Cat removal?
- Mornes
- Town: Roodepoort
- Vehicle: Hilux 4.0 DC 4x4 AT
- Real Name: Morne
Cat removal?
can anyone give advice as to where my friend can take his v6 Fortuner for a decat? many people are interrested in doing it, but in our area no one seems to have done it before on a v6. we are in the Roodepoort/Randburg area.
Morne' Smuts
Toyota Hilux 2007 - 4.0 DC 4x4 A/T: TRD Supercharger, OME Suspension, Outback Canopy, 29Mhz Radio, 32 BFGR Tyres, Unichip, Echo 4 Trailer, Duel Battery System, Snorkel, ARB Bumper
Re: Cat removal?
Praat met Ralf Toyo Service Center (Ondekkers Weg naby die roadhouse). Hy sal jou kan help verseker,
0110996350
0110996350
- Mornes
- Town: Roodepoort
- Real Name: Morne
Re: Cat removal?
thanks!
Morne' Smuts
- Blackadder
- Real Name: Thinus
- Club VHF Licence: X82
Re: Cat removal?
Cat...???
Het my Tuna ook een...???
- Blackadder
- Real Name: Thinus
Re: Cat removal?
Cat...???
Re: Cat removal?
Cat = Catalytic Converter...
Re: Cat removal?
Cat = Catalytic Convertor...
- Town: Johanesburg
- Vehicle: 1999 2700i Hi Lux
Re: Cat removal?
JR'S Exhausts Ontdekkers road newlands.
They did a very good job on my Hilux
Speak to Tjaart jnr.(011 673 0138)
- Blackadder
- Real Name: Thinus
Re: Cat removal?
Terrible echo in here....
- Blackadder
- Real Name: Thinus
Re: Cat removal?
Another question if I may...???
Why take it out...???
- Mornes
- Town: Roodepoort
- Real Name: Morne
Re: Cat removal?
they say you can gain up to 7% with a de-cat. its like removing your tonsels..
Morne' Smuts
- kfxnando
- Town: Germiston
- Real Name: Fernando
Re: Cat removal?
Blackadder wrote:Another question if I may...???
catalytic converter = the most restrictive part of most exhaust systems = power loss = drop in fuel consumption
if SA can build coal fired power stations, then we dont needs cats either!!
enjoy!!
Re: Cat removal?
Remove it .... they just keep trying to drink our milk!!
- Fred79
- Town: Kent UK
- Vehicle: Toyota Hilux Icon 2.4
- Real Name: Frikkie
Re: Cat removal?
Sal dit 'n verskil maak op my 3.0D4D?
Ek het die storie gehoor een keer by 'n vriend wat dit met sy Isuzu 3.0 Auto gedoen het en hy praat net goed van die conversion.
- kfxnando
- Town: Germiston
Re: Cat removal?
the removal of any restriction always results in improvements !!
Re: Cat removal?
Will your vehicle afterwards still stand up to the CO emission laws over there?Fred79 wrote:Sal dit 'n verskil maak op my 3.0D4D?
- AM Racing
- Real Name: Dylan
Re: Cat removal?
The removal of a catalytic converter ALWAYS improves performance!!! We have done
VW's
Merc's
Jeep
Ford
Audi
There are a few ways
1. THE HACK
This involves the cutting of a small "window" in the cat, whether in place or removed, and hacking out the material with a hammer and long screwdriver. Then welding up the window.
Pro's: Cheap de-cat procedure, more power, cheaper than a cat replacement
Con's: Raspy exhaust note more resonance in the vehicle, extra heat through the cat shell can cause the floor to get warmer in that area
2. THE PIPE
This involves cutting out the cat completely and just fitting a straight pipe in its place. This is not always possible as on some vehicles the cat is part of the manifold. Typically non-turbo applications.
3. THE RESONATOR/SILENCER
This involves removing the cat and replacing it with a resonator type silencer that kills the exhausy resonance and absorbs a lot of heat. These usually start at about R1000 for supply and fitting at your local exhaust fitment centre.
Pro's: More power, quiet exhaust, no hot floor, cheaper than a cat repalcement
Con's: NONE
PLEASE NOTE: On all of the above; if your vehicle has an oxygen sensor before and after (pre and post) the catalytic converter you WILL need to have the vehicle re-chipped or a dummey O2 sensor (post) fitted as the engine management light will come on to show an emmisions fault. We have performed all of the above, the first two due to budget constraints on the clients part and are usually done as the cat is blocked.
We do not have emmisions monitoring as part of out roadworthy process so it will not affect anything in that regard. But if your vehicle is under warranty it WILL void your warranty. But it is the easiest horsepower gained on a modern vehicle.
VW's
Merc's
Jeep
Ford
Audi
1. THE HACK
2. THE PIPE
Con's: NONE
- BosveldBul
- Town: Centurion
- Vehicle: Hilux 3.0 D4-D 4x4
- Real Name: Jak
Cat removal?
So does my '06 3.0 D-4D have a cat?
- AM Racing
- Real Name: Dylan
Re: Cat removal?
Not sure on the 06 will do some research. My 05 2.5does note.BosveldBul wrote:So does my '06 3.0 D-4D have a cat?
- BosveldBul
- Town: Centurion
- Real Name: Jak
Cat removal?
Thanks, appreciated
- Town: Durbanville
- Vehicle: Isuzu E/cab 3.0 D-tec
- Real Name: Morne
Re: Cat removal?
Ek het n roomer gehoor dat as jy jou voertuig verkoop nadat jy die cat verwyder het , en moet roadworthy , dan sal jy nie n roadworthy sertifikaat kry as jou voertuig as standaard met n cat uitgekom het nie.Dit gebeur seker nog nie maar dit is definitief in die pyplyn. Het iemand anders al daarvan gehoor ? ( Ek hoop dit is net n roomer )
- AM Racing
- Real Name: Dylan
Re: Cat removal?
There is talk of an annual roadworthy like they do in the UK which will include emmisions testing, but I don't see this happening for a long time to come. We still have to many old vehicles here that never had cats. The taxi industry drives this at the moment. The only requirements at this moment is that the exhaust must not leak, must be secure and not be noisy. So de-cat away. I would say that the legislation is at 3 years away from implementation and I would suspect it would only apply to vehicles from that date.
- Pietman
- Vehicle: 2005 Hilux V6 4L D/C 4X4
Re: Cat removal?
Ek het my cat so 2 jaar terug op my 2.7 uitgehaal nadat ek die 3de boks moes vervang in 2 jaar. Het n' freeflow opgesit en my bakkie trek van toe af soos n' bul.
EX ALTO VINCIMUS
- Town: Adelaide
- Vehicle: Toyota camry altise. Till I find a replacement hilux.
Re: Cat removal?
To de-cat wont effect roadworthy. Its a case of if its fitted as an extra and not a standard SABS requirement, it must work. Cats are not gazzeted as a requirement. As for roadworhty every year, it has been in the pipeline since late 2004. Our infrastructure in sa wont handle it and with all the old cars etc. will take many many years to impliment. Lots of ducks for the gov. to get in a row in this regard before they can do anything anyway.
There is a madness about been mad that only a mad person can understand.
Diesel and dust is where home is at.
- VeeS1x
- Town: Pierre van Ryneveld
- Vehicle: 2010 Hilux 4.0l Double Cab 4x4, OME, TJM Winch, ARB Bumper, IPF Spots, LR tank, Dual Battery
- Real Name: Martin
Re: Cat removal?
Ek weet dis `n baie ou draad die, maar ek het wyd en suid gesoek vir advies en raad oor de-cat.
Ek het die plunge gevat en my beast laat de-cat.
:o
Klink soos `n dier, maar tog geen effek binne kajuit.
Gaan egter wel 2 klein ekstra boksies laat insit waar hulle die laaste 2 cats verwyder het net om die effense resonansie te demper.
Supa Quick Menlyn doen die ding gereeld en het `n merkwaardige job gedoen. Dit vat net `n tydtjie, so be warned...
Ek sal oor so `n maand terugvoer gee oor die petrol verbruik
PS: Die V6 se exhaust het `n deel wat baie laag hang en jou ground clearance lelik beinvloed - hulle het daai stuk pyp ook mooi flush met die res van die exhaust laat sny
:o
2010 Hilux 4.0l Double Cab 4x4 (Bismark MK2)
- Optimus Prime
- Town: Krp
- Vehicle: Fortuner 4.0 v6
- Real Name: Robert
Re: Cat removal?
Wat was die prys by hulle?VeeS1x wrote:Ek weet dis `n baie ou draad die, maar ek het wyd en suid gesoek vir advies en raad oor de-cat.
:o
"As long as power flows through any of my circuits ill 4x4."
- VeeS1x
- Real Name: Martin
Re: Cat removal?
Ek was R1350 armer maar dit het 2 dummy cats ingesluit - aparently nie nodig nie, maar ek het dit maar safe gespeel
- JEEPIE
- Town: Roodepoort
- Real Name: Shaun
- Club VHF Licence: X 43
Re: Cat removal?
en trek hy beter ?
- VeeS1x
- Real Name: Martin
Re: Cat removal?
Ek kannie regtig met eerlikheid sê nie siende dat hy alvorens klaar getrek het soos `n meneer. Hy voel meer responsive.JEEPIE wrote:en trek hy beter ?
- VeeS1x
- Real Name: Martin
Re: Cat removal?
Just some information on the "mini-cats" I keep referring to:
They are installed where your O2 sensor goes. Then your O2 sensor, in turn, screws into the mini-cat.
The internal structure of the mini-cat actually contains the same inner as a catalytic converter in order to supply you O2 sensor with more or less the same exhaust gases it received before the catalytic converter inner was removed.
Apparently mini-cats are not necessary for 4l hiluxes before 2012, but I had them installed just to have piece of mind. I dont want to have engine lights and warnings coming on when I dont need them, especially on a trip.
Have a look at the pictures below that shows what they look like
- mini-cat-cutaways.gif (134.68 KiB) Viewed 13715 times
- F1-X_SportLine_Mini_Cat.jpg (33.67 KiB) Viewed 13715 times
- TOYODA
- Real Name: Tiaan
Re: Cat removal?
Dankie Martin
Ek oorweeg om myne iewers in die volgende paar te laat doen.
Gelukkig is Supa Quick Menlyn nie te vêr van my af nie.
- BenRich
- Town: Boksburg
- Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
Re: Cat removal?
Doen julle self n guns en praat met Viper Performance in Kempton Park. Hulle werk is uitstekend!
- Vehicle: 2004 Toyota Hilux 2700i 4x2 DC
- Real Name: Dillon
Re: Cat removal?
Weet een van julle of my '04 2,7 dit in het? Ek het die "stage 1 conversion" by SAC gedurende 2008 laat doen en hulle het die uitlaat pyp verander asook die "chip" en die "airfilter" modifikasie. Hy trek reeds soos 'n 6 silinder of beter as sommige 6 silinders.....
Ek dink ek is in vir ten minste een boks want daar begin nou 'n resonasie voorkom as ek ry en as ek moet wil ek die CAT verwyder dieselfde tyd..
- Town: Somerset West
- Vehicle: Toyota Hilux 3.0D4D 4x4 D/C
- Real Name: Ryno
Re: Cat removal?
Het so 2 weke gelede my D4D hilux se cat uitgehaal en hy trek verseker beter en baie loop defnitief gladder.
- Sebata
- Town: Cosmo City
- Vehicle: '06 Hilux 4.0l V6 auto 4x4, Iron-Man front bumper, Ali3n Rock-sliders, Old man Suspention, Snokel, 31" Pireli Scorpion Muds
- Real Name: Tau
- Club VHF Licence: X125
Re: Cat removal?
Got my 4 cats removed last weekend, all I can say, WOW
Tau Sello
- Optimus Prime
- Town: Krp
- Real Name: Robert
Re: Cat removal?
TAUSebata wrote:Got my 4 cats removed last weekend, all I can say, WOW
Give some info price and place please.
- Sebata
- Town: Cosmo City
- Real Name: Tau
Re: Cat removal?
Did mine @ noise boys in Germiston,
4 cats were removed & mini cats were fitted on the sensors in front of the 2 cats @ the back
Then 2 small "cowley" silencers were fitted to minimize the rattle inside the cabin,
Steel pipe from manufault to the big silencer @ the back was fitted
All for R5 k
All for R5 k
Tau Sello
- War-Medic
- Town: Centurion
- Vehicle: Hilux 4.0l V6 D\C 4x4
- Club VHF Licence: X203
Re: Cat removal?
Got a quote from Supa quick Menlyn for R1600. Cat removal and the fitting of mini cat dummy sensors on my 4.0l Hilux. Not bad at all.
The direct use of force is such a poor solution to any problem, it is generally employed only by small children and large nations.
Mods: EFS suspension - ARB front bumper replacement - Warn winch - Rear sparewheel carrier bumper - 160l long range fuel tank - Toatal unberbelly plate protection - Canvas seat coners - Alu steel Canopy - Snorkel - Kenwood TK VHF Radio - Ctek 250s Dual batery system with solar pannel
Dit is 'n TOYOTA ding, jy sal nie verstaan nie........
- Town: cape town
- Vehicle: hilux 4.0 4x4
- Real Name: david
Re: Cat removal?
where does one get these mini cats ?
- Town: Kyalami
- Real Name: Mike
Re: Cat removal?
Arent they called Kittens??justaguy wrote:where does one get these mini cats ?
Re: Cat removal?
Heh... I was also tempted to reply in that vein...
