Correct tyre pressure: BFG 31X10.5x15?
- Jaco Versfeld
- Town: Western Cape
- Real Name: Jaco
- Club VHF Licence: X69
Hi There,
What is the correct tyre pressure for road use for BFG 31x10.5x15 ATs?
Thanks,
J
Thanks,
J
- truckin
- Town: Durbanville
- Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
- Real Name: Juan
Re: Correct tyre pressure: BFG 31X10.5x15?
More Jaco
ek pomp my 31's tot 2.6 bar op die teer, en sak tot 0.8 bar as ek 'offroad' ry, maar dis mos maar n personlike ding, dit hang mos maar af hoe hard jy wil stamp
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
- arnize2
- Town: Wellington
- Vehicle: 2008 Toyota Hilux 3.0 D4D D/C 4X4
- Real Name: Arno
Ek pomp my bakkie se bande 2 voor en 2.1 agter en hulle loop gelyk af. Ry ook nie te hard nie.
Jaco, BF's is redelik 'hard' so om hulle so tussen 2.0 - 2.2bar the he sal OK wees
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Ek pomp myne 2.2 voor en agter op teer.As ek begin vrag dra gaan ek 'n bietjie harder agterOOOOMS wrote:Jaco, BF's is redelik 'hard' so om hulle so tussen 2.0 - 2.2bar the he sal OK wees
- Town: South Africa
- Real Name: Craig
I prefer to stick to the Toyota recomended pressure. See this thread: viewtopic.php?f=3&t=13253" onclick="window.open(this.href);return false;
Remember that you have an SFA which is a lot lighter then the Vigo shape therefore what works for the guys with that shape does not always work for your SFA. Toyota recomend 1.9 bar for a 215 x 75 x 15 tyre so for a 31" x 10.5" x 15" which is almost the same as a 265 x 75 x 15 you will be slightly lower in pressure. Generally the bigger the tyre the lower the pressure.
- cheetah
- Vehicle: 1994 Hilux d/c 2.2
- Real Name: Anton
gravel road- 2 bar
tar road- 2.2 bar
sand- 0.8-1 bar
rock- 1.4 - bar
tar road- 2.2 bar
sand- 0.8-1 bar
rock- 1.4 - bar
- arnize2
- Town: Wellington
- Real Name: Arno
Ek gaan op grondpad af na 1.7 voor en 1.8 agter. Dit gee nogal 'n heel gemaklike rit.
Stem saam, heelwat sagter en gemaklikerarnize2 wrote:Ek gaan op grondpad af na 1.7 voor en 1.8 agter. Dit gee nogal 'n heel gemaklike rit.
- 2.8 d/cab SFA
- Town: Boksburg
- Vehicle: Yamaha R1
- Real Name: John
BFG muds 2.6 highway, 1.1 offroad, rotate front to back every 10000km, wearing even
John
As Mark said, it's a 'hard' tyre .... this because of the thick 3 ply side walls. IMO 2 bar is more than enough on tar unless you are loaded at the back. I would certainly drop it a little for a longer stretch on gravel, about 1.6 ...... rocky terrain about 1 bar and soft sand 0.8 down to 0.6 if there are no sharp bends or side slopes. They don't be-bead that easily unless there are strong lateral forces.
- GooseMan
- Vehicle: Toyotal Hilux '96 Brospeed Branch and freeflow exhaust.Long range fuel tank.A Line Digger rims. 31 BF Goodrich All Terrain.
- Real Name: Adriaan
Dankie! Nou weet ek ook.
- Tiger7
- Vehicle: TOYOTA HILUX 2.7VVT-I SRX 4X4
- Real Name: Jonathan
foor 2.2 en agter 1.8. werk vir my
Foor is harder om bullbar en winch te dra.
Agter is meestal leeg so 1.8 is al wat nodig is.
- Town: Joburg
- Vehicle: Hilux 2.2 SFA 1994
- Real Name: Brett
Wow, quite a range. I have had recommendations of 1.2 off road, 1.6 on dirt and 1.8 on tar, but the tar pressure seems low. What are the recommendations for best fuel consumption/tyre wear of BFGs on tar with a loaded vehicle (I can survive a hard ride)?
A hard tyre will give better fuel economy because of a lower rolling resistance, but over inflating will cause excessive centre tread wear. As mentioned earlier 2 to 2.2 bar should be fine.
