I recently bought my 4.0 V6. Still getting to know the vehicle.
It is fitted with Velocity Raptor 31*10.5 AT tyres on the standard 15 inch Hilux mags.
Today I fitted the same tyres-with a set of Racing Hart mags that I took of my Ford Ranger- onto the Hilux.
I believe the Racing Hart's are 8 or 8.5J as opposed to the Hilux's 7.5J
The problem is that the tyres are now rubbing quite badly on the inside of the front mudflaps when I turn.
I never experienced the problem on my 2004 Ranger-I had 31*10.5 Yokohama AT tyres on the Racing Harts then.
Thought the Hilux has more space under the arch ?
Any solutions ?
Regards.
Tyres rubbing on front mud guards.
- Hangover
- Town: Deneysville
- Real Name: Stef
Re: Tyres rubbing on front mud guards.
Just throw lift spacers in the front and you will be ok...
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
I'm guessing that the Ranger Mags offset is different to that of the Hilux Mag. In other words the dish part of the wheel is deeper than on the Hilux and effectively give you a wider stance. If this is the case, when you now turn, the wheel actually moves further backwards and forwards and is now in line with the small screw holding those liners in place.
Lift spacers should sort it out as Stef suggested
- Town: Alberton
- Vehicle: Hilux 4.0 V6 manual
- Real Name: Gustav
Thank you for the feedback. The stance is indeed wider with the Racing Hart mags and looks better than with the standard mags.
Will try the spacers. Is it necessary to do wheel alignment after fitting the spacers ?
- Hangover
- Town: Deneysville
- Real Name: Stef
Yup you must do wheel alignment. I have seen most spacers sort out the rubbing issue but it is not the preferred "remedy" if i can call it that. With spacers you might get front CV issues in the long run which is not the case with a suspension lift IE OME, Mikem etc. I had them fitted and many other guys with no problems at all though... It also levels out the trokkie if you fit a set of 25mm spacers(40mm lift)
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
- Town: Alberton
- Real Name: Gustav
Thanks for the info.
- Drifter X
- Town: Fourways
- Vehicle: Toyota Hilux Kzte
- Real Name: Ranesh
Spacers will definitely sort out your issue,they cheap and easy to install
