Rear window in double cab hilux 4x4 2007 won't go up
- marlin control
- Town: cape town
- Vehicle: hilux 4x4
- Real Name: andrew
- Club VHF Licence: HC-200
The back drivers side window won't go up, is there a window locking master switch on the Hilux d4d 4x4c2007?
Re: Rear window in double cab hilux 4x4 2007 won't go up
If the other windows are operating, then it's most likely not a "lock switch" or fuse. I would say either a loose connection or the servo motor itself.
A loose connection could be at the switch or servo ends, but if the driver's master control switch also doesn't operate the window, then I would look at the servo side (inside the door panel).
- marlin control
- Town: cape town
- Real Name: andrew
Thx, will check it.
- Town: Midrand
- Real Name: Nishan
the spot welds on the scissor mechanism seem to be a weak spot. Does the motor run/try to run when you toggle the switch?
Perhaps remove the door pad and check the mechanism is in place and working
Real drivers use three pedals
- dalkill
- Town: Cape TOwn
- Vehicle: 2.4 GD6 SR D/C 4x4
- Real Name: Shaakir
my one rear window also seems to be a bit sticky... it goes up smooth till certain point and then just slows down, till fully closed... i'm thinking maybe rubber at that point bit worn... maybe you have same problem ??? doubt it would cause window not to close, but worth a mention...
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
- marlin control
- Town: cape town
- Real Name: andrew
All sorted, it was the auto locking switch on the drivers door consol, that had been activated, by mistake. All windows were locked except the drivers winow. The button was deactivated, and all windows now work, as they should. Thank you.
Glad to hear it was something simple.
