Towing
Introduce yourself and Meet the rest of the crowd
Krasmuss1
Town: Vardoe
Vehicle: Hilux 2,5 td 2004 chip(128hp)
Real Name: Kristian
Towing
Post by Krasmuss1 »
I want to know if I can Tow a 4260kg trailer whit my Hilux chip(128hp) and therefor is it possible to drive 5-speed 2-series?
Can i drive to 3rd gear in l4 and then go into h4 whitout damaging the gearbox
Re: Towing
Post by Family_Dog »
Would that even be legal in Norway? Doubt it is legal here in SA, or if so would require the trailer to have its own braking system. Nevertheless, I think the 2.5TD would struggle somewhat (especially on hills), even if it is chipped. Just do not even think of using 5th gear, you stand to damage your gearbox.
Re: Towing
Welcome Kristian! :thumbup:
When towing do not use 5th gear unless you are at cruising speed and the motor is not labouring.
[quote/]Can i drive to 3rd gear in l4 and then go into h4 whitout damaging the gearbox[quote]
Do not do this, you will damage the transfer box. It can be done at crawl speeds only but I would also not use 4WD on a hard road surface either - this can also result in some serious damage. :winkx:
Return to “Meet the People”
