Bad miss
Posted: Mon Jun 11, 2018 8:14 am
by Alan river
I have a 2004 2wd with the 3RW petrol engine. Have a bad miss it’s ok at idle not good as soon as I increase the revs. It is also pulsing through the air cleaner. Have checked vacuum hoses and replace plugs, plug leads and coil packs. Not sure what to do next
Re: Bad miss
Posted: Mon Jun 11, 2018 10:06 am
by dd6
Pulsing through the air cleaner almost sounds like a timing issue?
Re: Bad miss
Posted: Mon Jun 11, 2018 10:18 am
by pietpetoors
Did the problem appear after you worked on the vehicle or did it just start by itself?
Re: Bad miss
Posted: Mon Jun 11, 2018 10:20 am
by pietpetoors
What is a 3RW engine?
Re: Bad miss
Posted: Mon Jun 11, 2018 10:39 am
by Mars
Or it could be an inlet valve.
Re: Bad miss
Posted: Mon Jun 11, 2018 1:42 pm
I think he means a 3RZ motor.
Re: Bad miss
Posted: Mon Jun 11, 2018 2:23 pm
by Alan river
Yes I mean 3RZ and it just started while driving around town . Have not been working on at all
Re: Bad miss
Posted: Mon Jun 11, 2018 2:25 pm
by Alan river
Have had compression test done and was told it is all good
Re: Bad miss
Posted: Mon Jun 11, 2018 6:29 pm
If the compression test was genuinely good, then the chances of a valve problem are slim. Generally these are hardy motors that can take some abuse and don't give many problems.
Without the blow-back and considering what you have already replaced (including the compression test), I would perhaps be thinking along the lines of a dirty / partially blocked injector.
The fact that you are getting some bl;ow-back through the intake is puzzling and as mentioned could be a timing issue, but it would have to be badly out of spec. Then why would the timing go out of it's own. I'm not convinced even though it is a possibility.
Re: Bad miss
Posted: Wed Jun 13, 2018 9:49 pm
by LouisZ
Check the idle control valve on the throttle body. It become stuck and needs a good cleaning.
