Gear Change
- Town: Boksburg
- Vehicle: 1993 Hilux 4x4
- Real Name: Carl
Gear Change
I have just purchased a 1993 Hilux 2.2 D/C 4x4 SFA "its been a passion for a long time" I am experiencing a problem with the gears going into 1st when the car is at running temperature I have flushed and replaced the gear box oil, so i guess im asking for any suggestions or maybe a reference on some one who can take a look at it for me, thanking all in advance.
Re: Gear Change
The specific oil can make a big difference, but it could also be that the spigot bearing is binding or clutch not fully releasing (pressure plate).
- Town: Mooi River KZN
- Vehicle: 96 SFA D/C 4x4 2.4
- Real Name: Malcolm
Re: Gear Change
I have got the same issue with my 2.4 1996 . All though its not impossible to get it into gear when she is all warmed up . But if i come to a stand still , It can be quite difficult . What oil do you recommend mud dog .? Am hoping to change diff x2 oil and transfer box this weekend . and gearbox of course .
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
- Vehicle: Hilux SFA
- Real Name: Rodney
Re: Gear Change
It sounds like a sincro gear.I took my box to a place in Benoni to assemble after we striped it to see what was broken.The owner should be able to tell you what is wrong as he does a lot of taxi boxes.
Re: Gear Change
I'm not sure about it being syncro rings ..... 1st gear normally doesn't have and since your problem is engaging 1st gear I didn't mention the syncros. If however the gear changes in general are 'notchy' then the syncros are a possibility but the more common causes are the oil, a spigot bearing that is sticky / stiff and a clutch that is not releasing properly.
Since your problem manifests when everything warms up, I think it's more likely to be the oil - I could of course be mistaken. IIRC I had a similar problem some time back that was dramatically improved after replacing the oil in the box, but I cannot recall what oil it was, just that it was a synthetic grade.
- Real Name: Rodney
Re: Gear Change
Andy I think you are correct what I would do if it was my box is drain oil and fill it with ATF to see if it makes a diffrence.
Re: Gear Change
ANother question .. How do I adjust my clutch ?? how do I tell if my release bearing is releasing properly..I have put new oil in the gear box . I put the same as what i used in my diffs .. I have got a feeling i should of used a finer oil .. i used 80w-90 .
Your thoughts please gentlemen
I have a 96 SFA D/C
I have a 96 SFA D/C
2.4 1996 SFA D/C
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
