CLEANING ALUMINIUM
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
CLEANING ALUMINIUM
Okay as some of you have most probably realised, Obelix ii is in for a heart transplant at the moment.
The problem I have is that there was a ridiculous amount of carbon and oil sludge build up in the motor. The sludge is gone but how do I get rid of the carbon build up?
Remembering that the engine is aluminium block and all. I have tried different degreasers, Aluminium mag cleaner ( the non carbon area's are now very shiny) is there a product out there made for this??
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- JohanW
- Town: Strand
Re: CLEANING ALUMINIUM
Elbow grease
- Town: ROODEPOORT
JOHAN EK HET SO TWEE WEKE TREUG MY LAASTE VAN DAAI OPGEBRUIK!!! en die winkels het nie nog nie
God made man before
God made man before
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
Oven cleaner will remove some of it but the really stubborn bits will take some elbow grease...
Or maybe paint remover...
- Town: ROODEPOORT
Oven cleaner is apparently to aggressive and will cause long term damage. was about to buy oven cleaner when i discovered that. Thanks anyway
God made man before
God made man before
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Gentle sand blast
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Town: Midrand
- Real Name: Nishan
A friend of mine had given me something a few years ago called "Spotter". I'm not sure if its commercially available. Its a clear liquid.
I tried it out this weekend on the casing of gearbox that was absolutely filthy. I only had about 200ml. Put it in a pressure spray bottle thingy and sprayed it on then left it for 5 mins and gave it a little brushing with a plastic bristled brush. The box came out like brand new. Problem is i didnt have enough to do the entire box
I unfortunately dont have the guys number. Will see if i can get it from someone.
Real drivers use three pedals
- Town: ROODEPOORT
that would be brilliant, and good luck in finding some more
God made man before
God made man before
- Town: ROODEPOORT
Worried about stuffing up the gasket sealing surfaces thenThunder02 wrote:Gentle sand blast
God made man before
God made man before
- Dirka
- Town: Doornpoort Pretoria
- Real Name: Dirk
Soda Blasting.
- Pietman
- Vehicle: 2005 Hilux V6 4L D/C 4X4
Aluminium Cleaner? I used it to clean my canopy when we were busy building it.
EX ALTO VINCIMUS
- Town: ROODEPOORT
Thanks Guys,
does anyone have experience with working with ALUBRITE seems like it is the correct stuff use
God made man before
God made man before
- Vehicle: Hilux SFA
- Real Name: Rodney
MEK the aircraft industry uses it clean ? check it out.
- Real Name: Rodney
http://www.team.net/sol/tech/clean_al.html" onclick="window.open(this.href);return false;
Also known as Butanone
- Real Name: Rodney
CAS Registry No.: 78-93-3. Other Names: MEK, 2-Butanone, Methyl acetone ... Thoroughly clean clothing, shoes and leather goods before reuse or dispose of safely. Eye Contact: ... Not corrosive to: aluminum alloys, carbon steel. Hazardous
- FIRSTGEER
- Town: King WilliamsTown
- Real Name: Tony Geer
- Club VHF Licence: HC 109
A few years ago I was really peed off when the special alu cleaning product,I had ordered for a job,was used by my sons to clean their offroad motorcycles engines.I had a planned service and cleaning of an industrial refrigeration plant made up of a lot of alu components.The buggers had used the product which was not readily obtainable.
I took some of my wife,s " collar and cuff" equivalent product sold around my area called " vanishing liquid" and did the leaning job.It worked as good as,if not better than the specialised alu cleaning liquid.
I still use it for cleaning engines and oil etc today.I understand it has ammonia as part of its formula.
Our very own Stephan van Eeden is the owner of A-Z Chemicals in Pretoria and they supply a very lekker Alu cleaner.I use it to clean intercoolers on the inside and outside.
To be honest, all his products work very lekker!
http://www.a-zchem.co.za/" onclick="window.open(this.href);return false;
- Town: ROODEPOORT
Got some alu brite didca quick test and itcseems to work very well. Apparently this was designed to clead alu heads by soaking.
Thanks for all the replies
God made man before
God made man before
- Scooter
- Town: JHB
- Real Name: Scott
Having just pulled my motor and finished stripping it to get the heads away for recon I sat thinking about the best way to go forward with cleaning.
I'm in two minds on whether or not to strip the block and give it a proper clean as there is quite a lot of sludge and carbon buildup inside.
Any suggestions besides pulling it all apart?
Sent from my SM-G920F using Tapatalk
- Mylux
- Town: Roodepoort
- Vehicle: 4.0L V6 Vigo 4x4
- Real Name: Greg
- Club VHF Licence: HC249
Buy some beer and invite Quentin around. He seems to be doing an excellent job
- Scooter
- Town: JHB
- Real Name: Scott
Now that's an idea Greg.............Quentin, my block is waiting, no rush
- Town: ROODEPOORT
Pull it apart you don't want anything coming loose and blocking your oil passages and then you will just have to re-do everything you just did and more.
If you ask Greg he will be able to get the right stuff to clean the sludge off
God made man before
God made man before
- Scooter
- Town: JHB
- Real Name: Scott
Seems some more stripping is in order, I have run out of space with all the parts lying around.
Reckon my wife wont mind me using the bath
- Town: ROODEPOORT
Don't worry my daughters trampoline and outside patio table has been unusable for a couple of weeks. the major problem is that i have now started packing the braai closed
God made man before
God made man before
- Mylux
- Town: Roodepoort
- Real Name: Greg
Let me know if you need Alubrite. Apparently it works quiet well. Just a pity we do have any before and after pics
Use the dishwasher if you can't use the bath
- Town: ROODEPOORT
Will do the before and after with the oil pick up the one that was posted earlier
God made man before
God made man before
- Scooter
- Town: JHB
- Real Name: Scott
I've actually got plenty bench space...........its just being used to store other crap and Im too lazy to move it
- Lomies
- Town: Centurion
- Vehicle: 2013 3.0 D4D D/C 4x4 Hilux
- Real Name: Arné
- Club VHF Licence: HC273
Mylux wrote:
Here a pic of him working on the Hilux
- IMG-20160906-WA0022.jpg (26.03 KiB) Viewed 6279 times
I didn't know that he's a plumber!
you guys are cracking me up .....
- Real Name: Marnus
Please stop cracking jokes about plumbers!
- Town: ROODEPOORT
Will all of you clowns please leave my crack alone!!!!!
Arne ek kom vir jou!!!!!!!
God made man before
God made man before
- Mylux
- Town: Roodepoort
- Real Name: Greg
You better watch your crack Arne.............Obelix is coming for you
The gent's facilities are open again.
- Lomies
- Town: Centurion
- Real Name: Arné
Obelix and Dogmatix wrote:Will all of you clowns please leave my crack alone!!!!!
- Mylux
- Town: Roodepoort
- Real Name: Greg
Arne....shouldn't you be waving a pink flag?
- Town: ROODEPOORT
Mylux wrote:Arne....shouldn't you be waving a pink flag?
God made man before
God made man before
- Lomies
- Town: Centurion
- Real Name: Arné
- Thunder02
- Town: East Rand
- Real Name: Neil
Arne, I adjusted your picture......
www.4x4direct.co.za
www.4x4direct.co.za
- Mylux
- Town: Roodepoort
- Real Name: Greg
Thank goodness we don't drive Opels
- Town: ROODEPOORT
AND I CALL YOU LOT FRIENDS!!!!!!!
WOULD NOT EXPECT ANYTHING ELSE!!!!!
MAAR GAAN JULLE ALMAL NOGSTEEDS MOER
God made man before
God made man before
- Lomies
- Town: Centurion
- Real Name: Arné
Yup, looks much better now.
Hmmmm .....
- Thunder02
- Town: East Rand
- Real Name: Neil
Mud Dog wrote:Hmmmm .....
www.4x4direct.co.za
www.4x4direct.co.za
- Scooter
- Town: JHB
- Real Name: Scott
I landed up using a quick wash with petrol and then a soak in Prepsol and a power washer.
Worked like a charm.....
The key is to let it soak in the Prepsol for as long as possible.
Inside the timing chain cover...
[img]//uploads.tapatalk-cdn.com/2016111 ... c84c41.jpg[/img]
- RiyadhFortuner
- Town: Lansdowne
- Vehicle: 2015 Ford Ranger T6
- Real Name: riyadh
I have used Autosol to clean stainless, I think they make an aluminium cleaner as well. I purchased it at a motorbike shop
