Knock sensor
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Knock sensor
Hi, can anybody help with the part number for the knock sensor on the block. 2002 2.7I IFS
Thanks in advance.
Thanks in advance.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
Re: Knock sensor
get it from toyota?
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Re: Knock sensor
89615 -26010 or 89615 - 50010 depending on the year model. Just check with the agents.
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Knock sensor
www.4x4direct.co.za
www.4x4direct.co.za
- LouisZ
Re: Knock sensor
Part no. 89615-50010. Word wyd gebruik van die Prado 90 tot van die Camrys. Wonder of daar ene nog op my ou engine is?
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Knock sensor
Just checked with Toyota, that is the same part number according to my VIN number, cost R1550.00LouisZ wrote:Part no. 89615-50010. Word wyd gebruik van die Prado 90 tot van die Camrys. Wonder of daar ene nog op my ou engine is?
www.4x4direct.co.za
www.4x4direct.co.za
- mcw
- Town: krugersdorp
- Real Name: Martin
- Club VHF Licence: X100
Re: Knock sensor
Hi Neil
saw on ebay approx. R550.00 including shipping
do not know what import duties will be
Martin
Martin
- LouisZ
Re: Knock sensor
Jy reggekom?. Ek sien my ou engine sinne is nog op.
- Dowe Koos
- Real Name: Hennie
Re: Knock sensor
Hallo Neil. Klink miskien dom, maar wat is 'n "knock sensor".
- LouisZ
Re: Knock sensor
Hennie dit is 'n sensor wat op vandagse engins gebruik work om the tyd(ignition) terug te stel om te keer dat die engin ping. In envoudige taal is dit wanneer die engin se tyd te ver gaan en veroorsaak dat die engin knock.
Met die Ecu vandag op brandstof inspuiting petrol engins gaan die tyd ver oor die 45 grade met die tyd en branstof mengels wat verkry word, die knock sensor bring die tyd dan terug as dit te naby aan engin knock is, stel tyd terug. Dit beskerm die engin.
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Knock sensor
Hi, ended up getting one from the Stealers
Installed it, now the vehicle idles around 500 rpm, spikes to 900 and drops again, I guess the timing needs to adjusted.
www.4x4direct.co.za
www.4x4direct.co.za
- LouisZ
Re: Knock sensor
Laat hom stel by die ouens van Bosch. Net vra, jou thermostat, is die nog ok? Myne was ook so dat hy op en af idle. Die thermostat was heeltyd oop, na dit vervang was is die idling storie ook weg.
- Dowe Koos
- Real Name: Hennie
Re: Knock sensor
Dankie Louis, as ek reg onthou, in die ou dae praat ons van BTDC of ATDC. Dan moet ons dit manually doen, maar vandag word dit outomaties gestel. Wonderlik van vandag se tegnologie.
- LouisZ
Re: Knock sensor
100%
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Knock sensor
Thanks, will have it checked.LouisZ wrote:Laat hom stel by die ouens van Bosch. Net vra, jou thermostat, is die nog ok? Myne was ook so dat hy op en af idle. Die thermostat was heeltyd oop, na dit vervang was is die idling storie ook weg.
www.4x4direct.co.za
www.4x4direct.co.za
- Dowe Koos
- Real Name: Hennie
Re: Knock sensor
Okay Louis / Neil. Hoe weet mens wanneer die "knock sensor" het gegroet. Ek vra maar omdat ek nie goed kan hoor nie.
- LouisZ
Re: Knock sensor
Jou krag sal baie vermin by middle tot hoe rpms.
- Thunder02
- Town: East Rand
- Real Name: Neil
Re: Knock sensor
Engine light will come on, timing will be out and huge loss of power.Dowe Koos wrote:Okay Louis / Neil. Hoe weet mens wanneer die "knock sensor" het gegroet. Ek vra maar omdat ek nie goed kan hoor nie.
www.4x4direct.co.za
www.4x4direct.co.za
- Dowe Koos
- Real Name: Hennie
Re: Knock sensor
Thanks Louis and Neil, it's good to know if something like this happens.
