Hi All
Maybe someone can shed some light for me
So i have the Prado 3 weeks now every so often when idling stall at robot ,starts first time then happens
again .
So after some research ,decided to clean throttle body and MAF sensor ,but when i removed rubber pipe and MAF sensor all looked very clean ,
I saw this though
so feels like a crack to me could this cause stall and how do i repair
Martin
Prado stalling
- Real Name: Marnus
Re: Prado stalling
Are you talking about those lines visible at 6-o-clock? If he throttle body is cracked there it can mean it is sucking in air there which would be more than the throttle position sensor is indicating the computer should expect which could serve to confuse it. But it would have to be a big enough leak to confuse the system.
To test I would try and tape it up on the outside with insulation tape or duct tape just to stop any air leaks and purely as a means to check if there is a leak to begin with and if it has an influence. Just make sure the throttle body is clean enough to get a good enough seal with the tape.
If it leaking and causing the problem you are probably best off by just replacing the throttle body.
Hope this helps in some manner.
- mcw
- Town: krugersdorp
- Real Name: Martin
- Club VHF Licence: X100
Re: Prado stalling
Yes those lines at 6 o clock ,can feel they ridges with finger , wanted to look this past weekend ,but burst geyser got in the way ,will strip this weekend and try to seal from outside and test
Tks
Martin
Tks
Martin
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Re: Prado stalling
Martin Prattley steel
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- mcw
- Town: krugersdorp
- Real Name: Martin
Re: Prado stalling
hi Quentin
will be taking throttle body off this weekend and looking at whether it is cracked and how to fix it
car goes very well ,just will not idle for longer than 30-40 seconds in drive ,in neutral idles perfectly at around 950 rpm
Martin
Martin
- Dadz Toy
- Vehicle: 95 Series Prado - Diesel Dog
- Real Name: Richard
- Club VHF Licence: HC 286
Re: Prado stalling
Sure it's not a "Blou motion" Prado??
Is it stalling with your foot on the brake in Drive or without?
Rich
Rich
Rich
- mcw
- Town: krugersdorp
- Real Name: Martin
Re: Prado stalling
Hi Richard
will have to check SWAMBO drives her daily ,i am allowed to sit inside some weekends ,mainly to vacuum carpet and polish dash
Martin
Martin
