Hi all.
I have a 2004 legend 35 with the std mags and tyres.
If correct 245x75x15.
My question is what mag and wheel size could I go to comfortably without any modifications and obviously no rubbing.
Thanx
Tyre Size
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Re: Tyre Size
you can keep the rim, i can easily say the 31x10,5x15 fits no prblem, en gives a substantial bit of lift from ground.
- Town: Gauteng
- Vehicle: Legend 35
- Real Name: Greg
Re: Tyre Size
Great
Thank you
Thank you
- Town: Windhoek
- Vehicle: 2000 Toyota Hilux 2700 DC 4x4
- Real Name: Nick
Re: Tyre Size
Ive got the 31x10,5x15 fitted on the 2000 Hilux DC, Ive been told it is as big as you can go without mods. It does touch a little front left when doing a full turn, cant remember when turning to which side, ill check and come back to you.
- Town: Gauteng
- Real Name: Greg
Re: Tyre Size
Thanks all.
Re: Tyre Size
There is a knob on the right side mud flap on the inside. The 31 inch touches that knob sometimes. You can easily just cut it off.
31" no problem, 32 " you will have to modify.
- Town: Gauteng
- Real Name: Greg
Re: Tyre Size
Awesome thank you for the efforts guys.
As a side note is it possible to put on a larger mag than the 15inch.
- Town: Gauteng
- Real Name: Greg
Re: Tyre Size
Hi guys.
Thoughts on actually going to a narrower tyre format
Could one do a 205 wide tyre or is that going to narrow.
