Does anyone out there have the special service tool that holds down the shim cup so that the shim can be removed.
If so I would really appreciate it if they could take a photo of the tool alongside a ruler, as I would like to have one manufactured.
The toyota agent here in cape town dont do valve clearances on the 3RZFE they send it to Engineering workshops who remove the cams to get to the shims.
2700i, 3RZFE Valves
Re: 2700i, 3RZFE Valves
Ask Allan, AKA Hoppy on the forum, he will be able to give you the best advice.
- 3RZ
- Real Name: Willem Grimsell
There is a tool that depresses the bucket so that you can get the shim out, Toyota should have one or be able to order you one as it is a standard Toyota SST (Special Service Tool). I wil post you a picture and part number later today. Haven't got one myself might have a picture somewhere.
- 3RZ
09248-55040 is the Valve Clearance Adjust Tool Set (the two items below)
09248-05410 Is the valve lifter press
09248-05420 is the Valve lifter stopper
Still working on the pictures
- 3RZ
The part numbers above is similar to the on in the photo
http://www.amazon.com/Alltrade-648829-T ... B0002Q8TUK
http://www.amazon.com/Schley-SCH88250-T ... hi_title_0
26$ On Amazon, try e-bay as well.
Hoppy may have a cheaper homegrown solution
- Vehicle: Hilux 2.7 4x4
- Real Name: Wayne
Thanks that is exactly what Im looking for. By the way, the toyota dealers do not have these tools, they send the vehicle to engineering workshops who remove the cams to take out the shims, real heath robinsons.
