Old Man Emu bushes
Wayne
Vehicle: Hilux 2.7 4x4
Real Name: Wayne
Old Man Emu bushes
Post by Wayne »
Can someone please confirm whether there should be a steel sleeve in the bushes through which the bolt goes.
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Re: Old Man Emu bushes
Post by zepplin »
No steel sleeve. At least not on an SFA.
Wayne
Real Name: Wayne
Post by Wayne »
Oh ok, thanks, that is surprising to me.
LouisZ
Post by LouisZ »
Hi Wayne,
On the 2.7 IFS the bush in the front has a steel sleeve, on the Shackle at the rear no sleeve is needed.
Louis
Wayne
Real Name: Wayne
Post by Wayne »
Hi Louis,
Thanks for the info.
Does OME supply those sleeves or are they the same as the original toyota sleeve?
Regards
Wayne
LouisZ
Post by LouisZ »
Wayne,
I looked, it is not there as a part no. But what you can do is measure the Toyota ones and compare to these dimensions;
19 outer dia
14.1 inner dia
68mm long.
Also see if Cape town Mega do not some laying around, you never know.
