LED reverse ligte
Posted: Wed Feb 10, 2016 3:33 pm
by coetzer94
Het iemand al daai flushmount LED pods (hulle praat van bumper lights op 4x4Direct ) in die standaard vigo bumper ingebou? En hoe lyk/werk dit?
Die idee is om hull te kopel dat hulle saam met die reverse ligte aan kom, maar ook onafhanklik aan geskakel kan word.
Het enige iemand dit al gedoen wat kan raad gee?
Het aan so iets gedink?
Re: LED reverse ligte
Posted: Wed Feb 10, 2016 5:24 pm
by ChrisF
looks NICE
based on experience with other lights I would guess that 2 x 18W LED spots should give a LOT of light !!!
certainly WILL blind any driver behind you if you accidentally switched that on while driving ....
Posted: Wed Feb 10, 2016 8:06 pm
by pietpetoors
Een van ons gereelde kliƫnte met so mooi wynrooi IFS het dit in sy bumper ingebou.
Hoppy weet wie hy is.
Posted: Thu Feb 11, 2016 6:49 am
by CasKru
I used a 27w LED work light on my rear bumper/tow bar as a reverse light (the didn't stock the ones you are referring to when I bought mine) and it's awesome. More than enough light when you reverse.
Below is the one I used
![Image](http://www.4x4direct.co.za/shop/images/sqr-worklights-27-%285%29.JPG)
Posted: Thu Feb 11, 2016 8:37 am
by pietpetoors
I have two of those in my front bumper. The idea was to use it as DRL.
I must switch them off at night as they blind oncoming traffic. They make far more light than the vehicle's dims, but slightly less than the brights.
So for reverse it will be like installing head lights on the rear of your vehicle.
Posted: Thu Feb 11, 2016 9:51 am
by Thunder02
These are the one's
http://www.4x4direct.co.za/led-bumper-l ... p-1047.htm" onclick="window.open(this.href);return false;
Posted: Thu Feb 11, 2016 11:36 am
by coetzer94
I agree, won't put them on while driving, but with a canopy, I think it will be much easier when reversing.
Is there a wiring diagram for what I want to do using a 3 way switch with 1. lights off 2. auto lights on when in reverse 3. manual operated?
Posted: Sun Feb 14, 2016 12:45 am
I got a pair of these for the Rav - nice east flush mounting and should give ample light ( I haven't got around to fitting them yet). I won't couple them to the reverse lights, just a manual switch with built-in LED indicator that lets you know when they are on ( same as I did on the SFA). This way you can use them any time you need to.
http://www.4x4direct.co.za/led-drl-dayt ... p-1738.htm" onclick="window.open(this.href);return false;
