3RZ Engine
- LouisZ
3RZ Engine
The Pulley problem went further. It somehow damaged the crank bearings. Huge knock now from the inside of the Engine.
Well before I decide otherwise, where can I find a decent recon, 2nd hand 3RZ?
- Town: Centurion
- Real Name: Everdt
Re: 3RZ Engine
Ai, dis nou slegte nuus - so in die nuwe jaar
Re: 3RZ Engine
Are you sure the knock is from the crank bearings? Not the new pulley itself or the balance shaft?4x4megaworldpta wrote:The Pulley problem went further. It somehow damaged the crank bearings. Huge knock now from the inside of the Engine.
- LouisZ
Re: 3RZ Engine
Small pieces of silver soft metal in the oil...
Re: 3RZ Engine
Eish!!
- LouisZ
Re: 3RZ Engine
The thing is one spend good time on the initial problem and one gamble that nothing else will be wrong. Well after the pulley was done I drove about 40km and then engine noise became heaver, Knock knock and then no power. It will start but hell that knock.
Re: 3RZ Engine
As I understand the pulley drives the oil pump. So if the pulley comes out far enough the oil pump will stop turning. If you do not stop quick enough you will damage the bearings. Most probably what happened here.
- Big D
- Vehicle: SFA Hilux 2.2 BFi
- Real Name: Deon
Re: 3RZ Engine
Jammer om te hoor Louis.
Ek sien die chinese maak ook n 3rz, ek wonder hoekom ons engine importers nie hulle inbring nie.
Anders is dit tyd vir lexus...
- LouisZ
Re: 3RZ Engine
Just to confirm. Engine out and this in the sump.
- 030 (640x480).jpg (286.43 KiB) Viewed 2160 times
- 029 (640x480).jpg (274.28 KiB) Viewed 2160 times
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
Re: 3RZ Engine
Eina.............
On closer inspection I think a 5VZ will fit that bellhousing perfectly Louis!
- LouisZ
Re: 3RZ Engine
Steve now you tell
The replacement 3RZ is already in, finished Friday night after 1am. I must say it pulls much better with the replacement in.
- Town: Centurion
- Real Name: Everdt
Re: 3RZ Engine
Was dit toe die cranck bearings wat seer gekry het?
- LouisZ
Re: 3RZ Engine
Ek het so fyn langerige metaalstuk op no1 crank bearing losgewikkel, so ja dit is. Ek het nie verder gestrip nie. Dis 'n ander projek op 'n ander tyd.
Dis so 3km wat ek gery het vandat die pulley losgekom het. Eerste keer wat ek gestop het was die belde pap.
So as julle sien die Engin word warm, battery lig gaan aan STOP dadelik en kyk dadelik vir 'n los crank pulley.
Ek sal se dis punt no.1 om te kyk na.
- Danman
- Real Name: Danie
Re: 3RZ Engine
Baie bly jy het reggekom met die 3rz(al was dit teen 'n prys) daai mooi wa se wiele moet draai nie stilstaan nie.
- LouisZ
Re: 3RZ Engine
Dis 'n Pil om te sluk maar ek is bly is klaar.
Die meeste van die ou engine is gebruik op die "nuwe"een. Soos die Airconbracket, engine mounts, throttle body, meeste lug en water pype, flywheel en clutch en natuurlik die ou sump en laastens die coils en drade.
Verder was dit maar net geduld en mooi kyk om die goed reg te kry. Die Sensors en die drade was perfek gematch.
