Hi All,
Can anyone confirm the bearing numbers on front wheel of 2002 2700i 4X4 HILUX raider.
Im not sure if the number will be the same for all makes of bearing but I want to get Timken.
Regards
Wayne
IFS front wheel bearing numbers
Re: IFS front wheel bearing numbers
See viewtopic.php?f=12&t=18847&p=210963#p210963" onclick="window.open(this.href);return false;
Also posted by Willem (3RZ) .... viewtopic.php?f=3&t=18444" onclick="window.open(this.href);return false;
Bearings by Bearing Agent (Timken)hv Schoeman en Prince's Park str Pta Wes
Tel 012 326 2551 praat met JJ
Inner Bearing - Timken KJLM104948/10 @ R144 elk
Outer Bearing - Timken KLM102949/10-TI @ R65.79 elk
Olie seel - 65x85x8 R17.55
Bearings per kant - R227.34
Seels by Toyota
Altyd Goeie diens by Dereck van Pta-Noord Toyota
Hub Lock O-ring part no 4353260010 R59.73 elk
Hub Lock gasket part no 4353160010 R34.06 elk
Axle Gasket part no 4342260010 R5.76 elk
Gaskets per kant R113.49
Gaskets beide kante R226.97
Bearings Beide kante R454.68
Per kant bearings + Gaskets R340.83
Albei kante Bearings + Gaskets R 681.66 - Toyota R1900 vir albei kante bearings + Gaskets.
Search and you will find!
Seels by Toyota
- Vehicle: Hilux 2.7 4x4
- Real Name: Wayne
Thank you sir, thats great. Now I can go to bearing man and tell them what they should already know. Regards Wayne
- 3RZ
- Real Name: Willem Grimsell
Wayne you do not need the hub lock o-ring if you are not going to disasemble the hub lock. I bought the hub lock gaskets and the axle gasket but did not use them as the old one's were still in perfect condition.
- 3RZ
Just an update - Rather use the genuine Toyota oil seal 90311-66003, I have had 2 of the cheap generic oil seals pop out and rub agains the axle causing the seal to overheat and spill some of the grease.
