Hello All
I am looking at putting a set of Powerbrake disks and pads on my Mk6 Hilux and there are 2 pad options, listed below;
Bendix Ultimate brake pads = R1,950.40 - Blacks
Powerbrake PB05 brake pads = R3,650.10 - Reds
Has any one got either of these and know if the reds are worth the extra money? Its a massive difference in price and I cant believe they are so much better to warrant the price, but I may be wrong.
Blacks http://www.powerbrake.co.za/Bendix_Ulti ... b1482u.htm
Reds http://www.powerbrake.co.za/Powerbrake_ ... b05-za.htm
Many thanks
MIke
Powerbrake Pads - Reds or Blacks
- climbingmike
- Town: Hartbeespoort
- Vehicle: Hilux mk6
- Real Name: Mike
- Real Name: Marnus
Re: Powerbrake Pads - Reds or Blacks
Hi Mike.
The red pads would be a waste of money if you do normal driving and all that you need is improved braking. I used the Bendix Ultimate brake pads and they work perfectly.
The reds are more for extreme braking performance where you expect the pads to get very very hot like when pulling a heavy trailer through mountain passes or frequent repeated high speed braking.
The Bendix pads for your bakkie are even cheaper - R1719.25.
- climbingmike
- Real Name: Mike
Hello Marnus
Thanks for the info. Thats good news as I really didnt want to spend that much on pads ;)
