Hilux almost caught fire
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Re: Hilux almost caught fire
Any idea what the ignition source was?
and i take it that the white sheen is the fire extinguisher powder?
Just glad you are not having to do a rebuild
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
Pierre, we are all keen to hear the full story. It may save some of us a lot of heartache & grief...
HABOOB means "Dust Storm"
Re: Hilux Fire problem
Is yours a petrol or diesel? How did you realise it was on fire? Close one.
- Kaaskrul
- Town: Port Elizabeth
- Real Name: Pierre
Diesel, 2014 model.
When I stopped, smoke came from underneath the bonnet. Had to use a fire extinguisher
- Kaaskrul
- Real Name: Pierre
Can someone merge this thread with the other one, dont knwo why it was posted twice.
- Kaaskrul
- Real Name: Pierre
I dont know how this happened.
I was on my way to a customer. To be honest, I was doing around 180kph for about 10km. When I took the turn off and parked at the top to turn left, I started smelling what was to me a plastic burn smell. Being in an Industrial area, I thought it was smell from a factory. So I drove on keeping to the 60kph speedlimit for another 5km.
Stop at customer and walked into Building. When I came out after about 30min, I still did not see anything wrong, but when I opened the door the smell smacked me in the face. First thing I popped the bonnet. Then only did WHITE smoke appear. There was no flames. But smoke kept on coming out the carpet like crazy.
I thought once this go over into a real flame, the bakkie will be a gonner. So I grabbed the clients fire extinguisher and gave it two decent squirts. It kept on smoking!! Extinguisher did nothing. Then I took my wheelspanner from behind the seat, and started hitting the carpet pieces off, where the smoke was. Only when those pieces fell to the ground, the smoke stopped.
I had it towed to Toyota. They also never saw something like this. We decided it must be a aircon leak, and that the oily substance in the gas was the guilty party that ignited. The aircon was tested, no leaks whatsoever.
Toyota checked everything, for oil leaks around gearbox, or turbo, or engine, NOTHING.
We went out today to test it again, this time with extinguisher inside bakkie he he he. We nailed it for as far and long as we can, nothing happened.
For now, the only thing making sense to me, is that the bakkie must've over fueled, and at the high speed EGT temps went to high and ignited that carpet? That carpet is flame proof. Reason why it did not catch fire, but it did how ever start to smoulder and smoke. Another thing, teh day before I was teh engine bay with engine cleaner, but did hose it off with my WAP. Toyota say it can be that some of the engine cleaner was left behind the carpet, and that ignited?? Actually, nobody is sure.
So any ideas or solutions will be appreciated.
- Kaaskrul
- Real Name: Pierre
That carpet started to burn from the bottom, up to the Aircon pipes.
CAT is removed, so heat build up in exhaust it cant be.
Std heat shield above exhaust is still in place also.
- Drifter X
- Town: Fourways
- Vehicle: Toyota Hilux Kzte
- Real Name: Ranesh
Scary stuff, glad you managed to save the vehicle from burning up.
- jafman
- Town: Karachi
- Vehicle: HILUX RAIDER HERITAGE EDITION 2011 V6 4.0
- Real Name: Salman
Intriguing...
What's on the other side of the firewall under the aircon pipes?
According to the pic it seems that this point was the hottestTo God be the glory
interesting .....
A fire requires three things :
- material to burn
- oxygen
- source of ignition
Since the carpet is not flammable the source of ignition had to be applied for an extended period.
oxygen .. no issue in this case. In some fires a lack of oxygen cause the material to heat up in a smoldering state, then when oxygen is added you get flash over, clearly NOT the case here.
Source of ignition ... well here we have a few "standard" possibilities
* Electrical .. dont seem to be any wires in the area.
* "Heat" ...Pierre dealt with that in his last post. QUESTION - any possibility of a hearline crack in the exhaust system (from the manifold, through the turbo, down the pipes) which could direct hot exhaust gasses onto that area ? Extreme speeds will cause the system to run at higher temperatures and who knows ..... BUT, then I would expect to see more heat damage to the air-con pipes.
* Fuel .... I have actually been in a petrol vehicle when a fuel line cracked and sprayed fuel in the engine bay ! SCARY ! We were fortunate to be in town and stopped at a robot when the smoke came out from under bonnet. BUT, we know diesel dont "burn". And if it was a fuel burn it would be spread over a wider area.
* air conditioning system - the AC gas DONT burn, not the stuff we use. Some German vehicles do use LP-gas though !! The oil use in refrigeration system dont burn either, cant as it is used in direct contact with electrical connections on other systems.
nope, VERY strange incident. Would love to hear the final verdict on this one
- material to burn
- oxygen
- Kaaskrul
- Real Name: Pierre
For now I will put my money then on cracked exhaust.
Only thing that makes sense to me now.
Will have it checked out and give feedback
Jou foto gewys vir 'n pel van 'n workshop.
Hy het al so iets gesien op 'n Kz. Glo na 'n lang soektog die positiewe draad van die battery het deur geskuur en op die aircon pyp geshort. Die condensor is op rubbers gemount, dus loop die krag teen die pyp op en short teen die body - dan kry jy jou eie mobile braai!
Kyk daarna, dalk is dit ook so met joune?
- Kaaskrul
- Real Name: Pierre
I found the problem.
Will upload pictures a bit later, struggling with photobucket.
Where the down pipe from Turbo connects onto exhaust system, I have a leak!!
The heat from there also melted plugs on my gearbox
Pics later will tell the story
- Kaaskrul
- Real Name: Pierre
Im giving up trying to load pics.
Eina pyn. Dalk 'n goeie roep om die gearbox olie ook te vervang na dat dit so warm geword het
- Kaaskrul
- Real Name: Pierre
Die heatshield vd exhaust het ook al begin smelt.
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
Well at least you know where and how and what to do to fix it. Glad it didn't turn out worse.
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Pierre
Beteken dit nou dat jy nie 180 km p/u met die Hi-Lux mag ry nie?
Hey, any day we spot serious danger before it costs us money is GOOD DAY !
GLAD you found the culprit. Should be a cheap fix - at the leaking exhaust ....
But checking everything around it, replacing the gearbox oil etc, but more shlep, but certainly well worth it.
You wanny why I thought of a leak in the exhaust - Toyota Corolla started using water, but nobody could find the cause, not even the dealers. So one afternoon I asked my MIL to open the bonnet, just after she came back from the shops. There is a steal pipe along the engine from the water pump, and T-ing off to the water heater in the car. Had a pin hole leak on the T section. Only under pressure would it leak, squirting the water straight onto the exhaust.
check eers die bande druk en dat die exhaust okay is, DAN mag jy maar RY .....The Legend wrote:Pierre
- The Legend
- Real Name: Dawie
ChrisF wrote:check eers die bande druk en dat die exhaust okay is, DAN mag jy maar RY .....The Legend wrote:Pierre
- Kaaskrul
- Real Name: Pierre
Goeie verskoning om na maar daai 76mm sisteem te laat bou
Ek sal bekommerd wees!
As daai alu plaat smelt se dit die gas wat by jou turbo uitkom is dan hoer as 660 grade. Jou EGT's hardloop sekerlik te nabyaan die limiet(720)?
Het hy 'n chip in?
Het hy 'n chip in?
Of bestel De Graaff se aanbout sisteem?Kaaskrul wrote:Goeie verskoning om na maar daai 76mm sisteem te laat bou
- Kaaskrul
- Real Name: Pierre
Het gekyk na De Graaf sin. Te duur.
Ja hy het n chip in. Daarom het ek die manifold vermoed van dag een af.
Watter chip?
Klink of jou trok overfuel en die egt's weg hardloop. Volgende stop is 'n gekraakte head of gesmelte piston!
- Kaaskrul
- Real Name: Pierre
Chipbox.
Maar ek het hom klaar uitgehaal, hy gaan nie weer terug in bakkie nie
Chipbox is glad nie nice nie. Al wat hy doen, is jaag die diesel druk op in die Fuel Rail, en daarom kry jy wat ek nou gekry het
Sal nou maar n Uni Chip van SAC laat insit saam die exhaust
- Kaaskrul
- Real Name: Pierre
I went back to Toyota. They say its not their problem.
So I went to Powerflow, they check and tested, say there is no leaks on exhaust.
So what now??
Can the EGT, turbo heat and manifold heat get so high that it will melt a plastic plug on gearbox??
I feel frustrated, want to fix this but dont know where to start.
So what now??
COLD engine, start and let it idle. immediately apply soapy water to the exhaust and check for bubbles ....
my guess - no bubbles, and no leaks at normal operating temperatures.
add an EGT, keep the chip in, then drive it that hard again ,,,, and see just how those temperatures go .... now to try and get it onto a ramp without allowing time for it to cool down, bet you will then spot the leak .... except now the bubble trick wont work ...
- Kaaskrul
- Real Name: Pierre
Viper and also De Graaff have a 76mm full system from the turbo to the back.
About the same price.
Any one have experience with these two systems?
- Kaaskrul
- Real Name: Pierre
I'm still trying to sort this out and see what happened where, but as far as I go everyone blames someone else, and those who cant blame nobody say they cant find the fault. Had two okes also who turned the cold shoulder on me.
But I will leave the arguments, and move on.
Just a friendly warning to all, beware of the Chip Units out there, that only increase Fuel rail pressure.
Over fueling is a female dog, and when it bites, it bites hard
- 4x4BEES
- Real Name: Kevin
Sorry to hear that boet.
Glad it wasn't worse and that you can still drive your bakkie.
- Kaaskrul
- Real Name: Pierre
Bakkie booked for Dyno tune
76mm De Graaff system plus Unichip.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Lekker manKaaskrul wrote:Bakkie booked for Dyno tune
Interessant oor die chips.
Kan mens nie daai turbo upgrade.Hy lyk darm klein.
Hoop dit gaan goed daar
