2010 D4D 4x4 Clutch size?
Posted: Fri Mar 03, 2017 12:25 pm
by honn1
Anyone know what the OD size is for a 2010 Hilux D4D 4x4 clutch? Is it a 260mm or 275mm ?
Re: 2010 D4D 4x4 Clutch size?
Posted: Fri Mar 10, 2017 6:14 am
by honn1
Nobody? Ok just replaced it so if anyone is interested. The standard Hilux clutch plate is 260mm and the Legend 40 is 275mm
Posted: Fri Mar 10, 2017 7:30 am
by Mikie
Why would they differ? Thought the Legend was only a cosmetic upgrade
Posted: Mon Mar 13, 2017 5:24 am
by honn1
Not sure but just did mine. Mechanic said the 260mm clutch fits and works fine but the 275mm will obviously last longer and was an upgrade due to all the clutch issues that the Vigo model had.
Posted: Wed Mar 15, 2017 11:36 am
by Cinco
Mine is 2011 model and is 275mm.
The first time I ordered a kit, a few years ago, a 260mm arrived as that seemed to be the standard as mentioned, at that time. The after market catalogues only showed the 265mm. Now most catalogues show both.
