Hi all,
I am contemplating installing some for of sound deadening/dampening material into my Hilux. I have found a lot of useful information on various forums and also on threads here, but can seem to find one specific to the IFS.
Here are some links for anybody else that is interested:
http://www.4x4community.co.za/forum/sho ... -Reduction" onclick="window.open(this.href);return false;
http://hilux4x4.co.za/views/viewtopic.php?t=36753" onclick="window.open(this.href);return false;
http://www.4x4community.co.za/forum/sho ... 20proofing" onclick="window.open(this.href);return false;
http://www.4x4community.co.za/forum/sho ... 0deadening" onclick="window.open(this.href);return false;
My IFS is not particularly loud, probably just as loud as any, but I do find that at 120km/h that I have to put the music up much loader than it probably has to be in order to hear it properly (and it's not clear, but that's a seperator issue), and I have to talk loader than normal when having a conversation. Furthermore, I only really drive long distance, and the constant minor droning for several hours definitely contributes to fatigue. The heat insulation is not really a concern to me.
I have found that there are several products available: from the more expensive Dynamat and Second Skin, to the cheaper Sondor and Acoustex. In one of the links above you will find someone who achieved apparently great differences in sound and heat insulation using the cheaper Acoustex and simple camping mats... probably what I will end up doing.
What I am trying to find out, is if this is actually worthwhile for the IFS? Upon inspection under the carpets, I have found that my Lux has some form of silver hard lining approximately 2-3mm think already lining the floor under the carpet, and I can't seem to find anything suggesting if this is a heat/sound insulator already installed. It definitely appears to be original to the vehicle and not after market. If anybody can shed some light on this it would be much appreciated. Also, how do you remove the headlining on an IFS?
Regarding amounts and localities of application, it seems some suggest that you can have very good sound insulation improvement by only putting the stuff on 25% of the vehill interior, while suppliers/installers tell you to cover every square inch (obviously they would). I was told by a supplier (Acoustic Audio) that I would need to boxes of the Second Skin product (Damplifier Pro) to do my Hilux, which equates to approximately 6.5 square meters.
I suspect I may just do the door linings first to see if there is any improvement before committing to any other part of the car, but apparently most of the "ambient noise" comings through the roof.
Now that I've typed a lot, my main questions are:
1) Has anybody done this in an IFS and was it worth it?
2) Does the IFS come with some form of insulaton under the carpets?
3) How do you remove the headlining of an IFS?
Would be interesting to get some input from other forum members.
Sound/Heat Insulation in IFS
- drew3
- Town: Tuli Block
- Vehicle: '01 Toyota Hilux 4x4 Raider 2.7i DC
- Real Name: Drew
2001 Hilux 4x4 Raider 2.7i DC
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
Re: Sound/Heat Insulation in IFS
Had a SFA in which I put asbestos fibre matting under the carpet, which worked well for heat as well as a sound dampener.
This you would get from people who make fire deterrent products.
Hope you come right.
HABOOB means "Dust Storm"
I drive two IFS models, and none of them have a noise problem! Have you checked the gear rubber boot to see if it is not torn? Solved my problem with Bulldog (SFA).
Another thing is check carefully if all the rubbers in the firewall are intact. One of the previous owners of Hound Dog removed the rubber bung around the wiring loom to fit thicker cables through, and that made one hell of a noise - fan noise from the engine at speed. I sorted that out and now she is as quiet as a kitten!
- drew3
- Town: Tuli Block
- Real Name: Drew
Thanks for the responses Haboob and Family_Dog,
I will take a look at the firewall and any connections running through it.
