new project.....she needs a name...
Posted: Mon Oct 12, 2015 7:40 pm
by Cres
Hello
So this all started me wanting to get into 4x4ing, but my money is not all there.....so the search for a project Hilux started....i saw Lukes post about his Hilux and knew that was exactly what im looking for as i had some spare engines laying around
, so first thing first after i got her home was to add a sticker, then Sunday came around and had some spare time and i couldn't start with the engine yet so i started with the interior witch needed some valuable TLC....found some things including a hole in the floor well but noting serious. in the coming week ill wire wheel the whole floor fill all the holes and give it a lick of paint. She needs a name i'm open to all suggestions
Re: new project.....she need a name...
Posted: Mon Oct 12, 2015 9:36 pm
by Family_Dog
"Hot Stuff" - (the little red devil in the comics of yesteryear).
Well, she will be 'Hot Stuff' by the time you're finished with her!
Posted: Mon Oct 12, 2015 9:38 pm
by CasKru
Rusty
Posted: Tue Oct 13, 2015 11:01 am
by Thunder02
CasKru wrote:Rusty
Was going to say the same, so two votes for "Rusty"
Old trusty Rusty
Posted: Tue Oct 13, 2015 11:29 am
by ronnie
Thunder02 wrote:CasKru wrote:Rusty
Old trusty Rusty
+1
Re: new project.....she needs a name...
Posted: Tue Oct 13, 2015 12:14 pm
by Haboob
"Hot Stuff"
but we also need to know what engine will be added to Trusty Rusty.
Gigger than normal will be "Hot Stuff", otherwise Trusty Rusty.
Character will be built...
Posted: Tue Oct 13, 2015 7:02 pm
by Cres
Ok sy is rusty tot die engine in is
Posted: Thu Oct 15, 2015 5:30 pm
by pampoen
Posted: Wed Jan 13, 2016 3:18 pm
by Cres
Between all the work and holidays some work was done....gearbox and dummy engine was mated and lowered in...just need to finish the mountings, the mounting in the pics are the wrong ones. If any one knows of a KZTE box laying around please let me know
Posted: Wed Jan 13, 2016 3:20 pm
by ChrisF
MOOI !!
Posted: Thu Jan 14, 2016 10:10 am
by pampoen
Posted: Thu Jan 14, 2016 12:59 pm
by Thunder02
Lekker, going to be on the trails soon.
Posted: Mon Apr 04, 2016 8:43 am
by Cres
Hi guys did a bit of work....got all the old lexus v8 mounts out and started with the 7M mounts quick question how far back is the motor on your guys bakkies?
I'm using a stock 7MGE mountings it's a bit low I know but should work 100%
This is the only pic I have of the engine that is going in the one in the bakkie at the moment is a dummy
Sent from my D6503 using Tapatalk
Posted: Mon Apr 04, 2016 8:46 am
by niclemaitre
The rust on the floor is usually caused by water dripping from the rainwater channel/air intake for the ventilation system under the windscreen. Make sure you check for rust buildup there.
Re: RE: Re: new project.....she needs a name...
Posted: Mon Apr 04, 2016 8:53 am
by Cres
niclemaitre wrote:The rust on the floor is usually caused by water dripping from the rainwater channel/air intake for the ventilation system under the windscreen. Make sure you check for rust buildup there.
The bakkie has a sunroof and I think it's been leaking for a while, that is the only rust there is further up is clean
Posted: Mon Apr 04, 2016 10:10 am
by Knuppel
What Nic says !!!
Check inside HERE!
Posted: Sun Nov 20, 2016 5:22 pm
by Cres
So I did some work again it's real engine is in now to do some wiring
During next week I'll do the wiring and fuel system
Sent from my F5121 using Tapatalk
Posted: Sun Nov 20, 2016 6:24 pm
by Dadz Toy
Do I see right, Rooi Rust is an Auto??
Rich
Posted: Sun Nov 20, 2016 6:25 pm
by Cres
Nope manual hehehe
Posted: Mon Nov 21, 2016 6:07 pm
by Thunder02
Chris, she is looking great. Think she is heading to "Hot Stuff" at an rapid rate.
Posted: Mon Nov 21, 2016 6:36 pm
by TertiusK
Netjies.
Die wa kom mooi aan. Sterkte
Posted: Sun Nov 27, 2016 8:20 am
by Ou vale1
Dadz Toy wrote:Do I see right, Rooi Rust is an Auto??
Rich
Also had a good look at the powerbrake pedal ..
Posted: Sun Nov 27, 2016 8:27 am
by Cres
[img]
//uploads.tapatalk-cdn.com/2016112 ... 8ac8a9.jpg[/img] so the wiring starts
Posted: Sun Nov 27, 2016 8:35 am
by Cres
Ou vale1 wrote:Dadz Toy wrote:Do I see right, Rooi Rust is an Auto??
Rich
When I bought her it had a auto in her it was setup for a v8. All the pedals are back in the way it's supposed to be
Posted: Mon Nov 28, 2016 3:21 pm
by pampoen
Looking good cres. Are you going to keep the old rad?
Posted: Mon Nov 28, 2016 3:23 pm
by Cres
Hi Pampoen, I'm not sure yet we are going to fabricate water pipes for it but if it doesn't do the job I'm going to change it
