OILS/FRONT AND REAR AXLES
- hentey
- Town: worcester
- Vehicle: 2700i 4x4
- Real Name: hentey pople
When my Lux struck the 200k on the speedo the other day I thought it good to spoil her a little by changing all the oils in the gearbox,transfer case,and the 2 axles.So I dived into the owners manual and made the list of oils needed.The 2 axles take different oils Front: 1.6 lit SAE 90 API GL5
Rear : 1.7 lit 85W 140 API GL5
Fine I thought and off to the spares shop.Got all the oils except for the front axle.And that was the nice part.......
According to the manager of the spares shop will the correct oil for the front axle only be available at the stealers.Could this be right,and if so ,why???? We started talking and he told me things(if true)that would blow your mind.Certain oils are manufactured for the distrubution by certain car manufacturers only,and that protects the stealers.Is this not the same as price fixing? And I thought the electrical trade was corrupt.
What do other 2.7 owners do to solve the problem? Buy at the stealers? My ar$e!!!!!!!
Re: OILS/FRONT AND REAR AXLES
C'mon Bretton! You're the guy with all the oil knowledge!
Poppy Cock :!:hentey wrote:When my Lux struck the 200k on the speedo the other day I thought it good to spoil her a little by changing all the oils in the gearbox,transfer case,and the 2 axles.So I dived into the owners manual and made the list of oils needed.The 2 axles take different oils Front: 1.6 lit SAE 90 API GL5
That's why we call them Stealers
You can use the same Oil in front and rear diffs, transfer case and Manual Gearbox in an SFA Hilux
Total EP SAE 75w-90 Handratkas Olie es Lekker mos
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
I agree with Rich, I have been running Castrol EPX 80W-90 GL5 in diffs and gearbox. Great oil, no problems.
Sifu-Lux....I will miss you
Also use Shell Spirax Axle oil 85w - 140
- hentey
- Town: worcester
So what you guys tell me is that the manufacturers want to confuse uninformed people like me.
This is nogal hard to digest.I trust you people would not lead me into the ditch.Thanx for your replies
- dalkill
- Town: Cape TOwn
- Vehicle: 2.4 GD6 SR D/C 4x4
- Real Name: Shaakir
just a bit of sidetrack question...
does the 2.7 have front axels. I thought that ended with the SFA?
TOYOTA IS MY LEWE
TOYOTA IS MY LEWE
- hentey
- Town: worcester
Thanx,done that. 8 )OOOOMS wrote:Also use Shell Spirax Axle oil 85w - 140
- hentey
- Town: worcester
Dalkill,a little bit technically challenged here but it still has an axle,not solid but still.It's much shorter (hard to admit for any man) but it's still there.dalkill wrote:just a bit of sidetrack question...
- Town: South Africa
- Real Name: Craig
I recently replaced all the oils i.e: both diffs, gearbox and transfer box in my SFA. I phone around to get prices of oil from the various outlets and when I phoned Toyota they were R28.72 for the gear oil and R23.10 for the diff oil ex VAT. This was a lot cheaper the I could get it from any other outlet. They also had the 75W-90 GL4 gear oil which no other outlet had and that is the oil the SFA needs to use. The diff uses 85W-140 GL5. I was supprised that Toyota was so much cheaper then the other outlets.
Previously I had serviced my truck and in ignorance put in a GL5 oil into the gearbox. I don't remember the grade exactly but it was something like 80W-90. Although I never noticed the difference when I was living in Pietermaritzburg, when I moved to Gauteng and especially in winter there was a big difference. When the vehicle was cold I would battle to select 2nd gear from 1st gear. Sometimes I even had to stop to get it in. This was really only evident when the vehicle was cold. Since I have used the correct oil this problem is gone and I don't have to warm the vehicle up prior to pulling off. I can select 2nd gear no problem.
Proves to me anyway that the correct oil is imprtant. There is an article on the forum about GL4 versus GL5.
Use the correct oil, what does it matter if it is slightly more expensive then everywhere else you only change it every 40000Km anyway. But do yourself a favour and get a price from Toyota first before buying a cheep alternative.
- Town: Harkerville WC
- Vehicle: 1990 Hilux 4Y
- Real Name: Peter
Hi fellow SFA drivers. I am driving a '90 DC Hilux 4Y. After noticing a new whine from my drivetrain I decided it was probably time to replace all the oils as the first step. Not having an owners manual, I turned to this forum for advice, but after reading all I could find on what oils to use, I am more confused than ever. Would one of you fundi's please advice as to what spec oils I should be using in:-
1. Gearbox
2. Transfer Box
3. Front Diff
4. Rear Diff
Thanks in advance
1. Gearbox
2. Transfer Box
3. Front Diff
4. Rear Diff
Thanks in advance
- hentey
- Town: worcester
Hi Peter,just hang in there....untill Mr B reads this.He is THE guy to help you.He knows oils and in particular the SFA Hilux.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
I know this is a old topic but anyhows. I am in the process off replacing my gear box oil with a synthetic oil and I started doing some reading. The main reason for this is on my recent trip to Henties there was a point were i was driving for long periods in the soft sand in 4L second gear and I started to smell the oil.Before I get to the gearbox and transfer case oil i will just mention something I picked up on the diff oil.hentey wrote:When my Lux struck the 200k on the speedo the other day I thought it good to spoil her a little by changing all the oils in the gearbox,transfer case,and the 2 axles.So I dived into the owners manual and made the list of oils needed.The 2 axles take different oils Front: 1.6 lit SAE 90 API GL5
According to the manual the front diff take the SAE 90 API GL5. According to the manual if you have the Salisbury type diff where the cover plate is bolted onto the housing you need the 85W 140 API GL5.If you have the Banjo type where the cover is welded to the Diff then you need the same as the front diff SAE 90 API GL5. Mine is not bolted so I can use the the same oil as in the front diff.I am just going to use a standard good oil in the diffs since this should be replaced regular.
Back to the gearbox and Transfer case.At this point in time I am looking at Castrol Bot 130 75w/90 or the more expensive Bot 402 75w/85. I would like to hear from you guys what will be the best for me between these two.My main concern is that when the gears work very hard and it builds up heat that I will get the best lubrication.
Without starting a war what do you guys think of Shell Ultra for the motor
Cheers
- Town: Mooi River KZN
- Vehicle: 96 SFA D/C 4x4 2.4
- Real Name: Malcolm
Good morning all . Seems a while since this topic has run . I have a 2.4 sfa d/c 4x4 . Just recently got it . Havent ventured much in , I have definitely tested the 4x4 .. Unreal stuff .
I have just changed the engine oil with castrol 20w-50 .Oil that came out looked like black water .. Not great..
I would like to change all the other oils . Diffs , transfer box , gearbox .. Do i still go ahead with 75w-90 . or has something better come along since then . ? And how many litres do i need to cover all the changes ?
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
- Sifu-Lux
- Real Name: Andrew
Malcolm, look at the bottom of this post at the attachment viewtopic.php?f=34&t=8700
