the bakkie last year, so this is the first service. I am now running Rimula X in it.
I hit the tappit cover with degreaser and the high pressure cleaner, but that stuff is not budging.
Your advice/ opinions much apreciated.
Re: Sludge buildup in engine, what now?
looks like the previous owner used Castrol GTX ....
Would love to hear HOPPY's advise for cleaning this baby.
The problem with cleaning it is that that sludge MUST go somewhere ... either blocking small oil passages, or blocking the filter .... cleaning it out without stuffing up a few bearings may well be difficult ...
The problem is not the sludge that you can see, but rather that thats accumulated in all the oil channels, oil filter and pump. I'd recommend not using an engine flush first in this case. Start by draining the oil overnight(engine oil should be hot before draining), then(following day) remove the sump and make sure the oil pump is not clogged by inspecting the course metal filter, replace the oil filter as it could also be close to clogged. If the pump is clogged remove if and clean properly(rinse in petrol) and clean the sump. Re-assemble and re-fill the engine with a good diesel oil like Shell Rimula R4. Run the engine with this oil for say 500km and repeat(replacing oil filter and oil). Diesel oils contain a high concentration of detergents that will break down the sludge bit by bit! After that(1000km) take off the rocker cover and inspect. If there's no/little improvement you may have to consider using a good quality engine flush or even tearing down the engine and rebuilding as a last resort!
That's what I would do... mech gurus like Allan and Francois may have even better advise!
- raider
- Vehicle: 96' Hilux Raider 2.4 4x4 SC, 12' Mitsubishi PJS 3.2 4x4
- Real Name: Zubair
That looks really bad. The previous owner must of never serviced the vehicle. That's past the sludge stage and looks like it has formed a tar like substance. I've watched videos on oil tests and oil only does that when subjected to extreme heat or extremely long duration of time without change. Perhaps the previous owner kept using the wrong spec oil or added additives that had negative effects.
- Town: wellington
- Vehicle: 81 hilux 350,80 vx landcruiser,650 bombardier.
- Real Name: martin
that is tipical GTX colestrorol!
I would say - strip, chemical clean and assemble with new seals,gaskets, ring and bearings?
hilux sfa -the only real 4x4!
- Town: Rawsonville
Thank you for the replies guys, I can well imagine that damage have been suffered by now.
The bakkie is really sluggish and thirsty compared to what I am used to and I have never owned a petrol vehicle before this one.
What are we looking at $$ wise talking A: parts, and B: Labour should I have it done at a reputable mechanic?
If I contemplate going the strip, clean and replacement of parts route, do I stand to lose anything if I were to try and clean it with the Rimula X route (What I have in now) first? Can the true state of the engine be determined as it stands to see if the rebuild is justified/ necessary or if just a good cleaning will do?
I was not planning on ripping it's heart out any time soon, but hell, are you ever?
- Dowe Koos
- Real Name: Hennie
Hallo Pieter en almal
Ek ry al 35 jaar en die volgende voertuie wat ek en my vrou gehad het is; 3 x Beetles, 2 x Opel Kadet, 3 Monza, Hilux 1984 4x4 wat ek 20 jaar gehad het sonder dat ek die enjin ooit oopgemaak het, die huidege 2004 2.7, 250-400-650 DR Suzuki en 1000GS en 1100 GSX en dan ook 1100 GPZ Kawasaki, huidiglik dan ook 400DRZ en DR 800. Ek het by my pa geleer om net Castrol te gebruik en nog nooit het ek daardie probleme gesien of beleef wat Pieter nou het. Wat ek wil sê is dat my broer het 'n Fortuner gehad het wat gerook het en hy het toe nogal 'n Wynn "additives" ingegooi en dit was seker nie eers ses maande, toe pak sy Fortuner se enjin op en dit lyk net soos wat op jou bakkie is. Omtrent jaar later gooi hy ook in iemand anders se kar wat gerook het weer Wynn "addittives" en ook nie lank daarna pak daardie kar op. So uit my ondervining is dit die "additives wat die skade maak en nie CASTROL nie.
Ek stem saam met Bretton, doen jou enjin heeltemal oor, kortpad gaan jou net later meer geld kos.
Sterkte daarmee.
Sterkte daarmee.
While it is still running, keep going.
Maybe change the oil every 2/3000km for a 10/20000km and have a look?
You could also add some diesel to the oil for the last couple of hundred kilos before changing the oil, much as you would do if using an engine flush. It will thin the oil down but will help to break down that gunk - adding roughly a pint shouldn't cause any problems / undue wear if you don't ride it hard.
- Real Name: Marnus
I also think that is due to driving the vehicle for very long intervals without changing the oil. I think to start re-doing the engine if it is not using oil etc. is a little premature. I would also try the diesel trick and see what happens. I would also remove the sump and see what it looks like in there.
- Town: Rawsonville
Thank you all for the replies. I am going to run it like this with rimula x for a couple thou kilo's and compare rockers with pics taken. If there is an improvement, i will keep going. If not I will think of plan b. Best weekend to all!
- Danman
- Real Name: Danie
Stem saam hennie. Gebruik ook al jaaaare castrol en nog nooit so iets ervaar nie.
- Club VHF Licence: X93-
Ek kan ook nie byt aan die storie dat Castrol olie die sludge veroorsaak nie. Ek het Castrol GTX olie van 1975 in al my voertuie gebruik en nie een van hulle het olie sludge probleme gehad nie.
Ek het nou onlangs maar eers oorgeskakel na Shell Helix toe -nie dat Castrol my enige moeilikheid gegee het nie.
Self vir jare GTX gebruik.
'n Vriend was n mechanic, en na n paar hart aanvalle kon hy nie meer permanente werk kry nie .... werk toe van die huis af. Ek het n paar enjins saam met hom oorgedoen (ek het net tools aangegee). Sodra daai sump drop kon jy SIEN as die man GTX gebruik het !!
nooit die tipe aanpaksel bo-op die cams gesien nie. Maar gereeld die "GTX cholesterol" onder in die engin gesien.
- Town: wellington
- Real Name: martin
presies!...waarom sal hulle nou skielik "anti cholesterol" olie adverteer? - hulle was die oorsaak daarvan!ChrisF wrote:Self vir jare GTX gebruik.
kan dalk ook noem dat Castrol GTX was in die vroee 90's ontrek van die mark, toe High Milage bekend gestel is.vanthev8man wrote:presies!...waarom sal hulle nou skielik "anti cholesterol" olie adverteer? - hulle was die oorsaak daarvan!ChrisF wrote:Self vir jare GTX gebruik.
Taxis het geweier om oor te skakel, en Castrol moes die klandisie verloor of weer GTX terugbring .....
- Town: wellington
- Real Name: martin
chris,
ek het ook gesien hoe Toyota n "stickertjie" op die 2E masjien se tappet cover geplak het in die laat 80s/ vroe 90s.
"ONLY USE CASTROL GTX IN THIS ENGINE"
weet nie wat Castrol en Toyota se liefdes verhouding was nie, MAAR kan jou verseker hierdie masjientjies het skaars 200k gehaal en dan gooi hy conrod! en as jy hom oopmaak is hy so vol sludge dat die oliepomp nie meer sy werk kon doen nie!
...praat maar gerus met die "ouer garde" engine herbouers?
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Some interesting reading
http://driving-tests.org/beginner-drive ... ne-sludge/" onclick="window.open(this.href);return false;
and
http://www.wisegeek.com/what-is-engine-sludge.htm" onclick="window.open(this.href);return false;
Have you looked at your cooling system?
and
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Dowe Koos
- Real Name: Hennie
Dankie Quentin vir die artikels. Hier sien ons dit kan met enige kar en enige olie gebeur. CASTROL tops
Ek weet Castrol het die anti-freeze vir Toyota "verpak" ....vanthev8man wrote:chris,
Een dag per week het hulle n ander kleur middel ingegooi. PRESIES dieselfde botteltjie waarin die anti-freeze gekom het, net ander printing op dit.
so ja, dalk het die samewerking dieper geloop ....
- Town: wellington
- Real Name: martin
haha chris,
dit lyk dan nou of die sous nie NET in die parlement loop nie?...
- Wave
- Town: Edenvale
- Vehicle: Tuna 3.0 D4D 4x4
- Real Name: Geoff
I would keep driving it and change oil and GUD or OEM oil filter every 2000 kms, make sure you do some nice highway driving as often as possible to get everything lekker hot and hopefully losen up that gunk.
I would use Caltex Delo 400 as it seems to tops in the detergent area.
Also check you cooling system and flush and use genuine Toy coolant!
'09 Toyota Fortuner 3.0 D4D 4x4 (M)
'14 VW Polo 1.2 TSI H/L (Swambo's)
'10 Conqueror Comfort
- Vehicle: Hilux SFA
- Real Name: Rodney
Agree to run Shell Rimula had Isuzu diesel for years and every one was shocked when motor was striped how clean it was.And would only do oil changes every 5000km.Not a GTX fan.
- Real Name: Marnus
I would definitely remove the sump, clean it out and make sure that the oil pickup(Screen/pipe etc.) is completely clean.
- 4ePikanini
- Town: East London - Thorn Park
- Vehicle: Touareg R5 TDi
- Real Name: Marius Fourie
pull the engine and sump
Leave it in bath full of diesel turning the engine by hand every few hours to work the oil pump - leave the diesel filter on.
Then let it drain for a day. Fill with fresh oil and fresh filter, run it for 200km. Drain the oil again and change the filter again.
