Brakes shudder or does not release while parking/ maneuvering
Fugax
Town: LANGEBAAN
Vehicle: Toyota Hilux GD6 2.8
Real Name: Eastwood
Post by Fugax »
Hi. I am new to the forum.
My Hilux 2016 2.8 GD6 DC AUTO 86000 km SHUDDERS/ LOCKS/ DOES NOT RELEASE BRAKES wile maneuvering into garage or parking spot.
Agent is suggesting skimming of discs as first step ( tested at 120 kph). Note: There is no wobble of front wheels at any stage/speed.
I live on the West Coast 800 metres from the waters edge.
Have done some High RANGE 4x4 mud terrain and beach driving (NAM).
I am planning a caravan trip within a week and feel uneasy to proceed.
An expert opinion will be much appreciated.
Thank you
Re: Brakes shudder or does not release while parking/ maneuvering
Hi and welcome. If your brakes are binding, first thing is to check out which wheel/s are getting hot, if any. Walk around the vehicle after a short drive and feel all the hubs for heat.
If none of them are getting hot then it's more likely to be the rear and could be related to the parking brake mechanism or if the rear are hot it could just be the ratchet adjustment having taken up too much slack. Another possibility is the shoes themselves are binding. (There's a thread here on setting up rear drum brakes, just do a search).
If the front or all are getting hot, then it's probably a booster problem. Usually the front are hotter because the front calipers provide a lot more braking friction than the rear drums. if it's just the front, this can sometimes happen when fitting new pads but I doubt that's the case here unless you have recently replaced the pads, but you make no mention of that so to my mind it's then more likely to be that the booster is the culprit by allowing the vacuum on the other side of the diaphragm inside to apply brakes even though your foot is not on the brake pedal. Next time when it''s actually binding, preferably on a slight incline, where the vehicle remains braked while it should start rolling, then turn off the motor and see if it starts rolling after a few seconds. If not then depress the brake pedal a few times so as to help relieve the vacuum negative pressure .... it may take as many as five or six pedal pumps. If it still doesn't start rolling then it's not likely to be the booster but don't rule it out altogether.
Hope you come right.
Fugax
Town: LANGEBAAN
Real Name: Eastwood
Post by Fugax »
Brilliant answer. I went to my nextdoor neighbour. (Merc and Landie mechanical expert. Tested drum temp. Right rear. Adjusted little ratchet "weel". All is well. Appreciate your thorough suggestion and description. 11/10
Glad to hear that you got it sorted. :thumbup:
Just keep it in mind should you start experiencing similar symptoms again. If it has happened once, it can happen again .... especially if there is excessive wear or damage on any of the brake mechanism components in the drum. It may however just be an isolated incident where the automatic adjustment has prematurely advanced to the next click of the ratchet wheel. :winkx:
