Hi Folks
Have a 2012 3.00ltr D4D Invincible Hilux with leater seats, and the two buttons on the dash for them all wired up
However when i try to switch them on, no heat in seats ?
There is a lotof wires under the seats so presume they should work
Any help will be appreciated
Thanks Ian
Heated seats
- Town: Falkirk
- Real Name: Ian
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Re: Heated seats
First check the fuse, probably behind one of the kick panels in the driver/passenger footwell. The owner's manual should tell you where and which fuse.
If that fails, you should be able to find a workshop manual here on the forum, with the appropriate wiring diagram, that will identify the correct wires. A cheap multi meter will tell you if there is at least voltage coming to the heaters and if the circuit is complete.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
