overheating problem 2.4 surf
banditpete
Town: Bridport
Vehicle: ssr 2.4 td
Real Name: Peter
Post by banditpete »
Hi guy's. Have a overheating problem with my 2.4 surf. Have replaced the head, has new radiator waterpump viscous fan. Round town runs perfect but any load on the engine cause's the temp up. Have even taken the thermostat out so should run cold. Only thing I have not re connected is the air con pump. Can anyone help or think of something I have missed.
Pete
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Re: overheating problem 2.4 surf
Post by The Legend »
Peter
Did you clean you radiator properly,did you use Toyota antifreeze and last thing did you replace your radiator cab with original Toyota one?
You've looked at all the obvious stuff that covers cooling, so now you have to look at excessive heat generating factors like incorrect fuelling. Have you cleaned the MAF sensor, checked diesel pump, filters (fuel and air) and injectors? :think:
banditpete
Town: Bridport
Vehicle: ssr 2.4 td
Real Name: Peter
Yes correct fuel and changed the rad cap. Will have a look at the maf sensor and diesel pump. coolant and rad cap are otp's
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Might be, and I sure hope its not the case, that you have a crack in the head you have put on.
Even though it might have been pressure tested, the head need to be heated to operating temperature and only then tested.
This happened to me previously, and believe you me we struggled to find the crack.. It tested perfectly when cold. My car would drive with the heat gauge almost stuck at a certain level, and then all of a sudden the temperature would climb fast and very high when going up a hill.
Hope you get to the bottom of this...
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
Knuppel
Town: Somewhere in Africa
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Post by Knuppel »
How sure are you that its really overheating, may just be the gauge having a problem or does it start spewing steam?
Image Link Broken
banditpete
Town: Bridport
Vehicle: ssr 2.4 td
Real Name: Peter
Bosfebok wrote:Might be, and I sure hope its not the case, that you have a crack in the head you have put on.
Know nothing is guaranteed but it is a brand new head
banditpete
Town: Bridport
Vehicle: ssr 2.4 td
Real Name: Peter
Knuppel wrote:How sure are you that its really overheating, may just be the gauge having a problem or does it start spewing steam?
bypassed the original temp gauge with a dash mounted one. Doesn't spew steam. Only overheats when going up hill when the engine's under load. Will happily sit at just below halfway whilst pottering round town or on the flat
Knuppel
Real Name: Marius
Post by Knuppel »
Here is another wild thought for you.
Is the radiator new or refurbished?
Had a case once when a cruiser kept overheating after it broke the fan belt. No matter what you did it started to get hot when it saw a hill. Eventually we removed the radiator again, after it was sent for cleaning and checking, and saw that the tubes inside had expanded to such an extent that they block the airflow through part of the radiator. We re-cored the radiator and then problem solved.
What happened was when the v-belt snapped the engine overheated and the release on the radiator cap could not vent the steam fast enough and it then popped the normally oval tubes into round tubes. Not very obvious unless you do a personal inspection looking for that specific problem!
Image Link Broken
banditpete
Town: Bridport
Vehicle: ssr 2.4 td
Real Name: Peter
Brand new rad as were all the parts I have replaced
