65mm masonary drill.
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
Does anyone in Cape Town by any chance have a 65mm carbide grit masonary drill which I can borrow for a couple of hours?
Fitting a split unit aircon and don't really want to fork out R180 for a new one. That equates to R 90/hole.
Re: 65mm masonary drill.
The guys from the mines up north will be able to help you...
- zepplin
- Real Name: Steve
Very helpful Thys........................................shouldn't you be fixing your Jeep??????
- Vehicle: 2004 Hilux KZ-TE 4x4. Intercooler. Chip. Dyno. tuned
- Club VHF Licence: X07
Trek n 65mm dia sirkel. Vat n kleiner masonary bit en boor kleiner gate in die rondte. Slaan dan die gat hit met n beitel
- zepplin
- Real Name: Steve
Rattlesnake wrote:Trek n 65mm dia sirkel. Vat n kleiner masonary bit en boor kleiner gate in die rondte. Slaan dan die gat hit met n beitel
Did that with the last one and almost took the whole wall down.................
That's how it was done before the carbide core bits were available. Just get one, you'll use it again for another project. If you have a decent rotary hammer drill with SDS chuck that can take a chisel, then a short (cheaper) core bit will work. (Use the core bit till it 'bottoms out', change to chisel and remove the 'plug' you've just drilled, change back to the core bit and drill the next 'plug' till it bottoms out again .... and so on till you're through. Sounds tedious, but it's not really - it goes a lot quicker than you'd expect .... about 5 - 10 min through an outer (9 inch) wall.
zepplin wrote:Rattlesnake wrote:Trek n 65mm dia sirkel. Vat n kleiner masonary bit en boor kleiner gate in die rondte. Slaan dan die gat hit met n beitel
I work by a very basic rule - if I need a tool for the SECOND time : BUY IT.
Phone BWH, then also phone BRIGHTS :)
every so often the one is a lot cheaper than the other :)
Can you see I am bored?? The Jeep isnt broken...zepplin wrote:Very helpful Thys........................................shouldn't you be fixing your Jeep??????
- Town: cape town
- Vehicle: Toyota Hilux 3.0 D4D
- Real Name: Tyrone
Have you got a DECENT SDS Max Combi hammer?Otherwise get a 65mm Core fitting for a sds+ drill.You can always resell it on gumtree or olx when you done.
The bit is the easy part.
Have you got the right size(wattage) drill for this size bit?
Me thinks at least a 2000w. Smaller might do but you will damage the clutch.
